06-27-2019, 11:29 AM | #1 |
Rep 14
Halogen to LED headlights
I am thinking of upgrading my 2018 BMW X1 standard halogen headlights to LED bulbs but don't have the knowledge (coding, etc.) to do it myself. Does anyone know of mechanics in the Seattle/Tacoma, Washington area who have the expertise to perform this headlight upgrade for me?
06-27-2019, 02:27 PM | #2 |
1367
Rep 1,031
Drives: Like a bat out of hell.
They sell CANBUS error free H7 bulbs. Some bulbs will require H7 adapter clips to make installation easy or you can bend that wire to hold your LED bulb in place. There are others that don't even require an adapter. They also sell plug-and-play CANBUS decoder. Just make sure there's enough lumens or otherwise your new LED will be even dimmer than the regular halogens.
The only caveat is the blinking at start up unless you code it to cancel bulb check. BMW sends a low current to these bulbs and since these LED don't require much power, they will flicker for a few seconds when starting up the car. There's a thread in here on how to turn off bulb check. |
06-27-2019, 04:15 PM | #3 |
137
Rep 310
What GenXer said. Hardware install is straightforward. If you need to modify the clip, I recommend taking the clip out and using a linesman plier to straighten the latch part. If you need to do it, this comment will make sense once you take it out.
If flashing occurs on start up, you'll need BimmerCode or Carly to code the bulb check to Off setting and change bulbs to LED option. Alignment of beam may be necessary to not be that jerk that blinds people while driving. Quick and easy way is to tape off a wall where the original halogen beam shines at then compare to LED beam after install. |
GenXer1367.00 |
06-27-2019, 05:50 PM | #4 | |
1367
Rep 1,031
11-24-2019, 01:36 PM | #5 |
33
Rep 129
GenXer skyline0210 I'm having a hard time installing the Phillips Ultinon's on my F48 because the H7 clips interfere with the LED fan. I've tried bending but made a mess of it. Do you know which H7 LED adapter clips fit the F48 H7 socket? There are a ton on Amazon, but none seeming for the F48 socket. Guidance appreciated!
11-24-2019, 09:44 PM | #6 | |
137
Rep 310
12-04-2019, 12:25 AM | #7 | |
1367
Rep 1,031
12-05-2019, 11:20 PM | #9 |
137
Rep 310
