F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > OEM N55 Valve cover. Experience?
ARMA SPEED
      02-18-2020, 05:02 PM   #1
F32Fleet
F32Fleet's Avatar
3570
Drives: 2015 435i
The N55 has been used in so many models I figured posting here would cast the widest net.
I need to replace the gasket and at 60k miles I don't want to have to pay a shop to go back in at 70k, 80k miles over a cracked cover or failed PCV so I'm looking for experience with the service life of the non-genuine part.
It appears that there are about three suppliers at 1/2-2/3 cost of the Genuine BMW part with 2-3 yr warranty.
Comment away and TIA.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      02-18-2020, 08:24 PM   #2
E90705
E90705's Avatar
127
Drives: E90/F25 M-sport
Genuine OEM VC and vcg via fcp euro. Can't say about other brands, only used OEM. I didn't want to have to deal with it for a while.
F32Fleet3570.00
      02-18-2020, 08:39 PM   #3
culto
49
Drives: E90, F10, F30 and F48
Had an Indy replace my gasket about 4 years ago. Sorry I didn't replace the valve cover then. Just replaced the valve cover and used a BMW oem valve coverfrom FCP Euro.
I wouldn't mess around with after market valve covers. Do it once and do it right.
F32Fleet3570.00
      02-18-2020, 09:10 PM   #4
msquaredF33
27
Drives: 435i
I used an off brand replacement and have had zero issues.
      02-18-2020, 11:24 PM   #5
Logicoeur
Logicoeur's Avatar
991
Drives: F30 335i xDrive
https://www.amazon.com/gp/product/B0...UTF8&psc=1
And an oem gasket. It's a Mahle vc with the logo covered. The Mahle is an OE with the bmw logo covered. The oe is just a Mahle with a bmw logo. There are so many instances of this kind of parts supply chain in our a cars and all major manufacturers. Can't post the FB thread where many people have used the above combo with no problems.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
F32Fleet3570.00
      02-19-2020, 06:25 AM   #6
F32Fleet
F32Fleet's Avatar
3570
Drives: 2015 435i
Thanks for the info. Unfortunately it doesn't fit for my MY (2015). PWG vs EWG?
      02-19-2020, 07:16 AM   #7
khj24
khj24's Avatar
221
Drives: 2015 m235i
I don't see why that would matter, my EWG cover still had the (unused) connections for the vacuum lines that the PWG uses.
      02-19-2020, 07:23 AM   #8
Logicoeur
Logicoeur's Avatar
991
Yeah the vac port is due to auto or manual I believe, not the turbo.
      02-19-2020, 08:42 AM   #9
khj24
khj24's Avatar
221
Drives: 2015 m235i
Not sure about that, the reference video I used for the replacement had the vacuum lines and was an auto like mine
      02-19-2020, 08:44 AM   #10
khj24
khj24's Avatar
221
Drives: 2015 m235i
OP, realoem shows one PN 11127570292 that runs from 2008-2019 on various chassis https://www.realoem.com/bmw/enUS/par...&q=11127570292
If I were set on replacing the whole thing I would just go Mahle for the cover and gasket since its the OEM.
      02-19-2020, 10:04 AM   #11
mcintoshf30
184
Drives: 2014 F30 335xi
I have a small oil leak at the back of the block that drips on my downpipe.. I'm at 69K, do I just do the entire valve cover since I'd have to do the gasket anyway?
      02-19-2020, 11:18 AM   #12
redbullfan
redbullfan's Avatar
356
Drives: 22 TR X3MC
2022 BMW X3MC  [0.00]
Replace the Gasket
2022 X3M Comp
2013 335i xDrive (Sold)
      02-19-2020, 12:12 PM   #13
culto
49
Do both now. Otherwise you will have to change the valve cover later like I did. Do it once and do it right.
      02-19-2020, 12:49 PM   #14
F32Fleet
F32Fleet's Avatar
3570
Drives: 2015 435i
Ya. The part no. is the same but the model year per the Amazon link ended at 2014. :
      02-19-2020, 08:22 PM   #15
Logicoeur
Logicoeur's Avatar
991
Check the part number elsewhere. Realoem
      02-22-2020, 07:53 PM   #16
Tpriest7893
215
Drives: Bmw 335i f30 N55 ( sold)
  [0.00]
2012 bmw 335  [0.00]
02 2002 m3 Vert  [0.00]
I had the same as you and had Bmw do my valve cover under warranty. They fail as miles go up so better off just doing it
2012 bmw 335i sedan
VRSF catless DP
VRSF 5? HD IC
Stock intake(had open before and was sick of noise)
BMS CP
550i 351m rims with 275/245 set up.
No tune as of yet.
f30post
