04-19-2024, 09:52 PM | #1 |
32
Rep 150
Port injection Maxxecu
Looking to run port injection off EOS manifold- anybody running Maxxecu controller?
I was going to go with Reflex but tuner suggested Maxxecu. Any reason one is better than the other? |
04-21-2024, 06:50 PM | #2 |
761
Rep 952
Not sure but Max is being used by the G80 crowd and they all like it better than Reflex. Tuner will need to create the map for it and not sure about the harness. I've been digging but can't find much on S55 adaptation.
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
04-22-2024, 09:13 PM | #4 |
BM3 Tuner
316
Rep 291
There is a single s55 using maxecu so far. One off harness for the time being, might be able to get some made if the want is there.
So far the car has been running 15x better! Plus BOOST BY GEAR
2019 BMW X3M40I - VRSF Downpipe, XHP Stage 3, Nostrum Stage 1 Injectors, VTT PCV and Oil cap.
Paul Johnson Tunes Shop/Development Car |
Wanted_M760.50 SnoozieToofs28.50 |
04-23-2024, 12:14 PM | #5 |
74
Rep 172
would you not be able to implement boost by gear via motiv as well if you’re controlling boost thru a mac solenoid connected to motiv?
2015 Liberty Walk M4
F80Paul Tuned New Jersey |
04-23-2024, 01:08 PM | #6 | |
ECUTek Master Tuner
10444
Rep 1,734
Drives: F80 M3 YMB
Yes you can
04-23-2024, 04:08 PM | #7 | |
BM3 Tuner
316
Rep 291
Another another nice thing about max ecu is it doesn’t shut off randomly mid pull😜
04-23-2024, 04:43 PM | #8 |
74
Rep 172
why wouldn’t you be able to adjust boost by gear if you’re controlling it via an external wastegate? motiv has never shut off on me randomly.
04-23-2024, 05:09 PM | #9 |
BM3 Tuner
316
Rep 291
Becuase atm on public release motiv firmware, there is no way to do boost by gear as standalone, now with ecutek or MHD where it’s “integrated” you could I believe. With maxecu you do everything via can so you can grab gear data
