BIMMERPOST Universal Forums General BMW News and Cars Discussion Doing oil pan gasket soon on 2007 e83(N52), anything else to replace?
      02-12-2024, 03:41 AM   #1
gazzo
Drives: BMW
Im already 90% on removal since I’m having to do some other stuff related to differential.
My question is while I’m already that far down in the removal process is there anything else I should replace? While it wasn’t a hard process it’s not something I would like to go through again within a year if I could’ve just done it all in one swoop.
I’ve got engine mounts as an extra since I’m already there.
https://xender.vip/
Anything else?
      02-12-2024, 09:18 AM   #2
pbonsalb
5234
Drives: 18 F90 M5, 99 E36 M3 Turbo
How many miles on the motor? I did rod bearings on my 2008 N54 when I changed the oil pan gasket at 150k miles. The N54 is more stressed. I slso added a crank guard, though the pan does not have to be off for that.
      02-12-2024, 10:01 AM   #3
osteome
osteome's Avatar
195
Drives: 2020 X5
We did the front suspension on our E83 X3 while it was taken apart for the oil pan gasket and also serviced the differential.
2022 M4 Competition ConvertibleDravit / Tartufo Full / Carbon Fiber Exterior...loaded
2020 X5:MW/Coffee Extended Merino, M Sport, B&W....loaded
2007 X3: Sapphire Black / Black loaded 6 speed
Gone: M3 E93 Silverstone II over Bamboo
      02-12-2024, 10:44 AM   #4
Rafichicago
Rafichicago's Avatar
699
Drives: 2018 M5 2009 E63AMG Wagon
I would refresh suspension if tired or have not been touched by now. If there was no weird noises from bottom end or oil pressure light I wouldn’t touch rod bearings. This engine is not prone to that. Early ones tend to have ticking from top end because of leaky valve buckets.
      02-12-2024, 03:07 PM   #5
4JawChuck
216
Drives: 2013 128i SE
Crank guard plate, oil sensor gasket, forget the BMW sealant injection and slather the gasket both sides with 3m grey sealant.
Check the oil pick up for belt material that may have been sucked in previously.
