04-25-2024, 06:12 AM | #1 |
Rep 75
FS: CT - AW 2011 E92 M3 6MT ZCP Stripper w/52k (CF Roof, Single Hump, Speed Cloth)
First off, this car isn’t going to be for everyone. If it’s not for you, then that’s ok. However, if you get it, then you get it. DM me if you’re interested and I will provide the VIN and window sticker. Clean carfax with title in hand (no lien) I bought the car stock in December of 2020 with 49,xxx miles. It was a great base, that I’ve taken the opportunity to improve on through some tasteful mods and maintenance. The car is probably a 9/10 for the miles. It has a paint chip here and there. It’s not anything that would annoy you, but I feel obligated to disclose. There has been ppf on the headlights since I bought the car. I added ppf after polish and before coating on the roof. The stock ZCP wheels (cracked and bent) and brakes are not included. Almost everything else, including the complete stock x pipe and seats, is. Even stock motor mounts and rod bearings, in case you wanted to see what they looked like when I had them pulled out. I CAN MAKE THIS CAR 50 STATE LEGAL BEFORE TRANSPORT IF THAT MATTERS TO YOU. Below is the list of maintenance and modifications done under my ownership. 5/2021 @ 49,400 (AutoCouture) Inspection 3 (valve/timing cover gaskets, spark plugs, cabin air filter, coolant/PS/trans/diff/brake flush) BE rod bearing replacement Turner Motorsport power pulley kit AFE cf intake kit Bimmerworld group N motor mounts Ultimate clutch pedal 6/2021 Recaro Pole Position ABE in cloth with Brey-Krause side mounts on OEM sliders MJunkee GTS style armrest 7/2021 @ 49,800 (AutoCouture) KW Clubsport 2 way coilovers SPL rear toe links with eccentric lockout kit SPL front caster rod monoball Fall-Line billet aluminum trailing arm Fall-Line rear sway bar end links Fall-Line rear camber shim conversion 3DM rear trailing arm ball joint conversion New OEM suspension arms that were not replaced by Fall-Line Turner Motorsport solid subframe bushings Turner Motorsport rear shock mounts Hotchkiss sway bars Stoptech stainless steel inner and outer rear brake lines Coding for passenger occupancy sensor, GTS MDM, and TPMS delete 8/2021 Volk Racing TE37 SL 18x9.5/10.5 265/285 Michelin PS4s 5/2022 OEM chrome kidneys and side vents (have stock black chrome) 6/2022 Active Autowerke primary cat delete test pipes on a different x-pipe than stock OEM replacement transmission mounts 4/2023 @ 51,800 (AutoCouture) F8x M3 front suspension uprights F8x M3 front and rear brakes/rotors F8x M3 front and rear hubs and wheel bearings Stainless steel front brake lines MSI press in wheel studs Core4 floating lug nuts Turner Motorsport undertray GTS style cf front lip Remove windshield to replace gaskets and mouldings 4/2024 Rogue Engineering license plate bracket (black ti hardware) Rogue Engineering exhaust support bracket (gold ti hardware) Last edited by kk2; 04-27-2024 at 07:06 AM.. |
04-26-2024, 02:51 PM | #3 |
148
Rep 284
More photos of interior and engine bay? Where is this located?
1985 Euro E24 M6 5Speed - Graphite Metallic/Black Buffalo Leather
1998 E36 M3 5Speed - Titanium Silver/Black Vaders 2011 550i X Drive M Sport - Carbon Black/Cinnamon 2020 M2CS 6Speed-Black Sapphire Metallic - Black Style 763M |
