12-26-2019, 12:42 PM | #23 |
104
Rep 169
It Worked!!!
Following up here:
I finally got around to getting to an inspection station to test out this method. My car is a 2018 F80 ZCP running stage II bootmod3 with VRSF catless downpipes and stock ZCP exhaust. I placed the defoulers exactly like the OP instructed, and flashed stock tune (no lock). I drove around for about 25 or so miles after and then hooked up to a local shop inspection station OBDII. It worked. Everything was shown as "ready/pass". Got my sticker and I'm good for a year without putting stock downpipes back on. Thanks to OP for this thread. Saved me a lot of aggravation. I'll be putting these on every year now. |
01-15-2020, 08:02 PM | #24 |
17
Rep 68
How are you getting to the first downstream picture? I CANNOT get a tool in there to turn that nut... and how tight does the defouler and sensor have to be when installed? I got the 2nd in and that was a B××××. Cant get first one.
I have PLM downpipes btw... Last edited by M4SSIV; 01-15-2020 at 09:46 PM.. |
01-23-2020, 09:42 PM | #25 |
474
Rep 1,009
In VA they allow for one failed monitor. With that said, could I just flash to stock, ensure readiness is set albeit without a CEL and pass?!
Smog and visual are non issues for me. Car only has DP's with stock exhaust.
Pure F82
01-24-2020, 01:19 PM | #28 |
465
Rep 502
01-24-2020, 01:55 PM | #30 |
852
Rep 445
I did some research on this forums some peoples in different states use bm3 stage 2 tune and couldn't pass it. The one I went to was self service using kiosk!
01-24-2020, 04:54 PM | #33 |
17
Rep 68
01-24-2020, 06:56 PM | #34 |
465
Rep 502
How are you getting the cat monitors to show as ready though? Did you use the spacers method in this thread or did you have a custom tune that forced them to be ready?
01-24-2020, 07:55 PM | #35 | |
852
Rep 445
01-24-2020, 08:52 PM | #36 | ||
2056
Rep 1,984
01-27-2020, 04:40 PM | #38 |
52
Rep 173
Have full eisenmann non-resonated exhaust and catless down pipes. Was told by my smog guy who was trying to pass it that the status of the cats on my car show 'Incomplete' as opposed to 'N/A' .. He asked if my car was tuned but I really don't know I just got it and was told it was flashed back to stock.. Anyway to check if car is on stock tune or flash tune??? I don't have any programs like BM3 or VRFlash which is the tune the seller mentioned.
If I use the defouler method would it work with my set up?? Any help would be appreciated. |
02-04-2020, 06:06 PM | #39 | |
17
Rep 68
02-04-2020, 06:21 PM | #40 | |
52
Rep 173
No idea honestly, the guy told me he couldn't do it because it showed INC. He said normally it shows N/A. I hope to get the smog done this week at a place another member recommended. Guy said he could do it, so we'll see. Worse case scenario back to stock I go. Will report back. |
03-11-2020, 07:55 AM | #41 | |
57
Rep 148
03-11-2020, 07:58 AM | #42 | |
57
Rep 148
Yeah it’s not easy, you have to just use the oxygen sensor removal tool, it makes it 1000000x easier to take them off. You also need to unclip the o2 sensors completely so they are free; that way you can screw them into the defouler once you install that into the downpipes. If it’s plugged in still it will get twisted and won’t work. So unclip it completely first then use the o2 removal tool to unscrew the downstream o2 sensors |
GA///BIT31.00 |
04-27-2020, 10:25 AM | #43 |
67
Rep 144
I'm curious too... any impact of leaving them in there permanently while using DP's?
2017 Yas Marina Blue M3 - ZCP
2008 E60 M5 Alpine White - SOLD Instagram.com/Veeral4Real |
Tags |
bm3 stage 2, catless downpipes, defouler, emissions, how to pass emissions testing |
