Deleting Foglight VO
04-18-2024, 12:37 AM | #1 |
528
Rep 1,165
Drives: 09 E92 335i 6MT
Im at a bit of a loss here, quite confused.
I removed the VO for fogs ($520) from both my CAS and NFRM. Somehow I am still getting fog light errors on my iDrive. Do I still need to code out the cold and warm checks?
09 E92 335i 6MT / Alpine White / Coral Red / VRSF 7.5" / VRSF DCI / VRSF Catless Downpipes / VTT Charge Pipe / Turbosmart RacePort Gen V / RB OEM Billet Turbos / CD919 Custom Tune / Bilstein PSS9s
04-18-2024, 10:43 AM | #2 |
207
Rep 168
It sounds like it: https://www.e90post.com/forums/showthread.php?t=739072
04-18-2024, 11:21 PM | #3 | |
Robot
1693
Rep 2,193
If yes, you might have to default code KOMBI too. |
04-19-2024, 12:28 PM | #4 | |
528
Rep 1,165
I had only read that CAS/NFRM were necessary. At this point I am looking to update my FRM to C33 software, which I believe is done with winkfp if you have any tips there. I know I will lose any coding, which is fine I don’t have much.
04-22-2024, 03:49 PM | #5 |
207
Rep 168
CAS and NFRM are all you need to update in order to update the VO, but if any other modules are affected by the change in VO, those modules need to be "default coded" in order to reflect the change.
04-22-2024, 06:50 PM | #6 | |
528
Rep 1,165
I discovered a previous owner had coded out brake light errors because immediately after this, I got bright light errors. For awhile a few friends told me they looked kinda weird but, I had no errors so kinda ignored it.
