my weekend cleaning my intake valves!
08-05-2015, 05:55 PM | #45 |
215
Rep 1,818
I don't see any vacuum lines coming from the driver side fender like that...
only the center hose here, but that comes from the bottom as you see http://image.superstreetonline.com/f...135-engine.jpg |
08-05-2015, 06:07 PM | #46 |
15
Rep 157
I have no idea where it goes to ive checked most everything. I just know that it comes out of the side near the drivers fender with two other hoses..
08-05-2015, 06:20 PM | #48 |
Rep 44
There is no reason to spend 30 minutes trying to work around something rather than spending the 10 minutes it takes to just take the part out. It's similar to a child complaining about something longer than it would take to just do it...
08-05-2015, 06:26 PM | #49 | |
215
Rep 1,818
it's only a problem if you don't have the replacement bolts |
08-05-2015, 06:33 PM | #52 |
15
Rep 157
Thanks guys im just gonna hold off on the thermostat until those bolts come in. I assume ots.ok to drive around with a thermostat open for awhile based on what ive read here on the forums.
08-05-2015, 06:35 PM | #53 |
15
Rep 157
08-05-2015, 06:38 PM | #54 | |
215
Rep 1,818
does it have vacuum when you start the motor? are you stock charge pipe? |
08-05-2015, 07:14 PM | #55 |
15
Rep 157
Awesome gives me a little room to play! So yeah its stock charge pipe but everything is still apart because of my valve clean so i cant check with motor on.
