03-04-2022, 08:03 AM | #1 |
Rep 28
Fullscreen Carplay
Just got fullscreen installed on my 2018 MSport by Bimmer-Remote. Fantastic people. Installed remotely, fairly quickly. Would totally recommend.
I originally coded it with BimmerCode but parts of the screen, the touch would not work and it was a little grainy. Now it’s perfect. |
03-04-2022, 12:10 PM | #3 |
Rep 28
04-29-2022, 02:57 PM | #5 |
Rep 24
How was the process?
Reading the notes on their website: "After purchase you will receive a software to download. After downloading the software we will book a remote session for you. Our technician will connect remotely and he will flash your headunit and activate Fullscreen mode." |
04-29-2022, 05:36 PM | #6 |
2033
Rep 2,814
Drives: F33 430 and F39 M35i
will this affect the OTA updates for the navi?
for $60 it might be worth it to make carplay fullscreen. |
05-03-2022, 01:01 PM | #7 | |
76
Rep 155
I did it myself with Bimmercode to put CarPlay fullscreen: Bimmercode Expert Mode in the Head Unit section |
05-03-2022, 06:36 PM | #8 |
Rep 28
I did that way too but it just stretches the screen out and is pixelated. The touch calibration is off too, I wasn’t able to press anything on the screen, had to use the dial. Getting it coded correctly is the way to go.
05-03-2022, 07:34 PM | #9 | |
76
Rep 155
Perhaps, it has something to do with the resolution. I saw this setting from someone else post. |
05-03-2022, 10:49 PM | #10 |
2033
Rep 2,814
I’ll try it with bimmercode. Gotta find the dongle.
Thank you! |
05-05-2022, 06:09 AM | #11 |
2033
Rep 2,814
Did it. The right 1/3 of the screen isn’t working for touch but i rarely use the touch anyway so this works just fine! Touch works on the left 2/3 of the screen.
Thanks again! |
05-05-2022, 06:42 AM | #12 |
110
Rep 394
Stretched out when you have it set to the correct resolution means that your infotainment system firmware is too old to accept the setting and needs to be updated by a dealer or 3rd party (this is not the same as the software you get on the BMW website)
05-05-2022, 06:45 AM | #13 |
2033
Rep 2,814
It’s stretched but after playing with it all the touch functions work if you touch to the left a little. Basically the buttons still react correctly if you press where the buttons are when not full screen.
Waze directions won’t show up on the hud since my car is old but the factory nav stuff still shows up in the hud. Ie press here for heart Last edited by chowser51; 05-05-2022 at 06:49 AM.. Reason: Pic |
05-06-2022, 08:38 AM | #14 |
Rep 114
Thanks chowser51 for trying with bimmercode. I have bimmercode, but I couldn't live with the stretched graphics and touch issues. I reached out to bimmer-remote with my VIN to clarify which offering I would need for my vehicle (2020 x2 M35i). They replied quickly with this-- "Firmware upgrade for Entrynav2 / WAY + Fullscreen" ($159). Before I pull the trigger, is this something my dealer would be able to do? I was wondering if anyone has done this through a US BMW dealer. I'd rather not bring it up with my service advisor unless I know it is something they typically do.
05-06-2022, 09:19 AM | #15 | ||
110
Rep 394
05-06-2022, 08:42 PM | #16 |
76
Rep 155
Sorry for the delay to reply, busy week at work.
I never asked the dealer to update my firmware specifically. They must have it done at some point. When I tried Bimmercode, it worked right away. I am Canada so I assumed that in the US we are always on the same firmware and get updated almost at the same time. It seems not... |
08-24-2022, 04:27 AM | #18 | |
Rep 11
I'm waiting for my ENET OBD cable to arrive then I'm definitely getting this coded |
08-24-2022, 04:07 PM | #19 |
140
Rep 256
Does anyone know what firmware version to check for, as a minimum that will fully support Bimmercode to allow full operation in a 2019, and not how it was working in posts 11 & 13?
Current:
2019 911 targa 4 | GT Silver Metallic 2019 X3 M40i | Glacier Silver Past: 2013 911 C4S | 2019 X2 M35i | 2015 M5 Comp | 2013 M5 | 2013 640i | 2010 535xi | 2007 525xi |
08-24-2022, 04:22 PM | #20 |
1792
Rep 3,059
20-07 at least
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
08-25-2022, 06:34 AM | #21 |
140
Rep 256
Thanks. Went through all idrive menus and didn't see anything close to that format. Is it something that pops once you attempt Bimmercode, or is there another way to check?
Current:
08-26-2022, 12:11 PM | #22 | |
Rep 11
