BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Is anyone else having throttle issues??
      07-16-2019, 10:44 AM   #23
Glazonyoursix
Glazonyoursix's Avatar
39
Drives: X2 M35i
Originally Posted by rice_rocket88 View Post
The X1 forum had a bunch of people with similar issues.. some way worse than others. My wife's X1 has this similar hesitation as well in comfort mode. My m35i, however I can really feel the transmission disengaging in comfort etc. So much that when I come to a nice slow stop, sometimes it disconnects the transmission just at the same time I let off the brake to have that smooth stop.. and it makes it a pretty choppy slowdown. Very awkward to say the least. I'm just running on sport mode all the time. I too have thought about getting the pedalbox/pedal tuner.
Huh interesting I'll look at some of the X1 forums in a little bit. But don't you think it's just weird how you strictly in Sport mode? Don't get me wrong I like Sport mode in cars but sometimes I like the comfort mode as well.
      07-16-2019, 11:21 AM   #24
billnchristy
1604
Drives: 2022 M440xi GC
I find sport a little too pedal happy, but the tuner could fix that.
      07-16-2019, 04:21 PM   #25
Glazonyoursix
39
Drives: X2 M35i
So I just got back the X2 and my friend, head manager for services told me that there was a part that was not completely connected in the engine. This part is what feeds air into the engine. They weren't able to replicate the situation before and after the fix. It actually runs a lot better now compared to before. I do advise that you all look at this part as it could be the cause of the situation albeit it might just only be my car that had this hose connection issue.
      07-16-2019, 05:17 PM   #26
Patrick852
Hong Kong
66
Drives: 15 320iED, 18 X2 sDrive20i MSX
I'm glad they found the problem! Do you call it solved?
      07-16-2019, 05:20 PM   #27
Glazonyoursix
39
Drives: X2 M35i
No I am still testing it out but I advise to check the same location or take it to local dealership and say you have the issue where it doesn't go.
      07-16-2019, 05:28 PM   #28
satz
336
Drives: 2019 BMW X3 M40i
I've had this happen on my 2.0 litre petrol with 7 speed DCT. Dangerous and annoying. In very similar situations to the OP's.
It's not so bad when using the 'Sport' driving mode.
I guess it's a combination of the engine lag ( i guess the M35i lag could be even worse given that it's more power out of the same sized engine?), combined with the 'learning' of the ECU/accelerator, whatever, that seems to want to keep the gear as high as possible for fuel economy?
Ruined the driving experience of my E90 335i automatic that I owned previously.
Just wish I could have bought a manual
      07-18-2019, 08:32 PM   #29
rice_rocket88
Drives: E60 F48 F39
Where exactly is that location? It sure doesn't hurt to look..
      07-19-2019, 04:12 PM   #30
xcelir8bmw
xcelir8bmw's Avatar
402
Drives: 2022 BMW M240ix
bump
      07-25-2019, 09:18 PM   #31
satz
336
Do people find this gearbox 'lag' worse after a distance travelling at steady higher speeds? That's what I find, and I think it's because the gearbox/throttle/engine 'learning' puts it into an economy mode. It's annoying, and possibly dangerous, like when trying to merge into another lane and I don't know whether the car is going to respond quickly, or sluggishly.
I find when I tootle around for a longish period in suburbs, or light traffic, then the car is more responsive to small throttle inputs.
In my case at least, I'm sure it's not the hose issue, but the so-called learning inbuilt into the components...aimed at economy and possibly a smoother (older-person's) drive
Annoyed me more in my 335i. Maybe the X2's 7-spd DSG responds a little quicker, and the one extra gear ratio helps a little...
      07-26-2019, 11:35 AM   #32
billnchristy
1604
I ordered a pedal tuner, should be here next week. I’ll report back on it.
      09-05-2019, 07:43 PM   #33
satz
336
For those looking for the location of this hose, a bit of detective work shows that part number 863360 which you can see in the photo above, is one of the ignition coils that sits on top of each of the four spark plugs. So this potentially loose hose appears to run across the top of the engine block if that helps anyone...
I'll try to take off the engine cover and see.
cheers
      09-05-2019, 07:46 PM   #34
Glazonyoursix
39
Drives: X2 M35i
cheers
Thank you for posting this I did not know where the location was for this. I hope this does help out lads!!
      09-06-2019, 04:07 PM   #35
satz
336
I took the engine cover off last evening. That's actually quite easy to do. Just lift the front edge firmly and it will disconnect from these 2 x sockets. Then put your hand through the gap between the windscreen air/intake base and the stabiliser bar and you can reach the rear of the engine cover. Just pull up the rear and that's off!
Anyway, couldn't see any loose hoses. Didn't really expect to in my case as it didn't sound anywhere near as bad as the OP's.
To put back the cover just line it up with the oil filler cap and then push down at rear, and then front.
cheers
      09-06-2019, 04:10 PM   #36
Glazonyoursix
39
Drives: X2 M35i
cheers
Good to hear back from the situation. It's a good thing that you didn't have it as bad as I did. Luckily my Dealer was able to fix it with the hose that they found.
      09-09-2019, 08:01 AM   #37
Glazonyoursix
39
Drives: X2 M35i
cheers
      09-14-2019, 03:05 PM   #38
El Greco DC
El Greco DC's Avatar
10
Drives: ‘19 X2 M35i
Thank you for posting this. I’ve had my M35i for two weeks and have been experiencing the same problem; in fact, it seems to be getting worse. I’ll be checking for the loose hose this afternoon.
      09-14-2019, 03:44 PM   #39
Glazonyoursix
39
Drives: X2 M35i
Originally Posted by El Greco DC View Post
Thank you for posting this. I've had my M35i for two weeks and have been experiencing the same problem; in fact, it seems to be getting worse. I'll be checking for the loose hose this afternoon.
Did you have auto Start/Stop on??
      09-15-2019, 07:17 PM   #40
DAC17
Long live BMW M's!
171
Drives: 2023 CT5-V
I have had the same issue as the OP; I'll have the dealer check that part. Thanks for the tip.
2023 Cadillac CT5-V
2022 Mazda MX-5 (manual)
2022 Chevy Bolt (being a little environmental)
      09-16-2019, 05:50 PM   #41
xcelir8bmw
xcelir8bmw's Avatar
402
I do not have the issues, but I did check and no loose hoses. Yay.
      10-11-2019, 04:48 PM   #42
El Greco DC
10
Drives: ‘19 X2 M35i
This is still happening to me with my M35i on a regular basis and today was particularly bad. The trip home from work involved a lot of stop and go traffic and I nearly rear ended the car in front of me twice because of the throttle lag. I went to accelerate and the vehicle hesitated then jumped forward in a burst after about 2 seconds. Also, while trying to make a quick left turn against oncoming traffic, the throttle lagged so badly I nearly caused an accident . . . also twice. The Auto-off was deactivated during the whole trip and I noticed the same condition in all three of the driving modes.
The ONLY thing that alleviated this was when I put the transmission into manual mode and used paddle shifters to shift. There was zero lag and the car behaved perfectly in that condition.
Are others experiencing the same thing? It’s gotten to the point where I really no longer trust the vehicle to respond as it should. I end up looking like I’m hesitating at four way stops and left turns after slowing down. This causes the other vehicles to take advantage of my “hesitation” and go through intersections because they think I’m still stopped or coming to a rolling stop. Ugh.
      10-11-2019, 04:55 PM   #43
Glazonyoursix
39
Drives: X2 M35i
Are others experiencing the same thing? It's gotten to the point where I really no longer trust the vehicle to respond as it should. I end up looking like I'm hesitating at four way stops and left turns after slowing down. This causes the other vehicles to take advantage of my "hesitation" and go through intersections because they think I'm still stopped or coming to a rolling stop. Ugh.
This is the exact same issue that I had in my M35i. Every time I would come to a stop light or turning to the left that is when the car lagged terribly. You legit explained exactly how I had my problems.
      10-11-2019, 04:58 PM   #44
El Greco DC
10
Drives: ‘19 X2 M35i
You mentioned that after your trip to the dealer in July the problem seemed to be fixed. Is it still gone or has it come back?
