TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > X5 Photo/Video/Audio Gallery
      11-16-2018, 10:42 AM   #45
9vapors
652
Drives: CB X5M
Well the price of the Powerdome hood has come down a lot... hmmm
https://www.ecstuning.com/b-genuine-...d/41617275285/
      11-16-2018, 11:13 AM   #46
do_0b
55
Drives: 2010 X6 M
2010 BMW X6M  [0.00]
do ittttttttttt
      11-17-2018, 03:16 PM   #47
9vapors
652
Drives: CB X5M
Got some of these corny things, but really they are much brighter than the stock lights. They're these: Grolish 2 Piece Car Door LED... https://www.amazon.com/dp/B075FK4XLS?ref=yo_pop_ma_swf
Probably will get a matching set for the rears
Appreciate 2
      11-18-2018, 10:30 AM   #48
argento
argento's Avatar
538
Drives: 2013 X5M
Thanks for the link, not bad...
      12-03-2018, 07:58 PM   #49
9vapors
652
Drives: CB X5M
In the cheesy realm, I added some of these... I had a moment where I dropped my cellphone down there in the seat abyss and had to pull over to find it... so these should help... for $12, they match well and the embroidery looks nice.
      12-04-2018, 12:08 AM   #50
9vapors
652
Drives: CB X5M
Something I wanted to share with anyone reading my "journal"... I've had a persistent 2E91 CEL that would not go away. I received it about a month after I installed my downpipes and Velos stage 2+ tune. I gave everything in the engine a once over, found the vband clamps on the downpipes were not tightened down all the way, found one of my hose clamps on my custom intakes wasn't on the coupler completely etc. I had the car smoke tested, reset adaptations, my injectors tested, spark plugs, O2 sensors all checked and tested. I removed the tune, it still came back. My code was particularly odd since it was showing up by itself, and reporting lean. Usually this code is accompanied by another code pointing towards a vacuum leak of some sort. To add to the strangeness of it, I'd get the code when just cruising at low RPMs, not when I was on it or driving it hard. If I clear it, it would come back within a day or two, about 30-40 miles... Reading online, there wasn't much on this code alone, and less on an X5M, but I was able to piece together some info.
People complained of this code during winter months, or when they used certain tanks of E85... I dismissed this for a few reasons, I run 93, always from the same gas station and there is no ethanol added... or so I thought. I went to get gas a few weeks ago, and noticed that it was now showing that they are using 10% ethanol. I went inside and asked and they said that starting in the fall, they begin running some ethanol in their 93 as well, then switch back to straight 93 in the spring. I don't know why exactly and the attendant didn't either. Keep in my my code started around the same time the ethanol content changed.
The other thing is that for the past few tanks of gas, I've been running an additive as well. I've read so much good about the additive that I bought a 4 pack and figured I'd put my car through a "cleanse"... The product is Liqui Moly Jectron Gasoline Fuel Injection Cleaner-pk4 https://www.amazon.com/dp/B00LPV1LHE..._WnHbCbBTYMHJN
I read about someone getting this code when they put an injector cleaner in another BMW model, so a light clicked on and I hadn't used the last one to see if that could be causing the fault.
I ran my gas tank basically dry, I had about 25 miles left to empty, found straight 91 at a gas station nearby and went and filled up. Check engine light went off on its own and hasn't come back. No code anymore. Unfortunately due to these two things being a factor, and stopping both at the same time, I don't know if it was the ethanol laden 93, or the Jectron...
Anyway, this fixed my issue and I wanted to share my info in case someone starts receding the same and is tempted to chase it with parts as it's a pretty generic code.
mirob3167.50
      12-04-2018, 06:37 AM   #51
mirob
mirob's Avatar
3168
Drives: M3CX
FWIW, I've used 10% ethanol 91 octane for the life of my X and never received that code. I'm also on Velos 2+, RK intake, but stock DPs. Sounds like the Liqui Moly was the culprit.
9vapors651.50
      12-04-2018, 07:28 AM   #52
boneca
boneca's Avatar
2027
Drives: 2022 BMW X5
2013 BMW X5M  [10.00]
2011 BMW X5  [10.00]
I have the same and those are great, best $10 spent
9vapors651.50
      12-04-2018, 08:55 AM   #53
9vapors
652
Drives: CB X5M
Awesome, good to know. Hope that helps someone with this random code...
      12-04-2018, 08:56 AM   #54
9vapors
652
Drives: CB X5M
Not going to lie, I saw them listed in your parts list and went and looked them up, stole that one for sure...
boneca2027.00
      12-04-2018, 09:31 AM   #55
boneca
boneca's Avatar
2027
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
hahaha great, I'm glad it was helpful, sometimes little things make all the difference
-tested-and-approved
9vapors651.50
      12-04-2018, 09:57 AM   #56
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
794
Drives: BMW M3 JB 04 Coupe
You know you guys are so right! Anyone got a link for those inserts?
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
Appreciate 2
9vapors651.50
boneca2027.00
      12-04-2018, 12:16 PM   #57
9vapors
652
Drives: CB X5M
This is the set I got...
https://rover.ebay.com/rover/0/0/0?m...2F202329585911
      12-04-2018, 12:18 PM   #58
0-60Motorsports
Bahrain
794
https://rover.ebay.com/rover/0/0/0?m...2F223222379899
Thank you!
Current Mods:
IG: @060Motorsports
      12-05-2018, 08:19 PM   #59
9vapors
652
Drives: CB X5M
I had my roof rails removed today... I love how it looks so much better. Crappy garage pic attached, will take better ones tomorrow. Also, anyone looking for a low profile painted set, let me know...
boneca2027.00
      12-05-2018, 08:44 PM   #60
boneca
boneca's Avatar
2027
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
way to go
9vapors651.50
      12-06-2018, 07:40 AM   #61
0-60Motorsports
Bahrain
794
That looks great! I'm thinking of removing mine too.
Current Mods:
IG: @060Motorsports
9vapors651.50
      12-06-2018, 02:24 PM   #62
9vapors
652
Drives: CB X5M
Couple quick driveway pics... not a big deal for some, but it made such a huge difference to the look of the car for me.
      12-06-2018, 02:35 PM   #63
0-60Motorsports
Bahrain
794
Looks sleeker. Time for some springs and spacers.
Current Mods:
IG: @060Motorsports
9vapors651.50
      12-06-2018, 02:49 PM   #64
9vapors
652
Drives: CB X5M
Spacers will be here today... springs are on the short list...
      12-06-2018, 02:51 PM   #65
0-60Motorsports
Bahrain
794
Great. What sizes did you get. I got 12/20mm but I'm changing the fronts from 12-15mm after I installed the new Dunlop's.
Current Mods:
IG: @060Motorsports
      12-06-2018, 03:13 PM   #66
boneca
boneca's Avatar
2027
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
Looks good
9vapors651.50
