      12-23-2011, 05:19 PM   #23
fastauto
fastauto's Avatar
26
Drives: AW 1M Coupe
What is the corner delete mod all about?
      12-23-2011, 05:43 PM   #24
1sonnyM
Drives: 1M
Will this cable work:
http://www.ebay.co.uk/itm/BMW-USB-OB...-/120818069365
Somewhere down the page they mentioned that it will not work for cars made after 2007 and yet the screenshots seem to tell otherwise. What you guys think? Can we plug this in on our 1M ?
      12-27-2011, 07:14 AM   #25
discoboy1
discoboy1's Avatar
123
Drives: E82 1M VO/F30 328D
I read in an other post that euro spec cars have dynamic pulsating third brake light under extreme braking, can we activate this in NA?
2011 E82 1M VO
2013 F84 35i VO
      01-02-2012, 11:44 PM   #26
ronster
16
Drives: 2011 1M VO
hi egghie, have you confirmed the mirror memory in keyfob yet? It would be a great option for my stripper...
Cheers...
Originally Posted by eeghie View Post
Found the Curb Monitor parameters (freebee for those of us with stripper cars):
AUT_SPIEGELVERSTELLUNG
aktiv
SPIEGELABKLAPPEN
aktiv
BEIKLAPPEN_B_KOMFORTSCHL
nicht_aktiv
MEMORY_SPIEGELABKLAPPEN
aktiv
SPIEGELHEIZUNG
ptc_kl_15
SITZMEMORY_VERBAUT
aktiv
V_VAR_SPERRE_BEIKLAPPEN
wert_01
LL/RL
linkslenker (use rechtslenker if your steering wheel is on the right)
SPIEGELHEIZUNG_VERBAUT
aktiv
ABKLAPPWERT
wert_02
Mirror memory in the key fob (without memory seats) is not yet confirmed, looking into that. TBC
For the AngelEyes there should be some options for those of you who would like to not use them. So far the only confirmed solution is the delete of the individual broken bulb warning: Because of that, if you take out the bulbs, you will not get a warning. TBC
BTW, these coding options are mostly not accessible via the idrive (although there are a few coding options to add menus to the regular user interface). The coding is done by using PC software to change the values of the parameters used by the BMW OEM software for the various micro processors (called xxxx Control modules) in the car. Then loading the changed settings from the computer via the USB port to the cars OBD connector. Query bmw coding if you're interested.
Not that I'm a nerd or anything; the above was told to me by a captian Kirk look-a-like at the last StarTrek convention
2011 1M VO stripper
2009 AW 135i M-sp (sold)
2002 SG MINI Cooper (sold)
      01-03-2012, 02:38 AM   #27
eeghie
Kind of a big deal
301
Drives: an 1M not often enough
Cheers...
It's not looking good, as the mirror memory location where the settings are stored might actually be in the electric seats module, instead of in the more general modules (available in stripper cars). For the next couple of months car is in storage, so i'm not able to progress on this topic. After that I'll post a final findings.
      01-03-2012, 02:52 AM   #28
Dackelone
European Editor
Dackelone's Avatar
Germany
10607
Drives: N54 e82
It turns off those orange parking lights at the "corners" of the headlights.
      07-17-2012, 04:20 PM   #29
PapaZoo
Drives: E36/7 M Coupe, E30 M3, E30 4dr
Hey guys
i have coded many cars but everytime i try and connect to my BMW 1M it gives me this error.
I have updated V46 and still have this problem. If someone could help me out that would be awesome.
Thanks
      07-18-2012, 02:08 AM   #30
eeghie
Kind of a big deal
301
hi eeghie, have you confirmed the mirror memory in keyfob yet? It would be a great option for my stripper...
Cheers...
Yes, here we go, Mirror memory in Keyfob is stored in FRM (a module we all have), however this module will only be able to set the mirror if you have an advanced mirror version (in case of the US 1M this only comes with the premium package, this advanced mirror version is connected with a so called LIN bus/cable. The stripper mirror can only be heated).
The good news is that with a retrofit of these advanced mirrors you can get folding, dimming, keyfob memory and curb monitor all at once. This certainly the route I want to go.
One note on the curb monitor, I'm reading that many users consider it not helpful because the tilting is not far enough down to see the curb. For this an additional (not so standard) coding is possible. (see the BMW coding website for details)
      07-18-2012, 03:33 AM   #31
BPMSport
BPMSport's Avatar
3388
Drives: Harrop M3 / F10 M5 / F82 M4
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
Originally Posted by PapaZoo View Post
Hey guys
Attachment 722312
Thanks
Try making sure that your setting in the com port properties has the latency timer set at 1 - default setting is 16 and it will cause that error.
Hope this helps. Corner delete looks really good on a 1 series imo.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
      07-18-2012, 11:47 AM   #32
octainejunkee
octainejunkee's Avatar
25
Drives: M3 f80 Comp, MPE, stage 1
turning the seat belt beep off would make the first three mins of my daily drive alot less beepy lol.
      07-18-2012, 05:35 PM   #33
UsualSuspect
Lieutenant General ***
UsualSuspect's Avatar
61
Drives: this way and that way...
Hey guys
Attachment 722312
Thanks
I seen people get that before and it was because of an incorrect installation. NCS is very sensitive. So try to install it the software and made sure you have a good copy of NCS and EDIABAS. That should fix it.
Everyone has a photographic memory, some just don't have film.
      07-19-2012, 07:05 AM   #34
JimD
JimD's Avatar
369
Drives: 128i convertible
Here's a link to a cable that I and other successfully use. It goes out of stock sometimes but when I copied it they had some:
http://www.one-stop-electronics.com/shop/
People ask a lot about cheaper cables and some may work. I would watch out if they do not have a liberal return policy and if they say the same cable will code all bimmers. The older models need a different pin arrangement so the above link includes an adapter. It is a high quality cable but isn't the cheapest you can find.
The error could be because you need to update your software.
You probably have the digital speedometer in your little digital display (as an option along with mpg and other info), I had to add it to my e88. Is your speedometer inaccurate like the analog? If so, this code may fix it, it is in Kombi in mine:
BC_DIGITAL_V_KORREKTUR
If you do not care for the warning gong when the temperature gets close to freezing, you may want to change this setting, also in Kombi for me:
CC_TEMPERATURWARNUNG
There is another website dedicated to coding you may want to check out: b m w c o d i n g.com (eliminate the spaces).
Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
      07-19-2012, 07:11 AM   #35
JimD
JimD's Avatar
369
The general coding process is to connect the cable to your laptop and the OBDII port of your car (drivers side footwell in my e88), run INPA to be sure you have a connection (requires turning the car "on" but not running), then run NCSExpert to do the actual changes. The process is not very logical and involves multiple steps that must be done exactly correctly. Attention to detail is required. It is possible to mess things up and make your car do things you really did not want. If you backup your module first, however, you can always reset to the way you found it. There is a good tutorial that I followed as close as possible the first time (the instruction is to add the digital speedometer which is in a different software module for me) and I follow steps 50 and up when making changes now. It only takes 5 minutes or so to make a change but if you do not follow the steps just right the least thing that will happen is it won't work. If you are good with computers and following instructions you should not have too much difficulty - possibly none.
There's a good thread in the DIY area called "coding success" you may also want to review if you like this subject.
Another thing you can do with the cable and software is to tell your car you put in a new battery. I am not at that point yet but that one thing will pay for your investment in the cable and software.
Jim
      07-19-2012, 04:40 PM   #36
PapaZoo
I actually have coded quite a few different cars including:
2009 M3
2008 128 convert
2008 335xi
And i have never had any problems. i updated EDIBAS to 7.2.0 and still no luck. I also reinstalled NCS last night and i still get the same error. I just dont know what else to do.
      07-19-2012, 06:19 PM   #37
Artemis
Moderator
Artemis's Avatar
29655
Drives: BMW M2 Competition
On two occasions, for an unknown reason, my doors unlocked whilst driving. Nothing coded, so probably a glitch. I don't mind, as long as the airbags do not deploy just for fun.
///M is art Artemis
      07-19-2012, 06:28 PM   #38
Artemis
Moderator
Artemis's Avatar
29655
Buckle the seat belt before taking place on the seat (if you don't mind the seat belt itching your back + taking the risk of driving without seat belt protection).
Familiar situation: the passenger wants to take something from the backseat or help the child out with something, unbuckles and there's the beep. If you want to keep rolling: let the passenger buckle the seat belt again to fool the system. Not safe though.
///M is art Artemis
      07-20-2012, 07:24 AM   #39
bmw1mc
bmw1mc's Avatar
Australia
20
Drives: BMW 1M Coupe
Originally Posted by robertm
I understood the following from above:
Hi, I just got my car on 10/27.
Happy
      07-20-2012, 10:07 AM   #40
JimD
JimD's Avatar
369
PapaZoo,
There is a really long thread on the other website about NCS errors. Did you try searching it for the one you are experiencing. I hate the amount of time it takes to look through those long threads but I've found useful information doing it. Good Luck.
Jim
      04-10-2013, 04:34 AM   #41
eeghie
Kind of a big deal
301
Trouble detecting the 1MDSC module
so far so good on various parameter settings and VO retrofits interior auto dimming mirror $431, Alarm $302 and passenger airbag deactivation switch $470.
However when either reading the 1MDSC module or when coding the whole car, I get an error saying ".. Cannot communicate with 1MDSC module..."
Can someone who has either successfully interfaced with the 1MDSC module specifically or who has no errors when coding the whole car please reply with their SGdaten, EDIABAS version and cable details?
THX!
      04-17-2013, 05:12 PM   #42
eeghie
Kind of a big deal
301
THX!
Figured it out, thx to gracious help from Mike Benvo@BPMSPORT.com; V46.3 Daten work fine with the M1DSC module, my problem was that to code this particular module, the ignition has to be on!
      05-21-2013, 05:52 AM   #43
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Can you read and post your 1MDSC .TRC file?
      10-17-2015, 06:58 AM   #44
Nagata-San
Homyseed
Nagata-San's Avatar
Switzerland
69
Drives: '11 BMW 1M AW
Installed RECARO PP, have the passenger seat code + airbag code.
Any coding way ?
NOW: '11 BMW 1M AW "Nabila"
PREVIOUS: '09 BMW 335i DKG (DCT) "never too big"
BEFORE:'09 BMW 135i F1 Sauber Edition 120/135
Team Homyseed
1addicts
