04-03-2013, 06:13 PM | #3 |
289
Rep 1,075
Ouch! let me check mine! Hope they deal with it!
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT |
04-03-2013, 06:33 PM | #4 |
651
Rep 4,323
Normal man...
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
04-03-2013, 06:48 PM | #5 |
15
Rep 606
04-03-2013, 07:03 PM | #6 | |
1591
Rep 4,553
Then that will only get you a year or two before the paint will likely begin to fail and rust will resume. Only solution is to replace with aftermarket rotors made of better quality metals. Good luck with that!
2023 840GC | 2021 740i | 2019 X3
04-03-2013, 07:10 PM | #7 | |
15
Rep 606
04-04-2013, 07:23 AM | #9 |
Rep 23
Took it too the dealership and indeed seems to be 'normal'. They made the same suggestions as mentioned here.
Oh and a story about nature pollutant paint being too harmfull for use in the factory.........blah,blah,blah........ |
04-07-2013, 11:55 PM | #10 | |
BimmerPost Supporting Vendor
171
Rep 1,397
don't know about the states but in canada oil based car paint is prohibited due to the "effects on the environment". thats why if you look at your car's paint its dimpled now instead of nice and flat on pre 2005 cars. |
04-08-2013, 12:07 AM | #11 |
17
Rep 344
The same happens down south (Texas) as well, just not as bad. I was told it was normal as well, and from reading the boards, it seems to be normal across all bimmers.
Unfortunate that they do not coat these pieces since a lot of rims have wide gaps between the spokes. Especially if they are selling $4-$7k rims mostly for looks. |
04-12-2013, 02:20 PM | #13 |
18
Rep 195
This happens to ALL CARS. All of them. Unless the hubs are aluminum. When exposed metal parts go through heat cycling, they attract moisture. This is normal. Find a real issue...
04-25-2013, 04:31 AM | #15 | |
Rep 16
I think spending tens of thousands on what is supposed to be a prestigious car and seeing rusty hubs spoiling the look is a real issue. Perhaps symptomatic of keeping prices within reason by cutting back on the integrity of materials or finishing processes? |
05-20-2013, 03:33 PM | #16 | |
Rep 17
Rusty Brake And Hub Parts
the quality of the parts are no better than ford/gm, the only solution would be to coat them with a good quality brake calipar paint when the car is new, but it should not necessary on a car costing this much! and i have to say that the paint quality in general is poor for a prestigious brand like BMW. I am now in a 2013 330d as the first one was replaced by BMW UK due to paint issues, and the replacement car is not a lot better than the first one, quite dissapointing really. |
05-25-2013, 07:39 PM | #18 | |
136
Rep 357
best option is zinc coating...
I addition, zinc coating has two other advantages: 1- Discs never rust on the inside, or between the front rotor plates, or from the inside out (happened to me once on a set that accidentally sat 8 hrs in a pool of water (torrential rain) and they crumbled from within in 5 months!) 2- Will never chip or crack like a paint, and not relative to rotor temperature. What is mystifying is why does BMW not do this as standard... I suspect maybe on the higher end M performance.. All the best Last edited by Musashi; 05-25-2013 at 07:44 PM.. Reason: adding pic |
05-25-2013, 07:54 PM | #19 |
136
Rep 357
[QUOTE=Sillhuvet;13801822]This is how mine look without the rims. Some zinkpaste or grease would have been nice in the center. :-(
Attached an old image of a Canadian made KVR zinc coated rotor. At the time the calipers had seized. Rotor had 50 000 kms and two winters- note- NO RUST on the hub. With the new calipers the rotor surface was again shiny. |
05-31-2013, 01:18 AM | #21 |
123
Rep 586
maybe you didn't like the old cars and didn't pay attention to the details.
G05 - M Performance roof spoiler
05-31-2013, 10:58 AM | #22 |
Rep 21
