BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Help locating TMAP sensor to install JB Plus
      07-20-2020, 05:31 PM   #1
bmwforme
257
Drives: 2023 X3 M40i
Recently bought a JB Plus piggy-back tuner for my 2020 X1. Fairly sure this is the B46 engine (might be B48, not positive).
Does anyone know where the TMAP sensor is located on this engine?
Page 2 and 3 of their installation guide note "For BMW X1 and MINI B48 models the sensor is under the air tube which must first be removed by removing two 10mm bolts."
I have no idea where said air tube and bolts are, I imagine near the red circle around the charge pipe... Any assistance is appreciated!
NYC
Main: 2023 X3 M40i Brooklyn Grey
Secondary: 2020 X1 xDrive28i M Sport Alpine White
      07-20-2020, 08:03 PM   #2
808X1
80
Drives: F48 X1 M-Sport
[IMG]https://f48.bimmerpost.com/forums/pi...ictureid=76091[/IMG]
The TMAP sensor is located beneath the air snorkels (air intake snorkels) in the front. Remove that and you will see it.
bmwforme257.00
      07-20-2020, 08:10 PM   #3
bmwforme
257
Ended up finding it but yes, that is exactly where it was. Thank you!
Initial reaction to the JB plus... eh Feels like I lost torque lower in the RPMs. Will look for a B46 dyno map later to confirm or deny this.
NYC
      07-20-2020, 10:15 PM   #4
808X1
80
Give it a few miles. Might need some adaptations. I had the JB+. Better than Dinan, but ran into some problems with manifold pressure/TMap sensor error once in a while. Switched to ECU flash and never looked back. Broad power/TQ delivery from 2000 rpm to redline. I think ECU flash is the way to go, in my experience.
      07-25-2020, 08:53 AM   #5
bmwforme
257
Spot on... I'm about 100 miles in at this point but would say after 20-30 miles everything changed.
The power and torque delivery at 2k rpms is incredible compared to stock. Onboard MPG has fallen about 0.5mpg but I attribute that to more spirited driving on my end.
Will say a prayer for my charge pipe but I've read that was mostly squared away on the B48
NYC
      07-25-2020, 12:56 PM   #6
808X1
80
Charge pipe will allow your turbo to spool a bit quicker, thus more responsive during partial throttle acceleration. Not a huge difference compared to software upgrade, but contributes to overall engine performance. I think you will be satisfied with it, but not OMG satisfied
      05-18-2021, 11:14 AM   #7
rice_rocket88
No_Country
298
Drives: E60 F48 F39
No.. keep following to the right under the big Y air dam which you have to take off to get to it.
