BMW M2 Forum > M2 Photos, Videos and Builds > UK - OG M2 road & track
      10-26-2021, 06:55 AM   #89
Sam-R
Sam-R's Avatar
194
Drives: OG M2
Originally Posted by 43%burnt View Post
Who makes the spacer? Works with OEM steering wheel retaining all the controls/air bag? I have the same problem. I would love to have the steering wheel back more with my long legs. Thanks.
spacershop.com
      02-10-2022, 10:25 AM   #90
Sam-R
Sam-R's Avatar
194
Drives: OG M2
Again been a while since an update
Done a Bedford day back in October 21, brake upgrade made the world of difference, so-much-so managed to keep a tuned & mapped M2 comp very honest.... video below of 2 laps
KRF_4189 by Katie Foster, on Flickr
KRF_4196 by Katie Foster, on Flickr
KRF_4249 by Katie Foster, on Flickr
KRF_4426 by Katie Foster, on Flickr
KRF_5156 by Katie Foster, on Flickr
KRF_5159 by Katie Foster, on Flickr
KRF_6660 by Katie Foster, on Flickr
KRF_6779 by Katie Foster, on Flickr
      02-10-2022, 10:50 AM   #91
Sam-R
Sam-R's Avatar
194
Drives: OG M2
Jumping to 2022 after a little break went on a buying and modifying spree
Apex ARC8 18" x 10 & 11"
265 & 295 Nangkang AR1
2016 Recaro SPA seat (so now I've a shape matching pair)
Gold wrapped the intake again using Funk Motorsport foil
Annual Engine and Diff oil service
Custom made a "GTS" style arm rest with genuine alcantara to match
Endless ME22 rear pads & removed backing plate to help with heat
68mm rear studs down from 75mm to save on grams as not running spaces on the rear
Lowered steering column 8mm
Untitled by M2 ClubSport, on Flickr
Just want to modify my front braking cooling ducts a little then get some track days booked in.
      02-15-2022, 11:18 AM   #92
Sam-R
Sam-R's Avatar
194
Drives: OG M2
Messed around with the Mumbury brake ducts, was never happy at how far away that sat from the OEM disc and the AP's are even further out.
Kit came with spacers only for the top fixing and bolted straight to the hub at the bottom and used button head bolts, got hold of some more alloy rod and some long counter sunk bolts to move things closer.
Ended up being around 24mm closer in the end
And chopped them back a little to let more heat excape
Still having a little trouble routing the 2" ducting to it, too many moving parts to get a clean route so it ends up chewing up the piping.
Gold in the bay again, going to get a charge pipe from Hack Engineering as apparently these are a weak spot... will be gold wrapping that too.
Lastly got hold of my dads roof bars off his F34 that were gathering dust in the shed
Part numbers didn't match between saloon and coupe models but thought would give them a go, turns out the front rails are a touch too wide... nothing a little drill and grinder won't fix.
Appreciate 2
dtmurf486.00
      04-19-2022, 07:46 AM   #93
Sam-R
Sam-R's Avatar
194
Drives: OG M2
Some overdue updates again
Snetterton 300 back in March, had kind of fell out of love with Snetterton for no piacular reason, didn't even do any sessions there in 2021 but this last day converted me, had a blast!
Managed a 2:08 which matches the best in my old M3 set on 245 BTCC slicks
KRF_1473 by Track Obsession, on Flickr
KRF_4032 by Track Obsession, on Flickr
KRF_2962 by Track Obsession, on Flickr
KRF_2532 by Track Obsession, on Flickr
      04-20-2022, 06:37 AM   #94
Sam-R
Sam-R's Avatar
194
Drives: OG M2
Bedford GT a week after Snetterton, only signed on for the afternoon as knew lots of people on the day
PR_220312_MSVT_BA_1201 by M2 ClubSport, on Flickr
PR_220312_MSVT_BA_1780 by M2 ClubSport, on Flickr
PR_220312_MSVT_BA_1202 by M2 ClubSport, on Flickr
When the photographer plonks himself on a hairpin its asking for a little slide
PR_220312_MSVT_BA_1742 by M2 ClubSport, on Flickr
      04-20-2022, 07:01 AM   #95
Sam-R
Sam-R's Avatar
194
Drives: OG M2
Ever since getting this car I'd say would never cage it... now look
But I knew if I did it would only be a bolt in half cage, after all I'm not going racing.
An what better to go for than a Pinnacle Motorsport T45 tig welded cage, that all fixings are internal and completely reversible. Also believe saved circa 8kg with the cage compared to rear seats, belts and latches ect.
Supplied and fitted by Swift Performance
Will be audio carpeting the rear when free time allows
Pinnacle design of the cross gussets gives an ideal spot for a camera mount, milled out the centre grove on a Gopro pad and added some hole to cable tie it down too
Lightweight and tidy, just how I like it
View from the camera... annoying to not see the backs of the kevlar Recaro anymore but that's no biggy
Lastly chucked in some BMW wheel badges to the Apex, have never ran these with centre caps before but this is a vibe... will of course remove them for track as they will only pop out and disappear.
Next track day is not till Players Classic at Goodwood on June 18th, although may try squeeze a Donnington day in May if funds allow.
Appreciate 3
dtmurf486.00
specka71.00
      05-04-2022, 03:52 PM   #96
le_cram
le_cram's Avatar
Drives: BMW M2
Originally Posted by Sam-R View Post
April 2020
Now for the update I've been waiting for - KW clubsport 2-way coilvers
Keen eyes will notice these are top mounts for an M4 (& M4 reinforcement plates), in fact the whole kit is for an M4, reason for that is KW only make clubsport coilovers for an M2 in 3-way and they're £1200 more than 2-ways, plus I would have only gotten very confused with high and low speed adjustments and just didn't think it was needed for a road car.
M2 being exactly the same subframes and arms ect from an M4 means the kit is a straight fit
Going back to what I said a moment ago that the M4 suspension was a straight fit, that wasn't 100% true... I loose my factory strut brace as they bolt directly to the top mounts and not the strut towers, I couldn't live with that and another blessing of the M4 kit is that I can run the fancy carbon strut brace.
Really enjoyed reading the build so far. Thanks for that!
You made me choose the M4 2way now. Will order tomorrow, but prob without the s55 brace.
How big is the difference for you stepping up from 9,5/10,5 to 10/11? Thinking of running a Trofeo square with either 9,5 or 10.
      05-05-2022, 06:05 AM   #97
Sam-R
Sam-R's Avatar
194
Drives: OG M2
Unless you really want to I'd always go staggered over square. But if you do I'd go 10" otherwise you're making it narrower at the back than stock.
      05-05-2022, 06:14 AM   #98
Sam-R
Sam-R's Avatar
194
Drives: OG M2
Spent the Bank Holiday Monday doing a job that I'd been meaning to do for a while.
Putting a finer grill behind the factory grills to stop stone strikes. Know this is a common problem as it happened to my mate on his first track day, so think I've been on borrowed time.
Managed to hide pretty much all of the cable tie fixing.
Few people have said keep an eye on temps, luckily have my AK motion gauge/screen that has all live temps and records peak.
At Donington this Monday so we'll see.
M1500Z426.00
      05-05-2022, 09:37 AM   #99
M1500Z
M1500Z's Avatar
426
Drives: a white BMW
I need to follow in your footsteps with the mesh—I have collected my fair share of rubber balls/debris. In one instance, something even hit the side hexagon plastics hard enough to break one.
Question for ya on swapping from Protrack to Apex—was this for aesthetics reasons or something else? I've wanted a set but we can't get them [affordably] in the US. They seem to be excellent for the price and have a great touring car look.
      05-06-2022, 06:59 AM   #100
Sam-R
Sam-R's Avatar
194
Drives: OG M2
Always had ARC8 on my E46M so when they came out with 11" rears I had to go for a set.
Nothing against the Protracks, very good wheel for the money, they have become the go-to wheel over here.
M1500Z426.00
      05-06-2022, 11:16 AM   #101
M1500Z
M1500Z's Avatar
426
Drives: a white BMW
Appreciate that. Maybe some day they'll get a US distributor and I can pick up a set for street/rain use. Last I chatted with them, they said they could barely hold onto the demand in the EU market—good for them.
Love the build—I feel we're on similar paths. Never give up the chrome.
      05-08-2022, 02:43 PM   #102
le_cram
le_cram's Avatar
Drives: BMW M2
I settled for 10" w 265 trofeos. How did the car handle for you w a square setup? Because for me the regular staggered is giving me too much understeer on Nordschleife.
      05-23-2022, 02:55 PM   #103
cesarortiz23
cesarortiz23's Avatar
325
Drives: bmw m2 lci
whats the offset on these specific wheels i want to purchase this specific wheel spec
bmw m2
      05-23-2022, 08:48 PM   #104
///393
///393's Avatar
830
Drives: X6
This is all just so bad ass. Great thread. Great build. Enjoy in good health.
      09-22-2022, 08:02 AM   #105
Sam-R
Sam-R's Avatar
194
Drives: OG M2
After my 3 year journey with the M2 I got bored.
Wanted to get back to a more analog thrill and something I wouldn't burn through a set of tyres in two track days, so I put the M2 back to stock and moved it on
It's replacement is a 1995 BMW E36 "M3" S50B30
Will start another thread for the build.
      09-23-2022, 01:05 PM   #106
WedgeSalad
307
Drives: 2018 F87 M2
One of my favorite builds! Sad to see it go, but there is no denying that gorgeous e36!
      09-23-2022, 09:55 PM   #107
gphung
194
Drives: 2018 M2 LBB - 6MT
2018 BMW M2  [0.00]
Damn, loved your build. Will follow your E36 build without question, hope you enjoy it!
      12-28-2023, 06:16 PM   #108
BAPETRACK
Drives: BMW F87 M2 COMPETITION
April 2020
[IMG]https://live.staticflickr.com/65535/49772951493_bdc6638a85_b.jpg[/IMG]Untitled by M2 ClubSport, on Flickr
[IMG]https://live.staticflickr.com/65535/49773505016_7811cf9ae7_b.jpg[/IMG]Untitled by M2 ClubSport, on Flickr
[IMG]https://live.staticflickr.com/65535/49772988323_370bbe427d_b.jpg[/IMG]Untitled by M2 ClubSport, on Flickr
Had a trail fit of some 18s I've still got in the garage with some racing wets on - 18x10 et25
[IMG]https://live.staticflickr.com/65535/49772979293_f49ccd0c02_b.jpg[/IMG]Untitled by M2 ClubSport, on Flickr
Had to remove the caliper as these 18s no way near clear the [...]
Sam,
Would you mind sharing damping/rebond settings that you are running for KW cs 2 way?
m2
