09-27-2021, 11:16 PM | #23 |
3634
Rep 875
Drives: ///M2
AFE open lid intake >>>. Only $100-150 more than the burger & it's larger in both the pipe & the filter, comes with a box that keeps heat away from the filter but is still open up top to let some sound come out.
In terms of sounds, it's not even close. AFE sounds night and day better and makes a variety of noises that the burger wouldn't. I've had both & I would pay double for the AFE now over the burger.
N54 135i 6MT (FBO, JB4 reflash, E30) sold
E90 M3 DCT (FBO, tuned) sold Current: Performance Edition M2 6MT (FBO, ethanol tuned by Bend Calibration/Ecutek) |
470MR104.00 |
09-28-2021, 12:21 AM | #24 |
7252
Rep 7,429
I would only get the cts intake if I were to get an intake at all, because that is the only one guaranteed not to have maf sensor issues.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
09-28-2021, 10:45 AM | #25 | |
2283
Rep 4,146
Mods: Yes.
09-28-2021, 12:22 PM | #26 | ||
3634
Rep 875
Drives: ///M2
Also, if this was the case, wouldn't the stock air box be a problem then? It would seem to me to be even worse because it's completely closed off.
09-28-2021, 12:28 PM | #27 | |
2283
Rep 4,146
Mods: Yes.
10-06-2021, 01:20 PM | #28 | |
a coffee drinker
96
Rep 162
FWIW, I inherited the Eventuri intake. No codes thrown on the stock tune, using the Dinan Stage 4 piggyback tune (inherited), or the Carbahn Stage 2 tune. Big turbo and MPE installed (inherited). I added the air scoop and changed to the V2 cone filter (because why not throw good money after bad ;-) ). No codes. Spirited driving. Perhaps "guaranteed" is a bit too strong a description. Least likely? I do not know. In theory, a poorly designed intake per the MAF sensor could see either an increase or decrease in performance. In other words, the wrong signal is an input to a model that makes adjustments to fueling, etc. To the point, I figured the Eventuri intake was working as expected before adding the air scoop. Ideally, there is more cold air intake (!) with the source being outside the engine bay. Looks good. Sound sort of amusing (to me). I would guess the complete new current kit offers measurable gains sans codes. So ... Eventuri has been reliable for me. CTS is apparently reliable. Some other options are probably legit too. Nobody should be surprised if there are some intakes that are slammed together and sold which do not properly funnel the intake past the MAF sensor. |
10-06-2021, 02:07 PM | #29 | |
7252
Rep 7,429
Guaranteed, youre right might be a bit strong (awe used to actually guarantee no CEL or your money back iirc, I had their carbon intake on my m235i) but least likely would be accurate, since there hasn't been a single report with this intake causing issues. Also once you go WOT the car switches to speed density so it doesn't care about the maf sensors readings. IIRC the maf sensor is for idle and part throttle. Oneore thing, some cars are more sensitive to intake than others, especially when it gets cold outside and air density increases. I've seen some cars fail to start due to a large rpm stumble and stall.
02-28-2022, 12:06 PM | #30 |
2283
Rep 4,146
Just updating this - I previously had the Stock M2 lower box with the Evolve scoop and AFE filter. All was well until I cleaned my filter and reinstalled it. The car was never the same since: Cold starts were rougher, and made the car undrivable for almost a minute after starting, if you did it would buck and jerk violently.
I thought this was intake related, so I tried cleaning the MAF with little success. XutvJet actually stated this happened to him, so maybe residual water damaged the MAF or there is a leak? I since changed to the CTS intake (more on that in a second) to see if that helped the MAF readings. Same issue with the CTS intake - it was jerky on start up and still cut out on WOT multiple gear runs. I opened up my code reader (MHD) and reset the adaptations for the MAF, fuel trims and idle, and wouldn't you know it, it actually worked. The car started up naturally, and settled to a nice idle and I was able to pull it out of the garage with no strange behavior. Problem: Rough cold start/Jerky Cold start throttle Solution: Cleaned MAF and reset MAF, idle and fuel trim adaptations. But on to the CTS intake - Perfect startup, sharper throttle response, more noise and yes, more power. Noticeable bump in torque, more power throughout the rev range.
Mods: Yes.
iam2slow78.50 |
02-28-2022, 12:49 PM | #31 | |
7252
Rep 7,429
I suspect the reason is the car is pushing harder to find and learn the limits of timing advance with the fuel in use.
02-28-2022, 01:06 PM | #32 | |
2283
Rep 4,146
Mods: Yes.
02-28-2022, 01:11 PM | #33 | |
7252
Rep 7,429
I'm still in the camp of stock intake, as it was well thought out by BMW and has a built in venturi generating taper. I still really doubt there is a big gain with an intake, hence why most tuners still run stock intakes on these cars. I guess I'll still be skeptical until I see before and after results with the stock intake being of an mppk spec/m2 lower housing and non charcoal filter.
02-28-2022, 06:15 PM | #34 | |
2283
Rep 4,146
The CTS offers more torque, and it's immediately noticeable on tip in throttle. I have a manual so throttle modulations are a lot easier with more toque. Earth shattering? No - but it's noticeable. I Think I've done everything possible to open up the intake and lower the WDGC. Hopefully it gives me some extra headroom.
Mods: Yes.
02-28-2022, 10:45 PM | #35 | |
BimmerPost Supporting Vendor
24199
Rep 190,807
here is a dyno from BMS with before and after, im sure the CTS intake nets similar gains
AmuroRay2282.50 |
02-28-2022, 10:51 PM | #36 | |
7252
Rep 7,429
Intake manufacturers generally do this to increase power gains. From what I have seen in the past on a different forum, users have run with no air box and just a turbo inlet and have seen no gains, and this was with a JB4 so it shouldn't be fully load tuning based anymore. I have also seen an m2 with the factory air box and no filter showing no gains. So there's that too. I am keen to see a proper MPPK air box and non charcoal oem filter vs. an aftermarket intake - same car, same tune, same day. That'll make me believe that there is a gain.
nioh_lbbm21716.50 |
02-28-2022, 10:54 PM | #37 | |
24199
Rep 190,807
F87source7251.50 |
03-01-2022, 11:30 AM | #38 |
2283
Rep 4,146
Of course an open intake is going to make power over stock, it's got more surface area for the filter and because it's not in a box, and it should have less pressure drop over the surface. Versus the stock F22/F30 airbox, the M2 box is actually measurably less restrictive because of it's additional opening. Objectively, it was a few % difference in WGDC, subjectively, the car drove better.
These effects are more noticeable if you have an aftermarket inlet (which in itself added a bit more power at top end, and offered a lower WGDC) I switched back from the M2/AFE to the stock F22/AFE. On the stock intake box with drop in filter, the was more lag which required me to be in SPORT/+ to get the same throttle response. I also noticed less power, which required more throttle input to modulate the clutch from take off and just an overall weaker feeling throughout the rev range. Again, these effects are more noticeable if you have an aftermarket inlet (which in itself added a bit more power at top end, and offered a lower WGDC) thejeremyman9 Intakes have made power on BMWs for years, I'm not sure why this is a "PROVE IT" situation. Here is Bimmerworld's independent dyno of the Injen open intake on the M2:
Mods: Yes.
03-01-2022, 05:35 PM | #39 | |
7252
Rep 7,429
Next you can't generalize all intakes are proven to make power on bmws. You need to consider filter size because not all coned filters have the indent at the top which reduces filter surface area, next some closed box intakes have a smaller inlet size than even the mppk bottom housing. But it is good to see conclusive proof...
03-01-2022, 07:30 PM | #40 | |
2283
Rep 4,146
Like I said before, the stock airbox and other closed box units are only pulling the air through the front inlet, which just seems counter productive. But we've been seeing these intakes (tube + filter) make power on cars for years - the N54 was all about DCI, the BMS made power on the early N55s and even F series, this isn't a surprising result.
Mods: Yes.
03-01-2022, 07:41 PM | #41 |
378
Rep 348
I really enjoy seeing you two post. Always fun to read.
Y’all both know you can see 5whp variations just dynoing a car repeatedly. Same day, same conditions, etc. I’m not saying what you’re describing as your experience is made up, or placebo… But I am still ambivalent on the value of changing the intake on these cars. I notice a minor difference in power between a 80 degree day and a 55 degree day. If I want a real power increase, I’m spending the money on a HPFP, a turbo upgrade, or a tank of race gas. I have an Eventuri engine cover though, so clearly my decision making is questionable |
03-01-2022, 07:50 PM | #42 | |
2283
Rep 4,146
If you wanted an extra bump in torque, and more sound - I would do it. Mostly manual guys, as some people say it can sound obnoxious with an automatic. I also have an upgraded diverter valve and inlet, which I think are absolute musts regardless of mods, but also help the intake breath more effectively. Like you said, it's just about 5whp at peak (which feels like it carries to redline) is a wash, but the torque is noticeable.
Mods: Yes.
03-01-2022, 07:50 PM | #43 | |
7252
Rep 7,429
Despite having air flowing through your still going to pull some of the hotter air from under the hood and past the radiator, it's not like pulling cool air from an ambient temperature room. I will take a look on n54tech to see if the dyno plot of just the turbo inlet and no air box is still there. That was the one that initiated the point that after market intakes don't produce any more power. It's also why every intake manufacturer compares to the stock f30 intake, to make the gains larger than they are.
03-01-2022, 07:53 PM | #44 | |
2283
Rep 4,146
Mods: Yes.
