08-04-2021, 12:06 PM | #1 |
Rep 9
Interior ambient lighting
Hi
I was wondering if anyone knew if its possible to add the above/below door and dashboard trim ambient lighting. My car didn't come with it and i was hoping to be able to add it |
08-04-2021, 08:10 PM | #2 |
201
Rep 798
need the wiring. if you take the trim off the dashboard, is there pre-existing wiring? mine has the connector - i can't imagine why this isn't standard across all X1s.
08-05-2021, 07:52 AM | #3 |
Rep 9
I haven't checked to be totally honest, if i have the connector then its possible to add it? I would assume the connector is there just the lights not installed
08-05-2021, 11:04 AM | #4 |
678
Rep 910
The dash trim plug was present on my late 2017 car so I just acquired the light strip for the dash (I had trim in doors from factory already). I would check first to see if the wiring is present in which case adding the lighting strips is possible, dash is easiest to check, start by pulling away trim from door towards the centre, if you find loose small 2 pin plug then good to go, parts numbers can be found online. Interestingly footwell light wiring was not present on my car so retrofit was not possible.
12-31-2021, 10:34 AM | #5 | |
Rep 32
What is the part number for the dash trim light? |
MJE60678.00 |
01-02-2022, 02:03 AM | #6 | |
678
Rep 910
https://www.realoem.com/bmw/enUS/select |
01-02-2022, 06:54 AM | #7 | ||||
Rep 32
Thank you. I looked this up, it seems to be the number 16 in attached photo. But 16 seems to be missing from the part list. Any idea if I'm missing anything? https://www.realoem.com/bmw/enUS/sho...16#63319355400 |
01-02-2022, 07:26 AM | #8 | |
678
Rep 910
01-03-2022, 02:21 AM | #9 | |
28
Rep 92
I'm in the same situation, I added the dash ambient lighting no problem (plug was already there), haven't tried the doors yet. |
01-03-2022, 11:41 AM | #11 |
Rep 32
