07-28-2021, 02:07 PM | #1 |
Rep 16
Appearance Modifications
Hey I was wondering if anyone knows if there is pre cut vinyl out there that I could cover all the exterior silver trim with?
Thanks |
07-28-2021, 02:33 PM | #2 |
137
Rep 310
I wouldn't trust a pre-cut option for the silver side skirts. The curves require heat + massaging to lay down flat and cutting the top edge can be tricky. I wrapped mine with a 6 inch roll of gloss black vinyl wrap. It can be DIY'd with patience, heat gun/hair dryer, exacto knife and edging tools. Tape off the adjacent edge to make tucking at the top easier.
As for window trim, I haven't tried to wrap it yet but window pieces may need to be removed to get a clean look. |
07-31-2021, 03:58 PM | #4 | |
80
Rep 139
I had bought this but I had the exact same issue as you see in that 1 star review, it was basically shorter on one end. I pulled it out and matched it on both sides and it was perfect, issue gone... BUT, the adhesive on the piece I removed wouldn't stick again, it was basically hanging. Had to throw it. Other than that, it fit perfectly. It held on in strong rain storms etc. But I got rid of it all and got the trim painted gloss black now Here's a most recent one if you really want it: https://www.aliexpress.com/item/1005002586273381.html Also, this was only $60-$70 when I bought it 1 year ago. |
08-01-2021, 01:39 PM | #5 |
50
Rep 753
Aliexpress also has the glossy black tape that you cover your trim with and use an xacto knife to remove the excess. Or just buy the factory gloss black trim.
08-14-2021, 05:32 PM | #6 |
Rep 3
I'm sure you are already well aware of this option, but I used plastidip on all the chrome accents on my Ram and its durable and attractive if you like matte finish.
