07-27-2021, 08:38 AM | #1 |
Rep 1
F48 X1 CarPlay retrofit
Hi, guys.
My first post here. I'm in the UK So, I bought X1 (2018 model) last year. The car doesn't come with CarPlay preparation. Now I regret buying a car without this feature. I spoke with a local stereo installers and they said they can 'add' CarPlay to my car for around £600. They won't change the unit that comes with the car. Can someone please explain how do they add the CarPlay then? They also confirmed that all the iDrive features would work as normal (Tyre pressure, driver profile etc) Would it cause any issues in the future? Thanks in advance |
07-27-2021, 11:24 AM | #2 |
110
Rep 394
Here's some reference material with the thread discussing it and your options
https://f48.bimmerpost.com/forums/sh....php?t=1588056 |
07-27-2021, 12:27 PM | #3 | |
1786
Rep 3,055
PM sent.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
07-28-2021, 03:11 AM | #4 |
28
Rep 92
£600 is waaaaay too much, the CarPlay boxes cost less than £200 on ebay/aliexpress/etc. and I doubt it takes more than 20 minutes to install.
Even if you get one from Amazon they're still under £300. £400 for installation is a rip off. |
07-28-2021, 12:30 PM | #5 |
1786
Rep 3,055
There's no point in MMI in 2018 if he has WLAN port.
10-11-2021, 10:56 AM | #6 |
Rep 41
I've just fitted a retrofit carplay/android auto in my 2017 Msport. The actual electrical connections are very straightforward, however you have to take apart the entire centre console, in order to free up enough cable to be able to pull out the head unit. In all it took me about 8 hours from start to finish. Quite a tough job. If I were doing it again, I would definitely pay someone, even if it did cost £400 to £600.
I bought the NBT version of this unit: https://bavarian-automotive.co.uk/pr...rplay-retrofit |
10-18-2021, 01:56 PM | #7 | |
28
Rep 92
Cost me about what you paid for the box, got it from AliExpress. Arrived in around 10 days and I installed it myself in under an hour. I really don't see how it took you 8 hours unless you have some sort of strange cable arrangement in your car : |
10-18-2021, 06:00 PM | #8 | ||
12
Rep 36
10-19-2021, 09:40 AM | #9 |
Rep 41
Mine is the MMI box using the existing 8 inch screen. I think the wiring varies in different models. I have the TIS manuals and this said to remove the centre console first. Once I had freed the head unit I found there was only enough slack cable to pull out the head unit half way, so the manual was right. It's easy to test by clipping off the trim, undoing the two screws, and seeing how far the head unit will pull out. Don't force anything though, especially as there are fibre optic cables in there. 8 hours did include a lot of faffing and re-checking manuals, so you could probably get that down considerably if you're a seasoned BMW dismantler!
10-19-2021, 05:09 PM | #10 |
Rep 4
10-22-2021, 12:00 PM | #11 |
15
Rep 71
10-29-2021, 05:27 AM | #12 | |
28
Rep 92
The installation was pretty stright forward, took me about 1/2 hour once I figured out I had to remove the bottom (air con controls) part first by just pulling really hard, which took me around 20-25 minutes |
Idelgado78211.50 |
10-29-2021, 06:47 AM | #13 | ||
12
Rep 36
Hey Siri doesn't work very well. I bought another mic off of Amazon to see if that helps. And I'm also having some issues with my heads up display. I can no longer change the settings and on the main screen the time is also greyed out and I'm trying to decide how much of deal breaker that is for the price. |
10-29-2021, 08:54 AM | #14 |
28
Rep 92
I think (if you haven't already) you may need to transfer the optical wires from the original harness to the new harness which inserts into the back of the radio.
I had to do this as my trip/mileage/fuel consumption were not working on the screen after installation. |
Idelgado78211.50 |
10-29-2021, 09:00 PM | #15 |
12
Rep 36
I thought I did but maybe it's not secure enough. I definitely removed it from the stock oem harness. I'll have to pull the entire unit out again and double check it.
My trip, fuel, etc is also not working. Thanks for the feedback! |
10-31-2021, 08:09 AM | #16 |
15
Rep 71
Definitely need to carry optical wires. This bus is the MOST, and it is needed to exchange data with the dashboard.
Idelgado78211.50 |
10-31-2021, 08:19 AM | #17 | |
12
Rep 36
Remove it from the original harness to the new one, however maybe they aren't snapped in all the way because I'm not getting any of that data. So it's one of two things. The unit i bought is defective and they have something not coded wired on their end OR does it make a difference of the spot of where you put the optical cable? I noticed there two spots and not sure if that could make a difference in getting that data to show up. |
11-03-2021, 06:34 PM | #19 | ||
28
Rep 92
It should go in the same place it was in the original harness. There's most probably nothing leading to the other empty slot. |
11-04-2021, 10:26 AM | #20 |
12
Rep 36
Well I took the car apart (literally removed the center console OUT of the car to access the bundle for the harnesses that go to the back of the head unit to get more slack) and I was wrong and didn't remove the fiber optic cable. I swapped it to the new harness and now it's all showing up again.
Thank you to everyone who helped and gave suggestions. |
11-11-2021, 05:14 AM | #22 |
117
Rep 212
Since my X1 F48 LCI has Apple CarPlay as standard equipment I was wondering if there is a cheap module available just for a rear view camera.
My BMWs
02/2017 - 10/2019: X1 F48 18i sDrive X-Line Platinum Silver with Android 10,25 Aftermarket Screen 11/2019 - Present: X1 F48 LCI 18i sDrive Connected Advanced Mineral White |
