BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) How do I get the foglights to come on automatically with the headlights?
      06-22-2021, 05:04 PM   #1
xnick101
648
Drives: 2020 BMW M340i RWD
2020 BMW M340i  [0.00]
Does anyone know how to automatically get the foglights to come on with the headlights on a 2017 Bmw X1? I have to manually click the foglight button for them to turn on. I want them to come on with my normal headlamps.
2014 BMW 335i M-Sport - SOLD
2020 BMW M340i
      06-22-2021, 08:21 PM   #2
CnSky
Ireland
329
Drives: BMW 530E 2017
Can't be done.
Not sure if a coding option exists but last time I was in BimmerCode non expert mode I didn't see it.
It's illegal in most European countries including Germany to have them auto on or on when no fog exists so that could explain why.
QUOTE=xnick101;27728486]Does anyone know how to automatically get the foglights to come on with the headlights on a 2017 Bmw X1? I have to manually click the foglight button for them to turn on. I want them to come on with my normal headlamps.[/QUOTE]
      06-22-2021, 09:05 PM   #3
Xorbitman
47
Drives: 2018 BMW X1
In most states and most provinces in Canada too. Technically you're not supposed to use them unless the weather is bad.
      06-23-2021, 01:45 PM   #4
pfdaxe
22
Drives: 2017 BMW X1 xDrive28i M Sport
I don't have them come on automatically with headlights, but I did code them to remain on with high beams and to turn them on without turning on the headlights. I also installed LED bulbs that match the LED headlights perfectly
      06-23-2021, 04:42 PM   #5
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Same in the UK. In fact, in the UK the foglights are used as auxiliary lights when travelling at low speed around tight corners to give additional illumination.
For instance, if you going around a tight left-hand bend the left-hand one only illuminates. Once the car is straightened up, the fog light that has functioned turns off automatically. This only happens when the main lights are switched on.
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      06-24-2021, 02:53 PM   #6
xnick101
648
This was the plan. Get LED bulbs to match the headlights. Gives extra light. But want it to come on at the same time as the headlights.
2020 BMW M340i
      06-24-2021, 02:54 PM   #7
xnick101
648
Very interesting.
2020 BMW M340i
      06-24-2021, 04:27 PM   #8
oakey46
158
Drives: BMW 2 A/T 220i Lux Auto 1.5
Thats interesting, but the cornering lights on my 2018 X1 are incorporated in the LED headlights, with a small, but effective, additional reflector on the inner corner of each light unit. The (halogen) fog lights don’t come on at all. In fact, I’ve hardly used them anytime. Perhaps the current updated cars LED fog lights are much better.
Last edited by oakey46; 07-11-2021 at 02:55 AM.. Reason: Position of cornering lights updated after trying them at home.
      06-24-2021, 04:35 PM   #9
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Originally Posted by oakey46 View Post
Thats interesting, but the cornering lights on my 2018 X1 are incorporated in the LED headlights, with a small, but effective, additional reflector on the outer extreme of each light unit. The (halogen) fog lights don’t come on at all. In fact, I’ve hardly used them anytime. Perhaps the current updated cars LED fog lights are much better.
You could of course be correct. Mine is a late 2020 LCI M Sport (built 9th September 2020) with the adaptive LEDs and my dealer said on the handover on 30th September it was the fogs that came on during tight cornering. He could have been totally wrong. I was just repeating what he said. It is very difficult to check this out oneself. Mine has the flat LED fogs, not the round ones. I will now have to read the manual.
      06-24-2021, 04:57 PM   #10
oakey46
158
Definitely correct and it’s worth pointing out that not only do the cornering lights come on individually, depending on whether I’m steering left or right, but if for example I’m reversing on my drive when it’s dark, without turning the wheel, both come on simultaneously to give the widest possible front light spread. Also, if I’m driving into my garage, I only have to turn the steering wheel very slightly and the appropriate cornering light will come on.
      06-25-2021, 08:27 AM   #11
xnick101
648
Very cool!
2020 BMW M340i
      06-29-2021, 11:38 AM   #12
AV07
Drives: BMW X1 M-Sport LCI
Thumbs up
Very cool I have had my X1 M-Sport LCI since sept. 2019 and never knew the LED fog lights did that.
      07-04-2021, 12:22 AM   #13
billakos1601
Drives: BWM X1 (f48)
so if i understand correctly there is no way to make the foglights automatically come on when headlights are working.
      07-09-2021, 04:55 PM   #14
xnick101
648
Correct.
2020 BMW M340i
      07-12-2021, 01:17 AM   #15
billakos1601
too bad!!!
thanxs Nick
      07-15-2021, 08:30 PM   #16
bmwforme
257
Drives: 2023 X3 M40i
This was a total nuisance for me as well coming from my old car that had a manual fog light knob I permanently left in the on position
I coded this when I got my car (2020 LCI X1 M Sport) and recoded it again a few months ago after an ECU/iDrive update reset all of my codes
BimmerCode Expert Mode for F48 X1
FEM_BODY 3063 MAPPING _ NEBELSCHEW _ L _ function value 3
FEM_BODY 3063 MAPPING _ NEBELSCHEW _ R _ function value 3
The default for both options is 8 I believe.
After coding this, whenever your headlights are on (not DRL), your fogs will be on. I lifted this from an F30 forum long ago.
I totally love the look! PM me if you have trouble!
NYC
Main: 2023 X3 M40i Brooklyn Grey
Secondary: 2020 X1 xDrive28i M Sport Alpine White
JR_197973.00
      07-16-2021, 12:52 AM   #17
ZZZZ
50
Drives: Z4 3.0i winterbeater
Curious, do the fogs turn off when your high beams are on?
On my e36 and e90 I wired both to only have angel eyes plus fog lights. That's my fave look.
      07-18-2021, 01:21 PM   #18
JR_1979
73
Drives: 335i Coupe
This worked perfectly, thanks for the post!
      07-19-2021, 03:51 PM   #19
pfdaxe
22
I wonder if this works for pre-LCI?
      07-19-2021, 05:55 PM   #20
JR_1979
73
Drives: 335i Coupe
It does
pfdaxe22.00
      07-25-2021, 07:59 PM   #21
pfdaxe
22
Originally Posted by JR_1979 View Post
It does
I tried and this does not work on pre-LCI. I have a 2017. The default is 08, but what it did after setting value to 03 was disable the fogs altogether. They would not come on in any position or pushing the fog button.
      03-30-2022, 12:34 PM   #22
ernest26
Drives: bmw x1
Sorry, I can find FEM_BODY to code the foglight as you mentioned. Im using bimmercode app and Veepeak OBD. Could you tell how you did it
Search this Thread:
Advanced Search
