BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Conversion to LCI front bumper?
      06-30-2020, 03:32 PM   #23
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Headlight coded, the light is awesome now!
JR_197973.00
      06-30-2020, 04:44 PM   #24
Skyline2.0
137
Drives: 2018 BMW X1 xDrive
Looks fresh Prodrive_X!
Are the LCI LED headlights factory BMW ones?
Also, did you go from halogen to LED? And, was it 100% plug and play (minus coding)?
I've been considering upgrading to the full LED factory headlight assembly, but was never sure if any wiring or mounting modifications were needed.
Thanks much.
      07-01-2020, 12:17 AM   #25
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Thanks much.
Led to adaptative led, original bmw.
Old headlights:
iceman7117.00
      07-05-2020, 03:08 PM   #26
BFetter
Drives: BMW X1
The head lights use the same plug and just go in and code for led? Looking to do the same on a 2018 X1 with standard head lights.
      07-07-2020, 01:30 AM   #27
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Yes same plugs.
      07-07-2020, 11:13 AM   #28
victorngcm
No_Country
30
Drives: F48
Yes same plugs.
will the headlight turn according to turning direction?
      07-08-2020, 04:49 PM   #29
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
same as in the m2 that I have no turn, change the light intensity only
      06-02-2021, 05:42 AM   #30
Soney66
Drives: 220i Msport Grey
Cheers all for the comments in this post, I also did the conversion this week! Turned out superb and we are super happy with the new look.
Appreciate 2
      07-02-2021, 10:10 AM   #31
adam_adam
Drives: BMW X1 F48
It looks great. Congratulations!
Are there any problems? What about the fog lights?
Was it difficult to complete and assemble the bumper?
      07-19-2021, 09:26 PM   #32
TWELVEAM
Drives: 2018 X1
In transition of installing the M sport LCI bumper on a 2018.
Wanted to see if Soney66 found an alternative solution for the fog light harness? Or will splicing still need to happen?
      07-26-2021, 12:40 AM   #33
TWELVEAM
Drives: 2018 X1
Finished the conversion this weekend. Took a bit longer than expected with removing some air ducts that didn’t match with the LCI bumper, but it worked out.
      08-28-2021, 12:17 PM   #34
Blackscell
Drives: X1 f48
Hi guys, I am from the Netherlands and came across this post. I am also conversing to the LCI bumper, however, for the fog lights what wires do I need?
I see multiple wires on here, not sure what to get. Could you guys help me out on this one or have a link?
      08-29-2021, 03:45 PM   #35
SDriver18i
SDriver18i's Avatar
No_Country
80
Drives: BMW X1 s18i 2019
Where'd you buy your parts? And did you find a solution for the fog headlights?
      09-07-2021, 04:50 PM   #36
Bongbmw
Drives: BMW x1
Looks great guys. If you don’t mind me asking what does a conversion like that end up costing $$$?
      10-11-2021, 05:00 AM   #37
Blackscell
Drives: X1 f48
No one that can update me on the led fog lights?
      10-14-2021, 04:54 PM   #38
SDriver18i
SDriver18i's Avatar
No_Country
80
These I think, don't know which specifically. I never got a place to buy the bumper so I never got to the conversion. If you do know where to get it, let me know!
https://www.amazon.com/Michigan-Moto...dp/B06Y2KDHK4/
https://www.ebay.com/itm/2-X-880-893.../263023462925?
      11-28-2021, 05:24 AM   #39
Blackscell
Drives: X1 f48
Since there was not much help, let me break it down:
I bought the bumper second hand for 335$ with the LED grills (do not confuse with led light, it's just the holders). Do not buy the bumper empty, since the parts are pretty expensive. I bought mine without the kidney grills and the under grill, because these 2 parts are not that expensive.
Kidney grill: 51138493450 partnr; cost me 70$ from an online shop.
Undergrill:51118075893 partnr; cost around 80$
Led adapter cable from BMW; 6112871864804 partnr cost 50$
Led light: 63178089525, bought second hand for 120$
So as you can see the front bumper cost me around 690$,-
Labor I did myself. The led lights still have to be coded afterwards, but do work.
      12-31-2021, 01:31 AM   #40
SDriver18i
SDriver18i's Avatar
No_Country
80
Please DM me where you bought the front bumper.
Thanks.
      01-16-2022, 02:02 AM   #41
Marioo
Drives: BMW F48
I have late 2018 M sport with LED headlights and wanted to swap for full LED LCI lights. Is this possible without any modifications and coding? Is it worth to add just headlights or to change bumper also to get full LCI look?
      03-25-2022, 12:43 PM   #42
ggiovanno
Indonesia
Drives: F48
where did you get this part from? i've search online with that part code nothing found
      03-25-2022, 06:20 PM   #43
SDriver18i
SDriver18i's Avatar
No_Country
80
The correct part number is this: 61128718648
      03-29-2022, 10:42 AM   #44
ggiovanno
Indonesia
Drives: F48
do i need to buy 2 pcs? cause the led foglight is left and right?
