01-27-2022, 12:49 PM | #1 |
Rep 27
Remove trim f48
Does anyone know how to remove this silver trim from the door of an F48? I have tried to remove it as if it were an E84 but it does not only have staples, it seems that it has screws and that to remove it you have to disassemble the entire panel. |
01-27-2022, 07:43 PM | #2 |
855
Rep 1,552
That sounds about right. You must remove the door panel
I've never removed that piece but the door panel is simple to remove, it's just two screws and the rest is clips. Remove the door pull cover to reveal the two fasteners and then pull panel off. Disconnect wires.or anything else attached to get complete access to door panel off of vehicle. |
01-28-2022, 02:01 AM | #6 | |
Rep 27
I am looking for the connection of ambient lights that the f48 could have in the doors, since it does have it on the dashboard? If you remove your cover from the door, could you tell me if it has it? thank you |
