01-25-2022, 03:39 PM | #1 |
165
Rep 1,059
Carly app error codes reading
Hi guys, I just did some error reading and found the below ( see pictures ). My car is at 94963km. Most of the codes are at the same mileage. Not sure if they something to do with only the ignition on. As for the error with other mileage than 94963km, Im not sure if they are serious or how to clear them. Anyone has any idea if they they need attention? Thank You
PS: excuse the poor quality pics |
01-25-2022, 05:59 PM | #3 |
263
Rep 646
Did you do some coding using Bimmercode? For example, I also have the 8041C3 "lamp mapping failed" after coding some options related to lamps.
Anyway, Carly should give you an option to clean all error levels memory (info, error, persistent). I use Bimmerlink and works in a similar way. You can also use ISTA as Homersbud suggested. Of course, the apps are easier/faster to use. I would clean all errors, drive it a little bit, and then scan it again to see which errors are still present.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
01-26-2022, 06:18 AM | #4 |
165
Rep 1,059
I had some coding done, when I changed my steering wheel to msport with paddles.
Prior to posting these errors I have cleared a lot of errors. The ones I posted came back on the second scan, however the car was not driven at all after first scan. I just did another scan straight away. I will go and see my m8 and have another scan as I have now driven the car a bit. With ISTA, can you guys tell me which cable to get and where to get the software. Wanna get into it. Thank You |
01-26-2022, 10:03 AM | #5 | |
263
Rep 646
To download ISTA, you can go here: https://f48.bimmerpost.com/forums/sh...9&postcount=18. Another user packed everything into a VM (Virtual Machine), so you don't need to worry about configuring everything; just install VMWare Fusion (free license for non-commercial use) to run the VM on your computer. And to connect ISTA to your car, you need an ENET Cable (RJ45 -> ODB2). Something like this: https://www.amazon.com/-/en/Aidixun-.../dp/B08KZVHBLH
pinco000164.50 |
01-26-2022, 02:22 PM | #6 | |
165
Rep 1,059
Thank You so much bud, I will go ahead and see if Ista will throw anything at me |
01-26-2022, 02:37 PM | #7 | |
263
Rep 646
Let me know if you have any questions.
pinco000164.50 |
