01-22-2022, 03:41 PM | #1 |
Rep 52
creaking at front
X1 2016 F48 M Sport Package w/ DDC, xDrive, 19" M alloy wheels
M Sport Suspension Miles 96,000+ Over speed bumps and pot holes there are creaking noise in front both left and right. I think also sometimes in rear area as well. I honestly have had this noise since probably at 21000 miles. Would it be the strut bearing mounts or the struts (and/or springs) themselves? If so, because of the "M Sport Suspension", would the factory struts be Bilstein B8 or B4 or "Touring B4 Plus"? Those are the options I saw at fcpeuro.com -- but all are backordered. Would you recommend also replacing the springs if struts are culprit? Is this the correct part for the "strut bearing mount" AKA "upper plate"? Thank you guys for taking time to answer my questions. |
01-23-2022, 01:06 PM | #2 |
330
Rep 1,028
More than likely your tension strut bushings. Top mounts usually don't cause creaking.
https://www.amazon.com/Forward-Genui.../dp/B084D1WC1J Could be a number of things get an Indy garage to identify the issue usually easy enough on a lift with a crow bar. |
01-25-2022, 09:39 AM | #3 |
Rep 41
Strut top mount creaking is a very common problem on F48s. BMW sell thousands of them a year in UK alone. Had to replace mine at 22,000 miles. Only creaked when turning the wheel at very slow speed (crawl). Didn't creak over bumps. Now I have an occasional knocking sound when I do go over bumps, having it checked out at the next service.
01-25-2022, 04:27 PM | #4 |
Rep 23
I had the Strut mounts replaced due to creaking when turning the steering wheel. But I'm also now hearing creaking noise during bumps. the odd thing is I only hear it when it's cold outside (30 F ) or less. started couple of years ago. But now its getting worse.
01-26-2022, 03:01 PM | #5 |
1289
Rep 1,641
I have the same issue on my f48. It is reasonably noticeable in the cold. I hear nothing on my f30, so it is something different on the f48.
01-27-2022, 10:23 PM | #6 | |
Rep 52
01-27-2022, 10:26 PM | #7 | |
Rep 52
Had same issue in my long gone saab. Will likely replace this as well as the bushing mentioned above. Thanks. |
01-27-2022, 10:27 PM | #8 |
Rep 52
You and Wadadli above only at wheel turn. Mmhhh making me think less of strut mount now.
02-03-2022, 03:25 PM | #10 |
22
Rep 81
Sounds like it could be the BMW TSB:
https://f48.bimmerpost.com/forums/sh....php?t=1453805 https://static.nhtsa.gov/odi/tsbs/20...46949-9999.pdf Last edited by pfdaxe; 02-03-2022 at 03:32 PM.. |
02-09-2022, 08:16 AM | #11 | |
724
Rep 1,756
2016 428ix, r, 2018 430iC, 2018 330it
02-09-2022, 12:19 PM | #12 |
Rep 23
That is correct. i was educated the hard way when i thought a TSB meant covered work. Dealership won that day.
02-09-2022, 12:28 PM | #13 |
263
Rep 647
Same here. I had this problem a couple of years ago and I had to pay for it fully.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
01-09-2023, 08:57 AM | #14 |
Rep 16
Recently picked up a 2017 F48 with the M-sport package. 35k mile car, good service records. I have noticed this too, a "clunking creak" when going over any bump akin to a speedbump, and only when its cold, as it is now in the Chicago area. Even after the car gets warm, it seems to not be noticeable. Only ever on the drivers side.
Strut mounts, control arms? What have people been having success with most? |
02-03-2023, 01:43 PM | #15 |
Rep 16
Does anyone know of an aftermarket upgrade for the upper strut mounts? Seems silly to just buy another one of the part that isn't any good.
