01-25-2022, 08:35 PM | #23 |
Rep 26
01-25-2022, 08:41 PM | #24 | |
Rep 26
I just ordered non-run flats that are getting installed in two days. My husband doesn't think I need to worry about get a donut right away or anytime soon. He says to hold off on that and that he'll give me the air compressor from his Jeep Wrangler for me to keep in my car and he says I should get a fix a flat/plug. He makes it sound so easy but I'm the one that would have to fix it if I wasn't in a cell area where I could call AAA or BMW roadside assistance!! LOL Just how easy is it to fix a flat on the road if I've never done it before? |
01-25-2022, 08:48 PM | #25 | |
Rep 26
01-25-2022, 09:00 PM | #26 |
850
Rep 1,544
I switched to a 235/50-18 Pirelli Scorpion Verde (Volvo Spec) specifically because I did not want to switch to winter tires anymore on the F48. This tire comes on the S60 Cross Country from 2016 and is phenomenal in snow. I drove through two extreme snow condition nights over our passes here in Washington and was simply amazed at how well these tires performed on the Volvo. So much I got them for the F48. This is a upsize tire from stock (225/50-18) but fits nicely in the wheel wells. This tire is also available in a 19" (235/45-19) which I imagine would fit snugly into the F48's wheel wells.
After the snow winter we had here back in December I can gladly say they performed just as good on the F48's X-Drive setup. This is the only tire I can attest to being as close to a snow tire without getting a dedicated snow tire for your vehicle. This tire also performs great in dry and wet conditions and is much more comfortable than the run flats and Pirelli snow tires I used to run on the F48. Get the BMW mobility kit, it has a compressor. This is what I got for our F48. It appears Volvo used a different tire on the 19" setup of the Cross Country. They're calling out Scorpion Zero Asimmetrico NCS as the OE tire for the 19" wheel. Just to clarify. Last edited by knightarmor; 01-25-2022 at 09:07 PM.. |
01-25-2022, 10:10 PM | #27 | |
Rep 26
01-25-2022, 11:50 PM | #28 | |
850
Rep 1,544
Keep in mind this is in a perfect world where the actual number sizes are equal, not all tires are created equal and not all manufacturers make their tires the same exact dimensions as another. For example a michelin in a 235/45-19 may not be the same actual physical size as a Continental 235/45-19. To make things more complicated a certain model of a tire may also be slightly different than another in the same brand. Yes, it's that complicated. The best thing to do is not overthink it when making a selection such as you are trying to do and just roll the dice. Everyone here will have a different opinion on which tire to recommend based on their experiences. Only you will know if you think you made the correct decision once you're out in the wild on your new tires! |
01-26-2022, 06:31 AM | #29 |
1993
Rep 2,799
Drives: F33 430 and F39 M35i
I dunno. I really love the performance of the PAS4S tires but now that winter is here, I should've went with the CrossClimate2s. I never looked at the CrossClimate SUVs. I believe the CrossClimate would do better in our winters. I keep forgetting that I'm not driving a sporty car anymore and consider my X2 M35i the grandma mobile. I got it to cart my dogs and grandkids around.
01-26-2022, 10:35 AM | #30 | |
248
Rep 613
Stock X1 doesn't have much power, but mine is close to 300HP to the wheels, so OEM tires were a disappointment. I lost traction constantly. That's why I changed rims and tires, fitting a 255/40r19 Michelin Pilot Sport 4 (see attached image). And, of course, I lowered it too to improve handling as well. You know, I don't have to worry about snow around here, so ground clearance isn't essential. Talking about clearance, it's all about proportions. If you put a wider tire, you need to narrow the side (%) slightly to keep the same total wheel ratio. It can get trickier when changing rims, but that isn't the case now. And at the same time, here in the forum, you can see multiple configurations of wheels, and you can ask us anything . For example, check this link: https://f48.bimmerpost.com/forums/sh...7&postcount=43. Another user put the same tires you bought but wider (245/40r19) on stock rims, with no issues at all. Oh, BTW, I'm glad you chose the Continental ExtremeContact DWS06. You will love them! And yes, there is a LOT of difference between touring all-season vs. ultra-performance all-season. UP tires are much better. Finally, I strongly advise you to get the donut ASAP. The air compressor may help you if the puncture is really tiny. But if it's bigger, the tire won't hold the air inside, and you will need to replace it.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
01-26-2022, 07:28 PM | #31 | |
Rep 26
chowser511993.00 |
01-27-2022, 10:31 AM | #32 | |
Rep 26
Regarding the spare, I found an already assembled and mounted wheel and tire for a few dollars less than what the dealer quoted me for the wheel and tire before mounting (they will mount for $30). Seems like a good deal and it appears to be oem spare wheel. Is this a good and legit company to order from??? The fully assembled spare tire would just get shipped to my house making it very convenient. I would just need to pick up a jack and wrench. https://www.turnermotorsport.com/BMW...bmw-spare-tire |
01-27-2022, 11:44 AM | #33 |
110
Rep 394
01-27-2022, 11:53 AM | #34 | |
248
Rep 613
Talking about the X1, I think we all agree it's more like a "city car" rather than an off-road truck, hehe. But, you know, it's always a tradeoff. A more off-road truck probably won't give you that luxury and sporty feel. But not everything is lost. For example, if you need more road clearance, you can probably install taller springs to lift it a little more (~30mm) at a very reasonable price (~250 USD). Eibach has some pro-lift kits, but I'm not sure if they are available for the US version of the X1 (F48). Anyway, there should be other providers that offer a lift kit.
01-27-2022, 12:07 PM | #35 |
Rep 26
That’s my plan, as I have both, as long as I’m in an area with cell service which more often than not. I’ll certainly need a space saver spare for the times when I am not in cell range - which happens from time to time as I drive everywhere, over passes and into the mountains.
01-28-2022, 09:35 AM | #36 |
Rep 18
I wish I had Cross Climate 2's for this weekend
Side Note: My son had his GF buy some for her Honda. Those are nice tires...
2018 X1, M Sport, Conv, Estoril Blue
2018 X3, Conv, Premium, White |
01-28-2022, 09:52 AM | #38 | |
65
Rep 244
01-28-2022, 11:02 AM | #39 | |
248
Rep 613
I didn't do a Dyno with the latest modifications, so I guess I should be around 290hp-ish to the wheels. After changing the pipes, I installed a JB4 on top of the ECU tune. At least I can feel much more punch while driving, but maybe I'm wrong, and that won't be reflected in the dyno . Anyway, we are still playing with the setup, and at the same time, waiting for a new aFe intake. I currently have a K&N CAI, which sounds great, but you know, it is soaking hot air, and after a couple of runs, the numbers drop. So, after that, I will go back to the dyno to see the results, using higher octane gasoline too. I have some shots from a previous run when I installed the tune, on stock wheels and stock intake. I'm attaching a picture from the first 3 runs of that day. It was very tricky because it was raining, and it wasn't easy to get full traction. At the end, when everything was dry, we got 277hp to the wheels and 322hp to the crank. My tune was installed directly by a BMW dealer. Which, you know, I'm pretty sure it's basically a JCW tune. Probably the same you can get using Autotuner or similar. But they gave me a great discount, and I didn't lose the warranty. Bottom line, I know I'm close to the limits. The transmission won't give me much more. At the same time, mine is a sDrive, so I lose a lot of traction too. I will probably install a downpipe, only if it doesn't give me trouble with emission regulations.
01-28-2022, 03:22 PM | #40 | |
65
Rep 244
That's amazing that you got a tune without it affecting the warranty. I just got into a M340i last month and I want a tune on it, but I still have 28 months left of warranty remaining. My only option would be a very tame ECU flash from Dinan to have some kind of warranty on the engine.
2016 F48 X1 -> 2020 G20 M340i
01-28-2022, 04:05 PM | #41 | |
248
Rep 613
BTW, did you try talking with the dealer? I mean, probably is going to be costly, but I'm sure they can do it, especially considering the DME lock your M340 surely has. And if they do it, they will keep your warranty.
