01-10-2022, 09:40 AM | #1 |
Rep 26
Tire questions from a tire novice! Please help!
I'm hoping someone here can help me decide how to choose the right tires for my X1 as I know very little about tires and perhaps cars in general. I have a 2018 X1 with the M sport 19" wheel package. I purchased the car pre-owned nearly a year ago.The tires that came with the car are summer performance tires - run flat OEM basically.
It's time for me to buy new tires for a few reasons. I absolutely need all-seasons. These OEMs are not cutting it for me in rain and in colder temps. I do lots of winter activities and I don't feel confident or comfortable taking this thing out to the mountains. I can't get winter tires because I cannot afford to buy a new set of wheels and there is nowhere for me to store them. I'm likely going to stick with run-flats because I honestly don't know what I would do if I was in an area with no cell service and had a tire issue. The run flats give me peace of mind. What I'm basically wondering is this: 1) Does purchasing OEM tires from BMW make a difference in handling/performance of the car? 2) Any recommendations for good all-season run flats for 19" option 225/45/R19 without sacrificing performance? 3)How important is the speed rating? Does that really matter? Thx in advance! |
01-10-2022, 12:20 PM | #2 |
#onelesssubaru
112
Rep 153
1. Don't buy the tires from BMW, go with TireRack or Discount tire
2. You can read the reviews of various tires online. I've been pretty happy with my Bridgestone Potenza S001's 225/45r19 92W. They do well in the PNW, decent on snow and soaked roads. 3. Important, check with the seller or tire shop |
01-10-2022, 01:51 PM | #3 | |
66
Rep 214
How many times have you had a flat? How many times have you had a '2-second flat' (as in not repairable via fix-a-flat or plug kit at place of flat)? In other words are you putting a lot of worry into something that hasn't happened to you & might not ever? Do not buy tires from the dealer unless you have some sort of hook up with them (price match or whatnot) or unless your local alternatives for mounting / balancing are horrid (as in you're afraid the local fly-by-night tire place will damage your wheels & have reason to believe that to be so). The rule of thumb is that non-run-flats out perform run-flats in almost every regard. You're generally going to be sacrificing some performance but if you need that ultimate piece of mind then fine. But then again, are you really pushing your car that hard that you'd notice a performance difference? I'm guessing you're not. What the average driver can & will usually be able to notice is a difference in ride quality & noise. For me, I can't stand run-flats. I panned them in my X5 when I had it & could not have been more happy. I'm counting the days when I can crap-can the run-flats on my X2. Read reviews on tires you might be interested in. Reviews from consumers that is. All-season designation is by nature a compromise. All seasons have to be a jack of all trades. If you live where you get snow & ice & you can't afford separate sets of seasonal tires, then you have to go with all-seasons. Personally I wouldn't compound that fact with lumping run-flats on top of all-seasons but that's just me. I'm totally ok with carrying a can of fix-a-flat & a plug kit. At the risk of jinxing myself I'm going to say I haven't had to use either while running cars without spare tires. I've had nails, bolts, & screws in my tires but never to the point I wasn't either home or was able to get to the tire shop for a patch. To each / his or her own though!
‘22 X2 S-Drive. Running 13mm Wheel Spacers & 255-wide 'go-flat' tires.
Former Owner '11 X5 35d w/Sport Package Former Owner '86 528 |
allwheelsdriven112.00 |
01-10-2022, 02:22 PM | #4 |
Rep 24
To echo what has been said, you do not OEM tires.
I just went through the same process after purchasing an X2 recently. There are only 12 options (all-season, summer, winter) in the 225/45/R19 if you want to stay with run-flats. Unfortunately it is entirely up to you and how you drive. Based on your location, why not get a full winter set (wheels and tires) and then get some summers in a few months? Got my set mounted for $35 compared to $100+ for swapping tires on the same wheels with balancing. The X2 I got has the ProContact TX SSR and I am debating taking them off the stock wheels before the end of the winter as I hated them for the one week I had them on the car before switching to a winter set. The only other all-season run-flat on tire rack are the Cinturato P7 All Seasons. They seem OKAY based on the reviews. https://www.tirerack.com/tires/TireS...=Runflat+Tires I am currently debating staying with the all season ProContact and switching to full summers and going with the P Zero Run Flats PZ4. Take your time and research as many things are weeks and months out due to the state of the world. |
01-10-2022, 03:28 PM | #5 | |
79
Rep 211
Excellent response ! Keep in mind this is a good time to switch to non run flat tires! They are much cheaper and as mentioned preform much better! |
01-11-2022, 03:05 PM | #6 |
#onelesssubaru
112
Rep 153
I'll never forget working with the local dealer on my GF's e46.
"Would you like us to replace the tires, they are at 30% left?" Are you kidding, who buys tires from the dealer? I guess if you are rolling in cash and are running out of pillow cases to put it in... |
01-12-2022, 11:28 AM | #7 | |
Rep 26
01-12-2022, 12:16 PM | #8 | |
263
Rep 646
The second time, I ditch run-flats, and I put a set of Michelin Pilot Sport 4 (summer version, not all-season, we don't have snow around here). Much better grip in all conditions, especially while raining. The downside, of course, is that you need a spare tire. At the same time, after several years, I never had a flat. Take a look at this threat for non-run-flats tires recommendations: https://f48.bimmerpost.com/forums/sh....php?t=1729957 Continental ExtremeContact DWS06 (https://www.tirerack.com/tires/tires...Contact+DWS+06) is a really great choice as an All-Season regular tire (i.e. non-run-flat). I would also recommend fitting a wider tire. For example, if you have OEM 19" wheels, you can put up to a 245/40 tire.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
01-19-2022, 01:29 PM | #9 |
Rep 26
I have been giving this a lot of thought - it seems everyone here always suggest non-run flats over flats. I'm sure most of you here would know what to do in a flat tire situation. LOL I don't really know, other than call AAA unless I'm in an area with no service. That's what makes me nervous - knowing my luck that would happen to me. But..I do have that BMW assistance button on the car - does that actually work via GPS or do I have to be in a cell service area??
Additionally, does anyone here use a space saver spare? Does it fit nicely in that extra bottom compartment and if so, does it little some extra room for smaller items next to it? Is it easy to change the tire with the space Saver? I haven't changed a tire since I was 17 and that was in the 90s with my dad supervising! Lastly, where do you buy a space saver spare kit? Can I just order one from the dealership? |
01-19-2022, 03:23 PM | #10 |
137
Rep 310
oliviahh,
In context of a flat tire situation, I think posing this question on a car forum will invite biased opinions towards non-run flats as there are likely a greater percentage of members that are more mechanically inclined, thus able to do a roadside spare tire change. There are benefits to run flats. One major plus is the ability to continue driving with a specific type of puncture (e.g., on the center tread) under limited conditions and speeds to a safe area. You should definitely consider sticking with run flats if this is a major concern. I was also on run flats until recently, but carried a space saver spare early on as I've had bad experiences with flat tires over the years. I now prepare for the worst. There were complete kits online the last time I searched, but I went the route of buying the BMW spare rim only (part # 36116851507) and got a 135/90R17 Kumho T121 SL tire mounted. It fits well with no clearance issues in the trunk's bottom compartment space. I'm able to stack other slim items (jumper cables, compact jumper pack, etc) on top of the rim. I also have several items in the space around the spare (portable air compressor, tools, scissor jack, first aid kit, small shovel, tire plug kit, etc). From monetary perspective, getting a spare kit through the dealer would be pretty expensive. I was able to cut down on the cost by building my own. For safety reasons, I highly recommend you find a way to secure the spare. A spare wheel thread with more information: https://f48.bimmerpost.com/forums/sh...are+wheel+hole A roadside spare wheel swap for the X1 isn't much different than any other car if you have the right tools. Changing a tire now is likely much the same as it was when you were 17. Main concerns are jacking up the car properly by the designated lift point and being aware the X1 has a lug bolt design, not lug nut. Installation can be a bit trickier trying to balance and line up the wheel while threading the first lug bolt in. |
01-19-2022, 07:13 PM | #11 | |
263
Rep 646
Run-flats are great, but they won't give you everything; there's always a tradeoff. They will give you extra confidence if you have a puncture, but they won't give you full performance, even less if we talk about all-season tires. At the same time, you said it yourself: there aren't a lot of All Season run-flat tires available for 225/45r19. I guess if I wanted to keep run-flats (summer) for 225/45r19, I would go with Pirelli P-Zero PZ4 https://www.tirerack.com/tires/tires...245WR9PZ4XLRFT or Michelin (if available in your size). The PZ4 are the new and improved P-Zeros. The previous P-Zeros wasn't great, but these new ones will handle heavy rain and little snow pretty well. You can see a summary video here: https://www.tirerack.com/tires/tires...um=435YR9PZ4XL And a complete comparison with other summer tires here: https://www.tirerack.com/tires/tests...y.jsp?ttid=269 Did you go to any local tire shop? Perhaps they can give you more information face-to-face.
01-20-2022, 08:26 AM | #12 |
Rep 18
Who mounts them?
When you guys purchase from Tire Rack etc., who do you go too for mounting? Someone who won't damage the rims or over tourque the lug bolts? Thank you
2018 X1, M Sport, Conv, Estoril Blue
2018 X3, Conv, Premium, White |
01-23-2022, 03:42 PM | #13 | |
Rep 26
01-23-2022, 03:46 PM | #14 | |
Rep 26
Any chance you know much about the mobility kit from BMW? I watched a how-to on YouTube via the BMW channel it and it looks like it is able to also temporarily repair a small puncture with just a push of a button. Seems easy enough if I didn't get a complete flat. |
01-23-2022, 07:37 PM | #15 |
137
Rep 310
Main components of my spare setup:
-Spare wheel from BMW (part # 36116851507) -Spare tire from Tire Rack - 135/90R17 Kumho T121 SL -BMW wing screw to secure wheel (part # 07119908728). I believe you'll need to drill a hole through the bottom of the compartment's fiberboard liner. The trickiest part is finding the right spot. You'll need to remove a few screws/plastic rivets to lift up the fiberboard liner and reveal the pre-threaded hole in the metal frame below (~12.75 inches from the front and ~13.5 inches from the passenger side - both measurements taken from inside the compartment area). See attached pic. Use the smallest drill bit possible to first see whether you're lined up correctly before enlarging the hole. If you're off the mark, a few tiny pilot holes should be nearly unnoticeable. -Something to hold the spare wheel down as the wing screw alone won't work. BMW uses a plastic cover (part # 36106857383). I found a random round plastic piece that served the same purpose. -Scissor jack - I got the BMW one. Other members have recommended the Harbor Freight 1.5 ton scissor jack (here: https://www.harborfreight.com/1-1-2-...ack-66907.html), which I would've purchased instead had I done a bit more research first. You should confirm the HF saddle fits in to the X1's jack pad. -Tool to remove the actual lug bolt: (1) 17mm socket (my memory may be off on sizing) + ratchet, or (2) lug wrench. You can get these items at Harbor Freight, Amazon, Walmart, etc. -Wheel stud alignment pin (I got the OEMTOOLS 24233 Wheel Stud Alignment Pin kit, but you obviously don't need so many). I think the thread size is M14x1.25. This item isn't necessary, but makes life easier when swapping. -Portable air compressor - not necessary, but will be essential if your spare is low on air or just need to top off tires. I don't have experience with the BMW mobility kit, but it looks like an expensive version of a tire sealant in an aerosol can (e.g., Fix-A-Flat can). You should be able to fit this along with the spare wheel setup. I don't carry one as I've read the sealant goo is very annoying and difficult to get off once you get the tire replaced/repaired. My alternative to the spare wheel is a tire plug kit. Note that it can be very difficult to plug a tire as the reaming step may require a lot of force. Also, plugging a tire will require the portable air compressor to inflate the tire back up. |
oliviahh5.00 |
01-23-2022, 09:33 PM | #16 |
2025
Rep 2,808
Drives: F33 430 and F39 M35i
I put together a spare tire and jack kit for my x2. I know it won't fit the front over the m brakes so if I get a front flat, I need to put the spare on the rear and move a rear to the front.
I wanted Michelin CrossClimate2 tires but ended up with the Pilot Sport All Season 4 tires. They're awesome! We're in the middle of a snow storm in Ohio and no issues. I always ditch the runflats as soon as I can. |
01-24-2022, 11:44 AM | #17 | |
Rep 18
Why did you opt for the Pilots instead of Cross Climate 2's? Asking because I am looking at the same..Thank you
01-24-2022, 01:34 PM | #18 |
2025
Rep 2,808
It was black friday in the middle of the night and the sale was going to be over. the website wouldn't let me order the crossclimate 2s in 235/45/19 because it wasn't a factory size for my x2 so i ended up just ordering the PSAS4s in 225/45/19. But going forward, I'll probably get the CC2s for my daughter's car when it's due.
dantis4963.50 |
01-25-2022, 09:32 AM | #19 |
Rep 41
I've done about 30,000 miles on Goodyear Vector 4 Season Gen II, which are available in 19". Been very pleased - good grip, long life, excellent in wet and snow. I towed another car up a steep hill on compacted ice with no problem. Also reasonably priced.
01-25-2022, 03:18 PM | #20 |
Rep 26
I’m torn between the Conti DWS 6 Plus and the Michelin Pilot Sport 4S. Does anyone recommend one over the over? I heard Conti is better is snow but the Michelin handles a bit better. I’m really looking for something that gives me a good balance between handling and winter capability in an all-season. I certainly have a tendency yo whip around curves at times so I’ wondering how the Continentals would handle.
01-25-2022, 03:20 PM | #21 | |
Rep 26
01-25-2022, 06:03 PM | #22 |
263
Rep 646
He's talking about another model, the X2, with M-Sport brakes, that are bigger than regular ones. You don't have to worry about that. Your X1 has regular brakes.
