01-02-2022, 03:05 PM | #1 |
27
Rep 156
Drives: 2016 X1 F48 xdrive xline 2.0 d
Boot closer
My electric boot closer doesn't seem to be shutting the boot tight.
I am pretty sure it used to shut the boot and then you could see and hear a motor "pulling" the boot tight. But I can't hear that bit anymore and certainly can't see it being pulled tight. As a result I hear a knocking from the boot lid when going over potholes, speed bumps etc. It must be closed enough that it doesn't light the warning symbol on the dashboard. Anyone any experience of this? |
01-03-2022, 10:39 AM | #2 | |
263
Rep 647
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
01-19-2022, 07:32 AM | #4 |
27
Rep 156
Adjusting them didn't make a difference.
Happened to be parked next to another X1 owner at the weekend and compared boots. His definitely made a noise after the boot initially shut as the boot is pulled slowly closed. Mine used to do that but doesn't anymore. Some googling suggests there is such a thing as a "soft close boot motor" but I can't find anything too specific on it. I guess my first port of call will be to check if it by chance has its own fuse and whether that is ok but would appreciate any advice others may have on this? |
01-19-2022, 07:41 AM | #5 |
202
Rep 799
let me know what you come up with as mine does the same thing but only during cold weather. during spring/summer, it's not noticeable at all but once temps drop here in Chicago, i hear it all the time over bumps.
I'm close to opening the panel and driving with it off over some bumps to see if i can pinpoint. |
01-19-2022, 10:19 AM | #6 | |
263
Rep 647
01-19-2022, 11:27 AM | #7 |
27
Rep 156
Cheers for that. I have seen other diagrams that seem to suggest it comes in two parts, the normal locking mechanism and then the soft closer.
Like in this listing ? https://www.ebay.co.uk/itm/2018-BMW-...-127635-2958-0 |
01-19-2022, 11:47 AM | #8 | |
263
Rep 647
Of course, the critical point here is identifying which part fails to avoid replacing both (if not necessary). Thinking out loud, if the trunk stays close, I would say that the locking is working, and the soft-closing is failing. But I don't know how those pieces interact together .
01-19-2022, 01:19 PM | #9 |
27
Rep 156
Cheers. Yeah I am tempted to think it's the soft close but I believe this has sensors on it which detect when the boot is closed so it may be a sensor needing a repair as opposed to the full part needing looked at or replaced.
You seem to have a lot of diagrams to hand, you don't by chance have any step by step guides on how to remove the inner trim from the boot to access these motors? |
01-19-2022, 02:32 PM | #10 | |
202
Rep 799
01-19-2022, 05:54 PM | #12 | |
263
Rep 647
I searched in the ISTA app, and I'm attaching the manuals on how to disassemble step-by-step the soft closing mechanism and the trunk lock, listing all the other parts you need to remove too. You will find which parts you need to remove first on the top of every file. I attached all of them. The video from bimmerTech is good for reference; I also used it when installing my rearview camera. However, the steps for the X1 are a little different, especially in your case, talking about trunk lock and soft closing disassembly.
01-20-2022, 10:09 AM | #14 |
263
Rep 647
If you don't see attachments in my previous post, probably is because you're accessing by phone. Try doing the same with a laptop, or just change the browser.
01-22-2022, 09:02 AM | #16 |
27
Rep 156
Cheers - can see them on the laptop. Which I should have done before I started!
Yes, I acrually removed all the trim around the glass and interior of the bootlid as per the video and then realised this was pointless as that is now where the locking mechanism was. Thankfully, I was able to put it all back. However as per the attchments above I need to rempove the tail panel trim. Now according to the sheet I just need to "Release expanding rivets (1) from tail panel trim (2). Lift off trim on tail panel (2)." However I cannot work out how to do this - is it just a case of brute force and yank it up or is there an easier way to release these? I have removed the bit of chrome effect trim that sits on top to see if that helped any but it didn't! How do I get this trim off? |
01-22-2022, 09:06 AM | #17 |
27
Rep 156
This is the trim minus the bit of chrome. The two circled bits seem to be the clips but just not sure how to release them?
01-22-2022, 09:12 AM | #18 |
27
Rep 156
Finally for now, on the fuse situation.
The diagram says the following fuses are used for the boot 11, 12, 90, 93, 96, 107. However the fuse diagram with all the numbered fuses only seems to start at number 30 so where are fuses 11 & 12? Finally you will see from the diagram that position 107 is right at the bottom which is out of eyesight and access when accessing through the back of the glovebox. How do I get access to fuse 107? (apologies but photo seems to have posted portrait rather than landscape) |
01-23-2022, 11:33 AM | #19 | ||||
27
Rep 156
01-23-2022, 11:44 AM | #20 | |||||
202
Rep 799
01-23-2022, 04:32 PM | #21 |
27
Rep 156
Ultimately, yes.
I managed to access the lock and soft close and see they were both working. However when the boot was shutting the soft close wasn't kicking in. Although it defied all logic (to me) I then adjusted this closure points and lo and behold the soft closer started to work again! So basically fully turned them clockwise and the soft close didn't kick in. Turned them anti clockwise a couple of turns and the Soft close did kick in. So then it just became trial and error turning them to try and get to the sweetest point for the boot to be locked as tight as possible. |
01-23-2022, 11:49 PM | #22 |
263
Rep 647
I'm glad you solved it! Unfortunately, it was after doing all the disassembling. But at least it was before buying any parts
