BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Who has run a cable through the firewall?
      12-31-2019, 09:40 PM   #1
Rex_Banner
Drives: BMW X1 F48
(2016 f48 X1, LHD) Seeking some advice from anyone who's routed a cable through the firewall. I'm installing an amplifier and need to run the 12v+ from the battery through the firewall and I'm not sure where to find a good spot.
Can someone point me in the right direction?
Thanks
      01-01-2020, 01:06 AM   #2
808X1
80
Drives: F48 X1 M-Sport
There's a hole in the firewall behind the battery near the steering column region covered with a rubber plug. You can access this hole by lifting the hood up, and looking into the top right corner of the hood area and down an opening. There's a rubber plug that can be removed and you can run wires through there.
Appreciate 2
      01-01-2020, 07:28 PM   #3
Rex_Banner
Drives: BMW X1 F48
Thanks very much!
      01-03-2020, 04:44 AM   #4
CFB
Drives: 2020 BMW i3S 120ah
Don't suppose this is the same for a RHD model??
      01-04-2020, 03:18 AM   #5
808X1
80
IIRC, the hole is still on the LHD side, despite you having the RHD. I may be wrong.
      04-20-2020, 05:31 PM   #6
Pdhesi
Drives: 2018 BMW X1
were you able to run the cable through that area? I'm looking to use that plug also but don't know where it is on the inside of the cab
      04-22-2020, 01:07 AM   #7
808X1
80
Yes. The hole will exit under the dash near, above, and to left of the steering column; looking from inside the cabin.
      11-14-2023, 04:46 PM   #8
mrpingu
181
Does someone have a picture of this
      11-28-2023, 04:18 PM   #9
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
RHD. The plug literally shines through if view from the glove compartment fuse box area.
      11-28-2023, 04:58 PM   #10
mrpingu
181
LHD and that one is taken
But found a way (LHD)
Driver side red
Passenger side green
Driver side was predrilled hole in firewall material also, passenger side I had to pike through the firewall material
