09-06-2019, 02:22 PM | #3 |
80
Rep 139
09-06-2019, 03:10 PM | #4 |
94
Rep 287
If you properly coded warm andcold monitoring off, and to bulb type led, then it sounds like the led bulbs are not seated properly in the sockets.
PY21W have offset pins and P21W have straight pins. Did you file or clip off one of the pins from the PY21W led bulb? If not then you're forcing the PY21W led bulb into a P21W socket and is not properly making contact to the base of the socket. The pins on the bulbs are there to hold the bulbs in place. It still needs to be properly seated to the base of the socket. If this doesn't work then you might have damage the socket. |
09-07-2019, 12:43 AM | #5 | |
80
Rep 139
Please read what I posted above before commenting. I already listed everything. Last edited by SDriver18i; 09-07-2019 at 03:44 AM.. |
09-07-2019, 07:50 AM | #7 | |
80
Rep 139
I have an attitude for pointing out that I already did that and its above? Good one. |
09-08-2019, 01:00 PM | #9 |
10
Rep 22
Try to use something like Bimmerlink to detect error codes. It would help.
SDriver18i80.00 |
09-11-2019, 02:15 PM | #10 | |
80
Rep 139
Thanks to Stephan Gauch from Bimmercode! Found out it was a Short Circuit error and that the counter needed to be reset. Gave an error but it reset all and all is good. And if you want to know how to here: Downloaded DEEP OBD > Went to BDC > Edibas Tool > STEUERN_RESET_KURZSCHLUSSABSCHALTUNG and put 0xFE in the Arguements and Click Disconnected. Last edited by SDriver18i; 09-12-2019 at 09:22 AM.. |
