01-27-2018, 03:34 PM | #1 |
191
Rep 453
Drives: 2007 Z4M Coupe
Well now that we've had our X1 for a week I'm already thinking about replacing the stock 18" wheels with some 19's with better offsets. I just think the stock 18's fitment leaves a lot to be desired. My research shows that the selection out there is kind of thin so I've moved into looking at some Audi reps. I like this one in particular from Hartmann. They have some good reviews for reps kind of like VMR. I'm eyeing the 19 x 8.5 ET38. Can anyone chime in on whether these would fit fine. Not looking for the pokey look and I've read in some other threads that an ET40 would give me a flush look. I figured 2 more mm's of offset shouldn't be a deal breaker. Comments?
http://shop.achtuning.com/hartmann-h...di-q5-sq5.aspx |
01-29-2018, 10:35 AM | #2 |
565
Rep 1,092
There is 27mm in the front and 33mm in the back to work with before they will start poking out. So your wheels would be 1 inch wider (so half of that goes on the outside so 13mm wider), then you add another 13mm for the offset (51 minus 38). You get 26mm wider over stock so just about perfect.
I'm a bit worried about the bolt warnings on that website. The Audi uses different bolts (14x1.5 vs 14x1.25) so you can't use them. |
01-29-2018, 10:55 AM | #3 | |
191
Rep 453
I figured actual fitment should be super flush being 26 mm more outboard than stock but I'm worried I won't like the look due to the body tapering inboard as you go down the car effectively looking "pokey". I'm contemplating going with a higher offset like say ET43. Would be nice to see pics of someone with a similar setup but I'm finding wheel fitment interest and information on the X1 is slim at best |
DARKMTTR229.00 |
01-29-2018, 11:15 AM | #4 |
64
Rep 261
Here's all the info you need on the F48 X1's wheel specs..
https://www.wheel-size.com/size/bmw/x1/2017/ You need to match up bolt pattern, center bore (or if your selected wheels have a larger bore..get correct centering rings)...and you need proper lug bolts for the wheels (conical or ball lug bolt seats?) that match the X1' s 14 X 1.25 pitch hub threads....There are websites that will show you dimensions of wheel tire combos to make sure you don't have clearance issues with suspension etc...if you stick with stock tire size and just go for wheels that move the face outward to "flush the face" you don't need to worry about these issues since you'll be increasing the space behind the wheel/tires... |
01-29-2018, 11:27 AM | #5 | |
191
Rep 453
I wish BMW would have stayed with the 5 x 120 bolt pattern as it's severely limiting the after market wheel selection (basically no aftermarket BMW wheel will work). Thank god the bolt pattern and hub bore matches Audi. So just need to get the offsets and bolts right and the Audi wheels should do fine. I know it may be sacrilegious to put an Audi wheel on a BMW but these I believe would look good. |
01-29-2018, 05:09 PM | #6 | |
565
Rep 1,092
View post on imgur.com - stock wheels, bulky tires, 15mm front spacer, 20mm rear spacer. With these tires I can't imagine pushing the wheels out by another 11mm, with normal tires (something like 245 on 8.5 rim) it could work for very aggressive look. There is another wheel/tire thread on this forum and bimmerfest that has some good photos. |
01-30-2018, 09:34 AM | #7 | |
64
Rep 261
coh661191.00 |
01-30-2018, 10:32 AM | #8 |
191
Rep 453
Well after some research i'm thinking inorder to make the Audi wheels work on my X1 i'll need these adapter's for the bolts.
https://www.ti64.com/product-p/6741.htm I could not find bolts anywhere that are 14 x 1.25 R12 Ball seat.....These adapters provide a ball seat conversion and will allow me to use my stock conical seat bolts (14 x 1.25"). i just need to make sure I still have 7 turns on the threads. If not i will just buy longer bolts. Hope this helps anyone else who wants to go with Audi wheels on the X1. |
02-03-2018, 03:57 PM | #9 | |
Rep 1
02-03-2018, 06:54 PM | #10 |
185
Rep 299
We are running some BBS SR's for our winter setup in 18's with an ET of 33. I used to run them on my Audi as well as our Golf. The only thing we had to change out was the centering hub. They do look smaller than the 19's that came on the car, but the ride is so soft, especially with winter rubber.
02-08-2018, 06:52 PM | #11 | |
565
Rep 1,092
