XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 Photos / Videos / Media
Register FAQ Calendar Today's Posts
      02-22-2018, 07:42 PM   #67
KWX1
KWX1's Avatar
25
Drives: X1 Xdrive35i
Originally Posted by Sabander View Post
Hello, New to this forum, just bought a 2012 X1 28i.
After seeing these pictures i'm excited to change out the stock 17's for some of the iconic BMW styles.
Has anyone ever put an 8" wide 17 rim on the x1?
Would this require a spacer?
I'm not sure what the offset is on the rims I'm looking at, but i'm being told either 34 or 40.
Thanks!
2014 X1 Xdrive35i /BMS intake/JB4/ GFB DV/CPE charge pipe/ VRSF downpipe/ Alpina TCU flash
      02-23-2018, 10:08 AM   #68
Sabander
Drives: 2012 e84 X1
I must be missing something. I read the thread four different times. The only ones that reference 17's don't post the et, and the one that does is an et20 which will obviously fit...
Did I miss it? I'm specifically looking for a 17x8 with et40.
      02-25-2018, 08:15 AM   #69
KWX1
KWX1's Avatar
25
17x8 et40 will be fine on the back and should clear the strut in the front. It would be a tight fit in the front depending on the tire width/size. My stock tires were 8" wide et30. I moved to a 8.5" et35. that is about 8mm closer to the stut. A 8" et40 would be be 10mm closer to the strut which I would say there is room for 2 more mm . If you tire width selection bulges past the rim it my rub the strut. A tire wider than 225 could rub the strut.
      02-25-2018, 07:52 PM   #70
blackx1x35
Drives: 2014 X1 xdrive35i
Originally Posted by KWX1 View Post
Wheels: CSL M3 Repros 19x8.5 squared ET35
Tires: 245/40/19
Spacers : Rear, 12mm just to bring flush to top of fender
Clearance: no problem, stock height.
Attachment 1741264
Attachment 1741265
Attachment 1741266
What spoiler is that?
      02-26-2018, 06:21 AM   #71
KWX1
KWX1's Avatar
25
https://www.ebay.com/itm/For-BMW-X1-...JXzTt0&vxp=mtr
      06-17-2018, 10:34 PM   #72
NemoX1
Drives: 2014 X1 xdrive35i msport
Looking for advice on wheel fitment for a spare set. Came off a 2006 bmw 650 19" m wheels. I believe they are 8.5j x 19 et14 front with 245/40/19. 9j x 19 et14 rear with 275/35/19.
My car is a 2014 X1 Xdrive 35i m sport. With factory staggered 8j x 19 et30 with 225/35 front, 9j x 19 et41 with 255/30 rear.
I don't know wheels well. Will these fit easily?
Thanks in advance!
Michael
      06-29-2018, 08:33 AM   #73
jd__m4
jd__m4's Avatar
415
Drives: AY M4
Wheels: Apex EC-7's in anthracite, 19"x8.5" square ET35
Tires: 245/40/19 General G-Max AS05
Spacers : None
Clearance: No issues on stock suspension
      07-04-2018, 09:22 PM   #74
bucketfoot
bucketfoot's Avatar
1078
Drives: 2020 Toyota GT86
Wheels: Black Apex ARC-8's, 17"x9" square ET30
Tires: Bridgestone Potenza RE71R 245/40-17
Spacers : None
This was taken shortly after we had snow, so the car is pretty dirty.
This post sent using 100% recycled electrons.
      07-05-2018, 04:31 PM   #75
bucketfoot
bucketfoot's Avatar
1078
I kind of like the look of that. Just don't know that I'd be willing to spend $200 (when you factor shipping) sight unseen for it.
      10-10-2018, 06:54 PM   #76
Yashvan
Drives: Bmw x1 e84
Hello guys
New to the forum from mauritius island. Got an x1 20d 2012. Picked up some ac schnitzer wheels 18 x 8.5. All 4 wheels are same size.
Should i use same tyre size all around since all wheel are same size?
Would 245/45/18 work thanks
Thanks alot
      10-12-2018, 03:15 PM   #77
Bodie
Drives: 2014 X1 xdrive 28i Xlne
Any Photos?
      10-12-2018, 04:33 PM   #78
Bodie
BMW X1 (E84) Widest Tires?
Formerly and X5 4.8L owner. LOVED the big tires Just purchased a 2014 X1 and wish to run 19" wheels and go wider than the stock 225's. I would be most appreciative for some feedback, advice and photos. Thanks.
      10-15-2018, 12:12 PM   #79
Dalco450
Dalco450's Avatar
84
Drives: X1 M-Sport
Style 230 on X1’s OEM PZero
F: 19x8 ET37
R: 19x9 ET39
      10-15-2018, 05:47 PM   #80
Chicone
28
Drives: 2015 X1 X35i M-SPORT
Originally Posted by Yashvan View Post
Hello guys
Thanks alot
Just wanted to say I needed to refresh my geography, looks absolutely beautiful there...How many X1's on the Island?
-Steve
2015 X1 35i MSport //BMS Intake
      10-16-2018, 06:45 PM   #81
KWX1
KWX1's Avatar
25
Hello guys
Thanks alot
Those will work fine if the rim offset is a ET30 to ET35.
      10-19-2018, 12:30 PM   #82
LevinBR
40
Drives: 2013 BMW X1 xDrive 35i
username - LevinBR
wheels - BMW style 238
size and offset - 18 x 8 et30
spacers - none
tires (size and brand) - 225/45/18 Michelin pilot sport a/s 3+
suspension - Bilstein B6 (HD) with factory springs
clearance - stock, no rub
      10-28-2018, 05:36 PM   #83
100niallsanhour
Drives: E84 x1
2013 X1  [0.00]
X1 E84 2013, 19” vs 20”. I Want more rubber on show
I am tired of the low profile tyre look.
I have 20” inovit wheels with 235/35/20 all round.
They fit like a dream with no rubbing at all.
However i dont like the tyre look.
I tried swapping one tyre to 255/40/20 just to see what happened.
It looked great and filled the arch beautifully, but it rubbed on the front when turning. Did not rub on the back but this was not tested with a full passenger load.
I want to try swapping to 19” with a fatter tyre.
I propose 8.5” up front with 245/40/19
And 9.5” rear with 275/35/19.
Will this fit? Or rub?
      11-21-2018, 10:44 PM   #84
AllEyesOnMe
TeQuiero
AllEyesOnMe's Avatar
85
Drives: BMW M2C
Hey All,
Wondering if anyone here has a staggered setup on their X Drives? I'd like to know what your tire spec is and if you noticed any difference in handling pre/post switch?
And also any problems with the differential, transmission or other components?
Thanks!
      01-01-2019, 05:53 PM   #85
SmithsonianX1
SmithsonianX1's Avatar
Drives: 2015 X1 35i M-Sport
Originally Posted by AllEyesOnMe View Post
Hey All,
Thanks!
I had the same question this week. From what I was able to find, the vast majority of opinions out there are that you’ll overload your center differential with variations in diameter. Not worth it to me. Why not try spacers?
      01-02-2019, 12:09 AM   #86
AllEyesOnMe
TeQuiero
85
Drives: BMW M2C
Spacers won't give the meaty look as opposed to wider wheel combo.
Some X Drive models come with staggered setup from the factory--did you get a chance to look into this?
      01-03-2019, 02:05 PM   #87
mangoango
Drives: Wife & kids crazy
Hey All,
Thanks!
My xdrive came with staggered wheels from the factory. 19x8 & 19x9, 225 40 19 & 255 35 19.
These are the wheels I'm referring to: (not my post)
https://e84.xbimmers.com/forums/show....php?t=1491277
      01-03-2019, 03:40 PM   #88
Let It Rein
ORNGBLD
Let It Rein's Avatar
32
Drives: F80 Sakhir Orange
Found a set of 437Ms in 19x9 29mm / 19x10 40mm. Plan on running 245/35 and 275/30. Can anyone verify that these will work. Thanks.
