BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Headlight switch question?
      06-14-2019, 07:13 PM   #1
GCP
Drives: BMW X2
Hi everyone
Just got my m35i. I just find out the light switch "position 0" will turn on the low beam automatically when dark... which is same function as the "position auto"
is this normal?
      06-14-2019, 10:00 PM   #2
xcelir8bmw
xcelir8bmw's Avatar
402
Drives: 2022 BMW M240ix
Those are DRL kinda. Code it.
      06-15-2019, 12:34 AM   #3
GCP
Drives: BMW X2
DRL will turn on low beam as well ?
not angle eye , 3 amber dots and tail led only?
      06-15-2019, 07:50 PM   #4
Patrick852
Hong Kong
66
Drives: 15 320iED, 18 X2 sDrive20i MSX
DRL should be the ring made up of three lines, not low beam, something wrong with your DRL connection if this is the case.
      06-17-2019, 03:09 PM   #5
rice_rocket88
No_Country
298
Drives: E60 F48 F39
GCP My only assumption is that since you're in canada I believe the law changed 20 years ago that there MUST be DRL on all the time no matter what, so it could be that it is coded that even on option ZERO with your headlight switch that it'll turn on. It could also mean that the low beam then turns on with the sensor when it's dark. You should be able to call the dealer to ask them. Still, I see not much point to actually have your car completely dark... if you want it that way it should be in park and off In fact, I ended up coding my back LEDs to be on with the DRL. I saw an X2 m35i for the first time on the road and didn't like the way the single light was on for the brakes.
      06-17-2019, 09:23 PM   #6
GCP
Drives: BMW X2
thx for the reply....just check with my dealer today and got the answer x2 drl will turn on low beam...
but never mind...just make sure its not a failure...😊
      06-18-2019, 12:29 AM   #7
satz
Australia
336
Drives: 2019 BMW X3 M40i
Might be a Canadian thing?
Downunder when you turn the light switch to '0', only the DRLs remain on (the bright LED around the circumference of the headlights).
But the low beams stay off.
You can switch off the DRLs from the vehicle settings/lights/exterior menu.
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K
Previous: 2009 335i LCI, Bluewater
      06-18-2019, 11:56 PM   #8
GCP
Drives: BMW X2
checked that already....no more drl off option in exterior light setting for x2
      06-20-2019, 12:57 AM   #9
satz
Australia
336
Looks like in 'Canadia' they really want you to have some light at the front
Perhaps you could code it out using Bimmercode?
I used that to activate my rear DRLs so they switched on with fronts (which is all the time in my case)
cheers
      06-20-2019, 12:28 PM   #10
rice_rocket88
No_Country
298
Drives: E60 F48 F39
Again.. why bother messing with the coding to turn it off, when it's illegal to have it off? One thing is for sure you'll get a ticket eventually with it off.
