03-20-2024, 02:39 PM | #1 |
49
Rep 136
Chargepoint home charger issue
I’ve looked and found some stuff that wasn’t definitive so forgive me if it’s on here recently. I’ve had my ‘24 iX50 since August and have been happily using a charge point home flex on a 60a breaker at the max 48a charge. Have gone on trips and charged both level 2 and CCS without issue. Then, suddenly, a month ago the charge point wouldn’t charge anymore. Took me a while to realize since it’s not a daily driver. Plug in and it would connect and show as charging but in a moment would click and stop. Car would show 0 watt power. Tried the included bmw trickle and that works at 1kw which is miserable. I tried a level 2 at a mall nearby and that charged at 7kw so obviously something works. I ended up having the chargepoint RMA and just installed a brand new one with same issue. Tried modifying car amp max and charger output max to no avail.
Anything I saw suggests something messy with the CCU. Has anyone had this issue and has some guidance? |
03-20-2024, 02:57 PM | #2 | |
654
Rep 423
03-20-2024, 03:13 PM | #3 |
49
Rep 136
Windshieldfarmer653.50 |
03-20-2024, 03:21 PM | #4 |
5637
Rep 4,537
Drives: 2022 iX xDrive50, DGM
Have both a hardwired and plug-in ChargePoint Home Flex, operating for about 2 years with no issues. But "installed a brand new one with same issue" sounds like the car or your installation. You didn't mention if hardwired or plug, but based on your info I'm guessing hardwired (48a). In any case, have a qualified electrician inspect your installation ASAP - there's an internal circuit breaker in the unit that will kick off if something is tripping it in your circuit. This is potentially a fire hazard. If that checks out, dealer diagnostics on fault codes in the car.
03-20-2024, 03:27 PM | #5 |
1719
Rep 1,499
Drives: 2023 iX xDrive50
It sounds as if you have the ChargePoint (or car?) set to begin charging at a specific time slot.
Past BMW's
2020 M850i GC | 2020 X5 | 2018 M550i | 2017 X5 | 2014 535d | 2013 X5 | 2007 530i | 2002 X5 | 2000 540i/6 | 1999 M Roadster | 1989 535i | 1984 533i | 1983 533i | 1977 530i |
Paladin15637.00 unfoundnemo1923.00 |
03-20-2024, 04:21 PM | #6 |
5637
Rep 4,537
That would be guess #2 but since no mention of any change in app or schedule.... Very possible though since seen before here - I guess I'm confused by the more-than-one-posts about "my charger/EVSE stopped (because I didn't know I had set a schedule)." Good catch!
03-20-2024, 04:24 PM | #7 |
629
Rep 1,200
ChargePoint were remotely disabling higher amp ratings, (>32A iirc) in order to decrease the chance of a poorly installed wire from the breaker box not being up to the job or a contractor grade socket being used instead of a Hubbell outlet, and hence getting too hot causing a fire hazard. Some owners were having to call the Chargepoint hotline and have a support person manually allow the EVSE to operate at higher amperage once they had determined that the install was ‘safe’.
This doesn’t sound as if this is what you are experiencing however, and as above you need to make sure you don’t have some sort of bizarre schedule set up either in your car, or your at home Chargepoint. Extremely unlikely that you received a second defect EVSE. |
justinguo31745.00 |
03-20-2024, 04:46 PM | #8 |
49
Rep 136
I’ve got a local program that I’m signed up for and the bmw charge forward but both have been bypassed. Something in the electrical line not impossible but it was all done to code by a licensed electrician and permits etc… so not to say it’s not possible that something is wrong but.
03-20-2024, 05:09 PM | #9 |
1152
Rep 1,148
I’ve had something similar happen with my ChargePoint Home Flex, my fix was to turn off the circuit breaker, then turn it back on, wait a minute or two and then plug the car in and it started working fine again. Not sure if you’ve tried that, but worth a shot.
03-20-2024, 08:09 PM | #10 | |
49
Rep 136
Y the car. Both can’t work otherwise I’ve got issues. |
03-21-2024, 07:45 AM | #11 |
162
Rep 131
Ensure all wires are connected inside the ChargePoint, under the front panel. This sounds similar to the issue I had but it was immediately after an electrician installed it and didn’t connect one of the pins.
03-21-2024, 08:19 AM | #12 | |
2525
Rep 1,988
Windshieldfarmer653.50 thebishman629.00 |
03-21-2024, 12:36 PM | #13 |
49
Rep 136
Yeah it was working fine until it stopped with everything looking fine. A replacement unit acting same way so next step have someone charge at my house and try charging at someone’s house on proper amp level 2 ie 16a+
03-21-2024, 12:38 PM | #14 | |
49
Rep 136
03-21-2024, 01:07 PM | #15 |
5637
Rep 4,537
On the flip side, if ChargePoint can determine remotely if something is going on with an EVSE that is potentially unsafe (support quality completely aside - that's more the norm these days), that's totally a good thing. Worth repeating:
03-21-2024, 01:40 PM | #16 |
49
Rep 136
It’s a fine line and a slippery slope but that aside, there should be some way for them to tell me what their unit is showing and it’s not. If it was sending an over or under load and reporting it at least that’s something to tell the electrician. All I’m seeing and they confirm is that the car is taking 0kw
03-21-2024, 05:21 PM | #17 | |
2525
Rep 1,988
Years ago i had a Cisco/Linksys router that I had configured and specifically set the option for auto updates to OFF. I manually updated it when I saw fit and was diligent back then to read up on vulnerabilities and such so that I didn't run an unsecure router. I never allow any remote access to my router as I have zero need for that. One day I needed to tweak some setting when I was home and was surprised to see that the thing updated itself nonetheless and was now requiring me to create an online account on their cloud service in order to configure my own device. I unplugged the internet connection from it and was "allowed" to do the configuration locally instead and the next thing I did was order a replacement router from a different company, added them to my blacklist and threw that one in the trash. |
03-21-2024, 05:48 PM | #18 | |
1386
Rep 948
Drives: ix xDrive50
I could see a scenario where a unit itself detects heat and backs itself down. But a secret override from galactic HQ seem like a bad move on many levels.
2024 iX xDrive50 Phytonic Blue on Mocha with DAPP, Premium, B&W, Ventilated & Radiant Heated Seats, Adaptive Headlights, and Luxury
03-21-2024, 06:07 PM | #19 |
5637
Rep 4,537
I know they can remotely read the unit and detect faults - that's my point. That's a good thing. Notifying the user is also a good thing. In fact, if they detect a fault #2 is mandatory IMO. I'm very much in favor of any technology that keeps my car from catching on fire and my house from burning down. And no one needs my permission or lengthy deliberation to do that. Any other action could be debated, but absent an emergency, see #1 and 2.
03-22-2024, 10:10 AM | #20 | |
629
Rep 1,200
I’m only reporting what I had read on another forum. |
03-22-2024, 10:18 AM | #21 | |
629
Rep 1,200
Have you not only ‘Rebooted’ the CP, but ‘Reset’ it and set it up as a new unit? Have you disabled all timers on the CP and activated Charge Immediately on the BMW app? Good luck getting this sorted; I know it’s frustrating AF when something like this occurs. The WiFi card in my first CP failed about 6 months after install, and I found ChargePoint’s tech response to be pretty damn good. I did have to send them pix of the breaker box and the way it had been installed by my electrician including the internal wires within the CP, but then they sent me a brand new unit that has now worked flawlessly for about 4 years. |
03-22-2024, 01:23 PM | #22 |
629
Rep 1,200
OP, I found this on Reddit:
"When Chargepoint removed this setting a couple of weeks ago, my current charging limit was fixed by the Chargepoint gods at 0A. It's so fun having a completely useless charging station at home. �� My station is 7 years old, but I never had an issue until this update. It sounds like the only way to get my station to work is to remove it from my app then add it back? I did call Chargepoint, but the phone agent did not resolve my issue." |
