11-26-2013, 01:16 PM | #1 |
BimmerPost Supporting Vendor
4168
Rep 2,319
DEFIV Differential Brace
The DEFIV differential brace is a handmade structural support from the rear subframe to the differential. It drastically improves the mounting area from the differential to subframe by adding 2 new mounting points with solid billet aluminum bushings up front and replacement poly bushings in the rear making a total of 5 mounting points for the differential.
The DEFIV brace improves rigidity up to 50%, by decreasing the inflection of the differential, it allows the power to be delivered to the rear minimizing wheel hop. It creates a drastic reduction in the geometrical movement by dispersing the load from the 3 OEM rubber mounting points to the now 5 stiffer mounting points. The dispersion released into the 5 mounting points in addition to the structural support of the brace itself at each end of the frame locks in the differential for maximum performance. After having it in our shop car for more than 5,000 miles both street and track, this is a tried and true product that improves the performance of the vehicle. With or without forced induction, this is a piece that makes a difference. There are two different material options for the DEFIV brace. There is Chromoly and Titanium. The Titanium brace is significantly lighter, but equally more expensive. Chromoly was $965 -- PRICE REDUCTION -- $825 Titanium $1865 Last edited by Matt@AUTOcouture; 11-26-2013 at 03:39 PM.. |
05-22-2020, 06:19 PM | #8 |
1132
Rep 1,366
I am just seeing this too and am kind of curious...
#ladydriven Heavy-spec M3 // KW Clubsports // AA x-pipe // Gintani muffler // Macht-Schnell intake // Gintani tune // OMP Seats // Too Many Apex Wheels // Stoptech ST-60 // Cobalt Friction brake pads |
08-12-2020, 09:43 AM | #10 | |
4168
Rep 2,319
Yeah these have gone by the way side over the years. Not sure what happened with him and making the units. Regardless, we are developing a brace as we speak so there will be options available again in the future |
08-12-2020, 06:55 PM | #11 |
3903
Rep 4,170
11-01-2020, 11:02 AM | #12 |
Alex - IG @screamer
613
Rep 475
Any updates on this? Bart@AUTOcouture Sal@AUTOcouture Lalit@autocouture
Instagram: @screamer
- 2013 Subaru STi Hatch - White - Racecar - 2011 BMW E92 M3 - Moonstone - Collector Car - 2008 BMW E90 M3 - Silverstone - Racecar |
11-02-2020, 07:49 AM | #13 |
4168
Rep 2,319
reidetailing612.50 |
11-04-2020, 05:41 AM | #14 | |
159
Rep 211
Matt@AUTOcouture4167.50 |
11-03-2021, 01:26 PM | #18 |
417
Rep 441
Drives: 1M
Any update? tried to contact DEFIV directly and got no response.
2011 BMW VO 1M (Currently in pieces for New Build!)
==OLD SETUP== ViE 3884 | PR | JB4 | EOS Billet Fuel / Manifold | Seibon Hood | Spec Twin | 900IC | Slek Lip / Diffuser | EC7 Wheels | KW HAS | Maddad + GTHaus | P3 | ViE Can |
