BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) BMW Style. 570M Wheels specification request please
      02-19-2021, 07:56 AM   #1
Beemerbuster2
Drives: BMW X3 G01 20D Xline
Information required please - I have a set of four 570M 18" rims with tyres, TPMS & centre caps. These were removed from a X1 2.5D 2016 model.
Just had a potential buyer call but sadly he said the wheels wouldn't fit his X2 which is a 2018 model 1.5l
He states his existing wheel stud spacing is 120mm whereas he states mine are 112mm
The measurements for mine are -
Hub centre hole max 7.3cm min 6.5cm (conical shaped)
Stud centre to centre - adjacent holes - 6.6cm
Stud centre to centre - non adjacent holes- 10.6cm
Hub diameter 15.2cm
Measurements taken with a rule as I cannot get a micrometer in place - too long
Not sure from above where the 112mm stud spacing is measured?
Any guidance welcome as I want to update the eBay listing to make sure it's 100% accurate .
Departing comment from the chap was - "you are underselling - these wheels are in pristine condition- you should be asking more money"
They are currently on eBay at £675.
Thanks
      02-19-2021, 08:25 AM   #2
MJE60
MJE60's Avatar
England
678
Hub diameter 15.2cm
Thanks
Hi
I think he is wrong, they should be 112m in 5 bolt pattern exactly same as yours. Stud spacing is measurement from centre of bolt hole to centre of opposite bolt hole (in 5 bolt pattern use nearest opposite I.e next but one).
As far as I am aware all X1/x2 (f48&f39) has same wheel bolt pattern regardless of manufacture date.
      03-02-2021, 10:52 PM   #3
jrveron
jrveron's Avatar
245
Drives: 2023 X3 m40i
I'm with MJE60.
As far as I know, all X1 / X2 have the same bolt pattern: 5x112. You can show your potential buyer these links:
* https://www.wheel-size.com/size/bmw/x2/2018/
* https://www.wheel-size.com/size/bmw/x1/2016/
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD
Search this Thread:
Advanced Search
