08-29-2020, 09:53 AM | #1 |
68
Rep 240
Question regarding battery replacement
Hi,
Today I was surprised by a battery event. I shut-off the car, then I get back to it and unlock the doors. When I pressed the power on button nothing happened. No power was present at any button. After searching around why I have no power, I discovered that the battery is dead. When a new battery was temporary connected,the car started immediately. I'm going to buy a new batt tomorrow but untill then I completely disconnected the "-" wire from the old battery and mechanically closed the car. Is there any danger like loosing some settings of the numerous computer of the car? Regards, Stefan |
08-29-2020, 10:05 AM | #2 |
Air Vice Marshall
256
Rep 1,639
The most important settings that allow the car to function will not be lost.
2012 BMW 320d Sport (F31). 2013 BMW X3 xDrive 30d M Sport (F25). 2020 BMW X1 xDrive 2.0i MSport (F48). 2022 MB EQB 300 4MATIC AMG Line Premium |
08-29-2020, 11:33 AM | #3 | |
68
Rep 240
What kind of minor functions could be lost? A strange thing regarding the battery: Measuring the voltage of the battery connected to the car is showing just 4,3 V. Then, disconnecting the battery it showed 12,45 V. Is it strange or not? |
08-30-2020, 07:01 AM | #4 |
163
Rep 334
If you're concerned about your personal settings being lost, you can backup the Profiles to either a USB stick, or to the ConnectedDrive "cloud" service, before you disconnect the battery (see below). On my older 5 Series there was a coding process that you were supposed to follow if you were replacing the battery, to let the car know what type of battery it was (lead-acid or AGM etc.) so that the battery monitor was calibrated correctly. I'm afraid I don't know if this is the case with the X1 though...
08-30-2020, 07:36 AM | #5 |
163
Rep 334
According to the Technical Information System (TIS) you do need to register a battery change with either a coding setup, or with dealer equipment. The TIS document is here. That was for my particular car (xDrive 20i) but I imagine it would be similar for other F48 models.
08-30-2020, 08:39 AM | #6 | |
68
Rep 240
I knew I have to register the battery and I'm going to do it today with BimmerLink. I guess it should work. Regarding the backup, the info came too late for me, because I left the car without power since yesterday. After replacing the battery this morning, I found I lost many settings, but nothing that cannot be replaced. Just some time spent to make the settings again Regards! |
08-30-2020, 01:19 PM | #7 |
50
Rep 753
The 12.45V you're seeing is your alternator output.
08-30-2020, 02:51 PM | #8 |
68
Rep 240
Nope, because the battery was out of circuit, out of the car.
Alone, out of the car, the battery has 12,45 V. Connected in circuit has only a little over 4 V. That was strange. Today, the new battery measured 12,5 V out of the circuit and 12,3 V connected to the car. When started the car, the measured voltage on the battery was 14,4 V - this is the charging voltage of the alternator (as I know). |
08-30-2020, 09:30 PM | #9 | |
171
Rep 313
For example, when you start a car, you may notice that the voltage drops temporarily because of the high load from the starter cranking the engine and other systems/electronics running, including spark plugs, fuel pump. In winter/cold weather, the battery capacity is weaker which causes the voltage to drop further, resulting in harder starts. |
02-03-2021, 09:58 PM | #10 | ||
Rep 51
Could you please share the steps of registering the new battery via bimmercode? |
02-15-2021, 12:56 PM | #11 | |||
Rep 51
Just bumping this thread up for support. I've changed my battery from the OEM 70Ah AGM to 74Ah EFB and wondering if I need to do any coding changes to safeguard the rest of the electricals. Thanks |
02-15-2021, 01:48 PM | #12 |
678
Rep 910
