11-22-2019, 03:49 PM | #45 |
75
Rep 383
I have posted my update experience here. Problem with 32gb micro sd.
https://f48.bimmerpost.com/forums/sh....php?t=1670507
11-23-2020, 06:32 PM | #48 | |
Rep 3
This worked for me, Thank you! I have bmw x1 2016 with tech package, has a larger screen. I followed the step mention above and it worked for me. I used FAT32 and copied the contain from the subfolder NAVD but not the main folder. |
02-24-2021, 04:49 AM | #51 | |
Air Vice Marshall
256
Rep 1,639
The lifetime code hack (still needed the car's VIN) was soon negated by BMW who changed each map update software. You could and still can get FSC Codes and maps for nothing from a website as follows: https://mhhauto.com/ Having said that you now have to pay to join the site, so unless you are keeping the car for any length of time, it is not cost-effective.
02-24-2021, 05:57 AM | #52 |
1993
Rep 2,799
Drives: F33 430 and F39 M35i
I was able to locate 2021-1 WAY north america online, didn't need an fsc code on my '19.
I was having issues with 2020-3 EVO on my '18, it required an FSC code, but the 2020-2 EVO I found updated just fine. Once I can't update for free, I'll depend more on my phone. |
02-24-2021, 06:01 AM | #53 | ||
Air Vice Marshall
256
Rep 1,639
chowser511993.00 |
02-24-2021, 12:11 PM | #54 |
47
Rep 231
Try NTFS...it should work...keep us posted.
03-01-2021, 02:00 PM | #55 |
171
Rep 313
Bimmer Scene has links to North America WAY 2021-1 maps:
https://www.bimmerscene.com/Thread-N...ica-WAY-2021-1 To see the links, you have to register on the website and reply to the post. I downloaded ~9.5GB and will try installing in 1 or 2 days. I don't know yet if FSC code is required. Bimmer Scene has links to other maps also. |
03-01-2021, 03:57 PM | #56 | |
22
Rep 81
03-01-2021, 04:37 PM | #57 |
1993
Rep 2,799
No, you need North America ROUTE versions.
I'll host NA WAY 2021-1 I have a '19 X2 and it didn't require an FSC code. compressed .7z Last edited by chowser51; 03-01-2021 at 06:30 PM.. |
03-01-2021, 04:52 PM | #58 | |
171
Rep 313
https://www.bimmerscene.com/Thread-N...a-Route-2020-2 Check other posts in this forum for adding Car Play. ps. Here is the link from Bimmer Scene https://drive.google.com/open?id=1i0...5jRyeXfPaK73o2 Last edited by wcs2229; 03-01-2021 at 04:57 PM.. Reason: added Google Drive link from Bimmer Scene |
weight_matrix16.00 |
03-02-2021, 12:46 PM | #59 | |
1751
Rep 3,050
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
03-02-2021, 02:33 PM | #60 | |
171
Rep 313
No FSC code was required in my 2018 F48, but it may or may not be required for other people. I think it depends on your car more than on the maps themselves. ps. Here is the link from Bimmer Scene (open with 7-Zip or equivalent): https://drive.google.com/file/d/1wpC...ew?usp=sharing |
03-02-2021, 02:38 PM | #61 |
171
Rep 313
I suggest that, even if you have iPhone and CarPlay, it does take much time and effort to update the maps in your car. You never know when you may end up without cellular service on a long road trip and it costs some $$ activate CarPlay.
I have Android phone, so CarPlay is not an option for me. I have Sygic Navigation installed from when I drove an older car without navigation. Sygic also stores maps and does not require cellular service. Last edited by wcs2229; 03-02-2021 at 02:49 PM.. |
03-02-2021, 06:19 PM | #62 |
18
Rep 104
2016 X1 Map Upgrade
I'm trying to update the 2016-2 Map to the 2020-2 Map, (Both Route) on my Canadian Version 2016 X1 M Sport
I have a 64Gb USB Drive and first time out I formatted it to Fat32 I copied the files (as shown in attachment) over to the formatted 64Gb USB Drive (E. I inserted the USB into the console USB and pressed start (no brake) to enter accessory mode. The screen turned on and carried on to normal mode. No action from the USB. Same process on NTFS formatted 64Gb USB stick Last edited by Bcborn59; 03-02-2021 at 08:43 PM.. |
03-02-2021, 06:24 PM | #63 | |
Rep 16
Please let me know the procedure for updating the map. Thanks |
03-02-2021, 08:54 PM | #64 | |
171
Rep 313
Some people have posted about problems with different brands of flash drive, different capacities of flash drive, and different drive formats (FAT32 vs NTFS). You can try another combination. So far, I had success with 2 different Kingston 32GB USB 3.0 drives formatted with FAT32. Here is my procedure: 1. Start the car (running so as not to drain the battery) 2. Unplug my existing USB drive that has my MP3 music 3. Go to the Navigation/Map screen 4. Go to Settings to look up the map version and take a photo of the screen as a Before record 5. Plug in the USB drive that has the new maps 6. Click Start update when the screen pops up after if detects the USB drive 7. Take a leisurely drive while the screen displays the percentage complete (I don't move off the same screen) 8. Click OK when the screen pops up that the update is finished and the Navigation system reboots 9. Go to Settings to look up the map version and take a photo of the screen as an After record 10. Unplug the USB drive with the maps and plug in the USB drive with the music The procedure may be slightly different for your 2016 X1 and Route maps. |
03-02-2021, 09:00 PM | #65 |
171
Rep 313
03-02-2021, 09:13 PM | #66 | |
18
Rep 104
Anyone had luck with the latest ROUTE version Last edited by Bcborn59; 03-02-2021 at 09:27 PM.. |
