E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Blinking Brake Force Display??
Reply
      03-13-2011, 08:29 AM   #1
Toad335
32
Drives: LCI 335i
I found this while looking throgh my NFRM. Very interesting. Looks like you can enable a second level (BFD2) of the brake force braking. With this you can enable blinking of various lights. Seems hard to test, but would be interesting to learn more about...
Code:
    BFD2_AKTIV
*       nicht_aktiv                 not active
        aktiv                       active
    BFD2_ESS_ENABLE
        aktiv                       active
    BFD2_ESS_ANZEIGE
        aktiv                       active
    BFD2_SL_BL_1
        dauer_an
        blinkend                    flashing
    BFD2_SL_BL_2
        dauer_an
        blinkend                    flashing
    BFD2_BFD
        dauer_an
        blinkend                    flashing
    BFD2_BL_M
        dauer_an
        blinkend                    flashing
    BFD2_NSL
        dauer_an
        blinkend                    flashing
    BFD2_BL
        dauer_an
        blinkend                    flashing
    BFD2_BLINKEN
*       3_hz
        5_hz
    BFD2_V_MIN
*       wert_01                     value 01
*       wert_02                     value 02
    BFD2_A_MIN
*       wert_01                     value 01
        wert_02                     value 02
    BFD2_A_LOE
        wert_01                     value 01
*       wert_02                     value 02
    BFD2_T_ABS
*       wert_01                     value 01
        wert_02                     value 02
      03-16-2011, 02:10 PM   #2
mark19uk
mark19uk's Avatar
Drives: 320
Have you had any success with this? Would be interesting if the brake lights could flash under hard braking.
      10-29-2011, 05:12 PM   #3
MalM3
4 pot warrior
MalM3's Avatar
37
Drives: E90 318I
2006 e90  [10.00]
was this ever tested?
Been there, done that, wanna do it again
      01-08-2012, 10:15 AM   #4
E30 Racer
E30 Racer's Avatar
220
Drives: '11 1M, '09 335i M Sport
Any update? Would be really interested in seeing the German-market default settings, particularly those producing the blinking frequency shown by the GTS under hard braking in this video at around 0:31.
      01-08-2012, 11:25 PM   #5
ZZZZ
50
Drives: Z4 3.0i winterbeater
would also be interested in this.
I know it's possible to enable Brake Force Display (both brake bulbs) as the default for braking. Would be interested in having that as the default and blinking under hard braking.
      01-10-2012, 06:13 AM   #6
armyav8tor
n1smo
armyav8tor's Avatar
97
Drives: E92 M3
I noticed that in the video also, would definitely be interested in coding my car to do this.
      01-10-2012, 10:06 AM   #7
taibanl
taibanl's Avatar
281
Drives: BMW
+1
      01-11-2012, 06:06 PM   #8
rollinstone157
Brotographer
rollinstone157's Avatar
88
Drives: F30 335xi
That would be very cool! If anyone can figure this out, it would be Grant@DetailAddict...he seems very well versed in coding!
Just skimming, I'm honing in on this section:
BFD2_V_MIN
* wert_01 value 01
* wert_02 value 02
BFD2_A_MIN
* wert_01 value 01
wert_02 value 02
BFD2_A_LOE
wert_01 value 01
* wert_02 value 02
BFD2_T_ABS
* wert_01 value 01
wert_02 value 02
This seems to control when it's going to flash--ABS would logically cause the flashing to kick in when ABS is working hard, I'm going to guess V_MIN involved a minimum speed for this to kick in? I don't know, I still haven't made the plunge on a coding cable yet...even though I should.
      01-11-2012, 07:54 PM   #9
RupertPupkin
RupertPupkin's Avatar
92
Drives: Freak Beast
Not to rain on the parade.
This idea seems cool.
In the video you sure they arent LED tails and you are seeing them "blink" due to the frame rate of the camera?
      01-11-2012, 07:56 PM   #10
onebadmofo
onebadmofo's Avatar
346
Drives: 2008 E90 M3
No, that looks like LED's themselves. Also 5 series have that feature enabled from the factory, so there's a chance it's possible on 3 as well.
This is also FRM2+ only feature.
I enabled the values loooong time ago but there's no easy way to test it.
      01-11-2012, 09:48 PM   #11
anerbe
121
Drives: Red E90M 6MT
can you set up a video camera on the side of a deserted road, and do a panic stop as you drive by it?
      01-11-2012, 10:31 PM   #12
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
I was able to get this to work on FRM 1 modules (coded it on mines and a few others).
However, for FRM2 and FRM 3 modules, I am trying to figure it out. I upgraded my FRM 1 with the NFRM (FRM2) module. Fore those with frm 1 here are the values.
BFD_1_RL_BL_ERSCH_BILD = brake light
wert_03 = flashing
BFD_1_BL_M_ERSCH_BILD = 3rd Brake light
wert_03 = flashing
BFD_1_RL_BL_1_ERSCH_BILD = brake light 1
wert_03 = flashing
BFD_1_RL_BL_2_ERSCH_BILD = brake light 2
wert_03 = flashing
BFD_1_NSL_ERSCH_BILD = rear fog lamp
wert_03 = flashing
I just did the flashing on my rear fog lamps as I don't like the look of all the rear lights flashing (too slow with halogen bulbs).
      01-12-2012, 02:05 PM   #13
BOSSBMW
81
Drives: 2013 X3 35i
wert_03 = flashing
wert_03 = flashing
wert_03 = flashing
wert_03 = flashing
wert_03 = flashing
Hi Desi, sorry I'm still learning the ropes here. As an 07/2005 build E90, I have the FRM1 module?
['13 X3 SGM] [20" XXR550's in Black Chrome] [Lamin-X Tails/Fogs] [M-Sport Rear] [FOX Exhaust][H&R Sport Springs][RaceChip Ultimate][BMS N55 Intake]
SOLD-['06 325i TiAg] [19" VMR VB3 HYPERBLACK] [Blacklines] [OEM Xenon Conversion] [35% Tint] [M-Tech Rear] [M-Tech Front] [Black Vinyl Roof] [Slotted/Drilled Rotors, Cool Carbon Pads] [PBX]
      01-12-2012, 04:24 PM   #14
DESI4life10
201
No probs.
Yes you have an FRM 1 module. So you can use the codes I posted in my post.
FRM 2 started for cars built after 03/2007
      01-12-2012, 09:07 PM   #15
ZZZZ
50
wert_03 = flashing
wert_03 = flashing
wert_03 = flashing
wert_03 = flashing
wert_03 = flashing
awesome... thanks desi! I assume they only blink when braking hard, not all the time, correct?
      01-12-2012, 10:22 PM   #16
DESI4life10
201
Yep, only when the abs kicks in. works really well and alerts the drivers behind when doing a hard brake.
      01-13-2012, 01:57 AM   #17
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
On my Trans Am I installed LED bulbs in my hi mount 3rd brake light and a special flasher module that rapidly flashes ONLY the 3rd brakelight upon initial application of the brakes
Is there a way to code BMW hi mount 3rd brakelight to flash ONLY upon applying the brakes?
Car is 09' E92 with FRM2...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      01-13-2012, 04:46 AM   #18
apkraven
Ukrainian tuner
Ukraine
40
Drives: E90 335i
wert_03 = flashing
wert_03 = flashing
wert_03 = flashing
wert_03 = flashing
wert_03 = flashing
you mean with BFD_1_NSL_ERSCH_BILD (nfrm module) set to wert_03 under hard braking my rear fogs will blink, no matter if they were turned off or on? or will they always blink if i just turn on the rear fogs? thanks, it's a fun addition anyways!
      01-13-2012, 04:25 PM   #19
DESI4life10
201
They will work just the same as when they would come on and stay on under hard braking, but now it will just blink.
They come on when you lowbeams are or parking light is on.
      01-13-2012, 04:27 PM   #20
DESI4life10
201
BTW....this code is for FRM 1 module.
NFRM uses it a different way.
      01-14-2012, 08:05 AM   #21
apkraven
Ukrainian tuner
Ukraine
40
Drives: E90 335i
oh, i have a frm1 pre 2007 year i guess, just chose wrong words. will experiment with 3rd brake signal and fogs i guess, however i don't know if there are rear fogs on my ebay tail lights
      01-15-2012, 06:58 PM   #22
E90PAT
SOFLO CODING
Slovenia
199
Drives: Z4M
this is pretty awesome guys, keep us posted with nfrm modules
Reply
Tags
bfd, brake force display
e90post
