01-08-2024, 06:36 PM | #1 |
Rep 3
Top bimmercodes
Is there a top 3/5/10 that you guys consider a must do for bimmercode? Just got all of the equipment in and I’m ready to do changes.
01-09-2024, 02:00 AM | #2 | |
17
Rep 30
Here is a list of what I've coded to my M550i;
This is for sure not the complete list of my codings. I do not remember them anymore. If someone want to code something from this list just contact me. Or just ask for a specific coding, maybe I can help you with that too. Greets, Taylyan Last edited by BMW_E_F_G; 01-09-2024 at 02:34 AM.. |
01-09-2024, 09:10 PM | #3 |
Rep 3
I bought the Veepeek adapter from a recommendation of a friend that uses it on his F 30. On our G 30 it will not access all the control modulars. Just started the refund process and ordered the MHD adapter.
Did do some coding but more once the new one comes in. |
01-09-2024, 11:27 PM | #4 |
209
Rep 495
For me the top ones were:
- Disable Active Sound Design - B&W Surround Sound options - Auto Start/Stop memory (this may not work in newer models/firmware) - Custom ambient lighting colors (ProTool is way better than Bimmercode for this, but you can use Bimmercode if you invest the time to calculate hex values for each color) - Comfort Plus - Lane Change Assist - Disabled the nag to keep my hands on the wheel when using Driver Assistance I've coded other things as well but these are the ones I personally find most useful. You can find instructions for all of these and more by searching the Forum. I usually use either an ENET cable or Kies Wi-Fi adapter since coding over Bluetooth is so infernally slow. |
01-10-2024, 01:10 AM | #5 | |
17
Rep 30
I have a long time experience with the MHD adapters, I have had the MHD-orange (e-series), MHD-Black (F,G & Supra) and the latest one MHD-universal with build in K/D-can switch for E,F,G & SUPRA MK5. All of them work flawlessly. I do preffer you the MHD-universal adapter because of the fact that it covers the whole BMW family for coding and tunning purposes. I've used it for the following apps;
Regarding for software use, I would reccomend you actually the ProTool. It is way more powerful than all other apps out there on the App store. Greets, Taylyan |
boostin41.50 |
01-11-2024, 01:42 AM | #7 | |
17
Rep 30
You can not change the lightning color of the buttons in the interior. The only way to change them to another color is taking everything out of the car and replace the LED's on the boards. Greets, Taylyan |
01-24-2024, 03:36 AM | #9 |
87
Rep 231
Can you send a pic of the M5 screen?
What is the rainbow effect ambient lighting? Can you send a pic showing what the xdruve screen shows? QUOTE=BMW_E_F_G;30797415]Hi mate, Here is a list of what I've coded to my M550i;
This is for sure not the complete list of my codings. I do not remember them anymore. If someone want to code something from this list just contact me. Or just ask for a specific coding, maybe I can help you with that too. Greets, Taylyan[/QUOTE] |
02-06-2024, 10:18 AM | #10 | |
Rep 9
M550i logo missing
02-14-2024, 07:03 PM | #12 |
209
Rep 495
02-15-2024, 10:37 PM | #13 | |
248
Rep 190
02-16-2024, 06:09 AM | #14 |
7463
Rep 6,836
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
Auto Stop Start - Remember Last Setting
Video In Motion 200 MPH Speedo ACC Shortest Distance Disable Active Sound Design Turn off Drive Mode Change Pop-Ups Sport Displays FOB Open and Close Everything Don't interrupt Window Up with Engine Off Custom Ambient Lighting Colors (easier to do with Protool) AD/VLD (higher a coder)
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
lanlilan64.00 |
03-24-2024, 11:54 AM | #16 |
Rep 1
@ BMW E_F_G
I'm trying to get some guidance with this bummer coding thing please help I'm new can't really send messages y3t so if you g3t a chance please contact meit would be greatly appreciated |
03-24-2024, 03:37 PM | #17 |
7463
Rep 6,836
Pretty sure everything everyone mentioned I’ve done most of with BimmerCode or Protool.
I didn’t see anyone mention killing the pop up when switching modes, which I’ve done. Other people in the car don’t need to know and it also takes over the screen for a few seconds which is unnecessary. I’m sure custom ambient light colors is mentioned somewhere above too as well as video in motion.
03-25-2024, 01:18 PM | #18 |
399
Rep 666
Anyone coded the turn signals to 5-clicks instead of the 3? 3 is clearly not enough, and back in E90 days I was able to get 5 through Carly and Bimmercode. Don't seem to ever get this coded on the F10, F15, and G30 cars nowadays.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
03-26-2024, 08:30 AM | #20 |
7463
Rep 6,836
Can't be coded on a Pre-LCI G30, maybe on the LCI, not sure. I miss it from my F10.
yupetc398.50 |
03-26-2024, 08:37 AM | #21 | |
7463
Rep 6,836
If not, look for pop-ups under head unit in whatever app you are using.
