M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Hard Wired Dash Camera .. VERY Easy
      11-06-2016, 09:00 AM   #23
pauloamore
10
Drives: M5 LCI
Originally Posted by 3Si View Post
Just installed one today. Thank you for the reassurance that it was easy as I'm mechanically challenged. I did it without using the mirror housing, I just hid the line through the top part of the housing then inside the lining all the way to the back. Used the cigarette outlet at the back and done. Can't believe the store was going to charge me $400 to do the installation... Damn thieves told me they do it professionally and will warranty their work...
Hi there... Thanks for posting... Fitted mine...
BUT - seems like the boot cigar lighter port is love 24/7? if thats true, did you fit a power magic pro to stop the battery going flat?
      11-06-2016, 01:20 PM   #24
pauloamore
10
Drives: M5 LCI
Sorry. It's not 24/7 on. More like a delayed off.
Easy install. Happy with that. Using the boot socket.
Though didn't look to see if I have the hidden socket under glove box...
      11-06-2016, 03:31 PM   #25
3Si
3Si's Avatar
217
Drives: 16 M2, 16 Macan S, 08 Elise SC
Yes, there's a delay and blackvue shuts down after a while anyways. There is a socket under the glove box, but I don't think it is connected.
      11-06-2016, 05:47 PM   #26
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
Originally Posted by TXSurfer View Post
Anyone wire the 2ch one yet. Got in mine but now thinking of sending it back and getting the 2ch version for front and rear.
Yes mate, i have the DR650GW 2ch installed.
      11-11-2016, 09:56 PM   #27
fryh1n
fryh1n's Avatar
Drives: 2007 Z4M Coupe
2020 BMW X3MC  [0.00]
2008 BMW Z4MC  [0.00]
I was trying to install Thinkware 2 channel, but had difficulty running the wire to the fuse box in the trunk. any suggestion on where to run it? I tried running down the c pillar, but when I hit the cover for the back seatbelt, there seems to be no soft spot for the wire to hide. I couldn't take out any of the plastic cover, didn't want to pull too hard and break anything...
is there any diy guide out there for taking out the trim pieces?
new to the bmw scene and would like to know what other resources are out there.
Thanks
      11-11-2016, 10:17 PM   #28
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
Thanks
Sorry mate I'm not sure as i had it professionaly installed but i do know that they removed the majority of the trim along the top of one side to run the wires behind the side airbag, i then assume down behind the seat belt trim you are having issues with.
      11-12-2016, 01:06 AM   #29
fryh1n
fryh1n's Avatar
oh.. no worries, I will try to run it at the floor level inside the weather strip, and under the back seat. Hopefully, it'll work.
      12-30-2016, 10:45 PM   #30
WaMi
62
Drives: '17 BMW M2 BSM
Curious what size storage did everyone go with? I ordered 64gb.
I got the 128GB, wasn't too much more than the 64 at the time, although I think 64 is adequate. I recommend the Lexar 633x microSDXC for anyone looking to upgrade. A lot of dash cam owners, especially Blackvue users, have had a lot of success with it as opposed to others like Sandisk.
2017 BMW M2 | BSM DCT Exec
BMW CCA Member ID: 522493
      12-30-2016, 11:53 PM   #31
M3 Adjuster
Albania
7909
Drives: 1M, X1 M Sport, E46 325ic
Originally Posted by g force View Post
What u use it for
To take a video of people backing up to me, then claiming I rear ended them. And the occassional WW flash during track days.
: making my job easier
      01-01-2017, 10:27 PM   #32
Whatup
31
Drives: LBB M2
Not sure how reliable the source is but I remember reading that super fast cards are not necessarily better.
"Our conclusions are that superfast cards like the SanDisk 64GB SanDisk Extreme Plus 80MB/s and Samsung 64GB Pro 80MB/s need to be avoided, these cards are simply just too fast and are the worst offenders for macro blocking or pixilation on Blackvue Cameras."
Source
I ended up getting the Lexar 300x based on their recommendation and it's been working great so far!
      02-04-2017, 02:54 PM   #33
Arizona_Steve
Driving 'Mr Car Car'
Arizona_Steve's Avatar
52
Drives: 2017 AW BMW M2
Has anyone wired one of these to the fuse box in the rear of the car? I have a hard-wire set-up I'm in the process of installing, but have no idea which is the best fuse to hook the Celllink-B battery to.
Any ideas?
"Mr Car Car": 2017 M2, AW, DCT, Exec, ACP
      02-05-2017, 04:24 AM   #34
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
Any ideas?
I'm not sure if the Cellink acts the same as a Power Magic Pro but i used fuses 100 & 144.
      02-11-2017, 10:42 AM   #35
Arizona_Steve
52
It's a little different in that only one fuse is required as the Cellink battery takes over when the ignition is switched off. I ended up using fuse 145, but any fuse that receives current only when the ignition is on will do.
      03-03-2017, 06:26 PM   #36
Whatup
31
Drives: LBB M2
I have a motopak multisafer. Any suggestion for a fuse that is constantly on for the fuse box in the trunk? I thought the door locks (#150) would be okay but doesn't seem so. Trying to avoid attaching directly to battery.
m2
