03-31-2020, 09:50 AM | #793 |
1619
Rep 880
Drives: 2011 E90 M3, 2019 F150
lsturbointeg9161.00 |
03-31-2020, 11:07 AM | #794 |
"Salud"
13913
Rep 4,683
Drives: F01 & F15 / Mineral White
03-31-2020, 11:08 AM | #795 |
"Salud"
13913
Rep 4,683
03-31-2020, 10:43 PM | #796 |
1154
Rep 1,543
Was looking at ordering Prodiamine to throw down soon but then remembered I still have Dimension concentrate leftover from last year. I have some fert that I bought last year that also has Dimension in the prills so this should work out well as early spring and pre-summer applications. I'll probably stick w/ the local fert I found for my spring fert application (along w/ RGS and Humic).
- Jeff
bosstones' flickr |
03-31-2020, 10:48 PM | #797 | |
9161
Rep 14,521
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
bosstones1154.00 |
03-31-2020, 11:29 PM | #798 | |
1154
Rep 1,543
I liked the local fert and it was organic and well priced. 22-0-2, 50lb bag for $28 and it's only a 5-min drive. I saw no tangible difference btwn it, Hyr-brix, and Carbon-X last year. Soil temps are still a bit cool for me to throw anything down yet. I'm seeing a little bit of broadleaf pop up in some spots, though, so maybe I'll still do pre-emergent. 5-day average is about 45F. I had less die off this winter since we had less snow but I'll run my electric dethatcher to help comb up the dead stuff up and fluff the grass a bit before putting anything down. It's only 14" wide so it may take a bit and a lot of extension cord but it's just walking in passes. It's light as hell so it doesn't add much effort.
- Jeff
bosstones' flickr |
04-01-2020, 08:31 AM | #799 | |
9161
Rep 14,521
bosstones1154.00 |
04-01-2020, 09:39 PM | #800 | |
1154
Rep 1,543
Do you use a pull-behind tine dethatcher on your lawn tractor? I have one but felt it was better at making grooves and muddy streaks in my yard. Maybe the ground was too wet. lol The electric dethatcher I got off Amazon actually is pretty decent but I like it. Doesn't get it all up but thins it out (which is fine). Should work well for any melt off coming out of winter.
- Jeff
bosstones' flickr |
04-01-2020, 11:08 PM | #801 |
9161
Rep 14,521
this is the one i bought.
https://www.walmart.com/ip/Fiskars-S...BoCmTQQAvD_BwE yup pull behind dethatcher. you need to set yours up right if it's making grooves into your lawn. in should be scraping the thatch area only. i have a 1/2 acre so using an electric version would take to long.
Ngilbe361618.50 |
04-02-2020, 01:45 PM | #802 |
482
Rep 96
I feel like this wood stained fence is a catch 22 to clean...
I tried pressure washing and it started chipping away at the surface even when I was careful. If I spray on a diluted bleach solution, won't it make uneven light spots where the spray was more concentrated? Also it seems like the bottoms of the posts will eventually rot to death, not even sure what to do about that. The area doesn't get a whole lot of sun as you can tell. |
04-03-2020, 01:30 PM | #803 |
18079
Rep 9,381
5 days, are you kidding me?
Rain is coming in Sunday/Monday, so spread Bandini 21-7-14. Figure Tuesday after work I'll need to cut again. Blades are up at #4 now
I have romped on her and I giggled like a drunk infant the entire time. - Sedan_Clan
04-03-2020, 11:36 PM | #804 |
9161
Rep 14,521
ended up scalping the lawn to get rid of all that dead grass over the winter. looks so much better after i went over it with my lawn sweeper!
my hydrangeas are starting to wake up!
04-04-2020, 06:38 AM | #805 | |
672
Rep 740
I did it early morning (in the shade), wet everything down evenly, agitated with a stiff brush, then rinsed completely. Never let it dry on the wood. Results were perfect, with no streaking/spotting. I would think as long as everything stays wet until rinsing, you shouldn't get any spotting. |
04-04-2020, 10:58 AM | #806 |
4366
Rep 1,913
Drives: Here and There
Just finished dethatching the yard by hand. First and last time I’ll be doing that without some horsepower. Up next is aerator. Soil is just a little too dry, so I’ll water today and try it again tomorrow if that goes well, fertilizer and I think I’ve finally got a decent base for now. Previous owners just didn’t keep up with it. 7.5 30 gallon yard bags and about 12 hours of back breaking work later...
04-04-2020, 12:49 PM | #807 |
"Salud"
13913
Rep 4,683
I've been using and highly recommend Miracle-Gro Stakes! Those things are beastly! My Rose bush I just planted last Spring and then staked it in January is foking exploding with Blooms! I also used one on my young Red Crape Myrtle. They also make a organic variety I am using in my Orange and Peach Trees.
RickFLM410988.50 |
04-04-2020, 01:08 PM | #808 | |
10989
Rep 4,822
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
04-04-2020, 07:17 PM | #809 |
18079
Rep 9,381
I've been struggling with the food production in my garden. Today I was worried maybe pH was wrong so I got a little digital tester and some NPK testers
Turns out my pH is great at 7.0 but there's almost no nutrients Put about 20lbs of triple-15 thru the garden and several surrounding plants
04-04-2020, 10:57 PM | #810 | |
9161
Rep 14,521
spazzyfry1234366.00 RickFLM410988.50 |
04-05-2020, 08:54 AM | #811 | |
10989
Rep 4,822
(Disregard if you don’t have St. Augustine.)
MKSixer34187.50 |
04-05-2020, 09:53 AM | #812 | |
4366
Rep 1,913
I’ve got a few bald spots that I think will come together with a fertilizer. Was hoping to aerate today, but we’ve been getting some off and on rain. I do have some big bald spots (one from a parked boat and two more from unchecked ant mansions). I think I may need some sod for those. Bottom line, I have no idea what I’m doing! |
04-05-2020, 10:12 AM | #813 | |
10989
Rep 4,822
spazzyfry1234366.00 |
04-05-2020, 10:19 AM | #814 | |
4366
Rep 1,913
Looking at the shape of dead behind the driveway, I'd say he had about a 18 ft boat parked in the same spot for a considerable amount of time. The yard is thick surrounding it, but there's a "V" shape of really just dry dirt that shows no sign of life. Sod will be the way to go for that. I think my final battle to get to that base will be weed control in the islands under the three large oaks I have. With as mature as they are, I'd imagine I'd be fine to blast some Round-Up or something, but I'm thinking it may just be a forever battle. Would like to come up with a way to have a bit more of a permanent solution. |
