Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Single Turbo - Pump Gas - Stock LPFP ?
      05-12-2024, 07:12 AM   #1
oVeRdOsE.
oVeRdOsE.'s Avatar
2835
Drives: F25 E91 Audi Avnt E90 Cayenne
Hi, Im diagnosing the hpfp 450 walbro noise, and I put back the stock 328 LPFP.
I'm questioning now if I can leave it there. Some source state you can go up to 500whp with the stock one.
Ill do some log to see if it holds the pressure , what ? if it doesn't fall bellow 50-60psi I should be good.
I have a small-medium size turbo, 6262 + meth 600cc. On pump 91.
Did not have dyno numbers yet, but 22-23psi should put me around 550bhp, so I should be fine ?
Any concerns?
      05-14-2024, 03:33 AM   #2
noidex
Drives: BMW 335i e93 N54 6MT
If the LPFP can't keep up then the engine will simply misfire as far as I know. If you keep an eye on the fuel pressure then you should be absolutely fine.
Sick build btw, I can only dream of having your problems
oVeRdOsE.2834.50
      05-14-2024, 07:03 AM   #3
oVeRdOsE.
oVeRdOsE.'s Avatar
2835
problems are not to the end yet
This is the issue, swap is done, no check engine, nor leaks. knock on wood.
BUT, I didnt complete the break-in yet, no time to drive it, and also, when I do, its short trip, so no time to the engine to get to temp to hit it.
soon enough, I need to take few hours to street log it.
noidex9.00
