04-20-2011, 08:25 PM | #1 |
188
Rep 2,138
Drives: Me
Laser sparks revolution in internal combustion engines
04-20-2011, 09:55 PM | #4 |
Rep 494
Wow, that's very cool. Thanks for posting. Just dreaming about the better gas milage....
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit| |
04-20-2011, 11:27 PM | #5 |
92
Rep 1,603
Drives: Imola Red Z4MC
pretty cool glimpse into the future
///M - Some Mods 'N Stuff
04-21-2011, 09:42 AM | #7 |
32
Rep 480
That article mentions many statements that are incorrect starting with:
1. lean air/fuel ratio's produce less NOx. Air is 80-81% nitrogen, so by introducing more air or having lean combustion you will have more nitrogen as a by-product. 2. spark plugs are affected inside the cylinders due to high heat (strong spark) and optics wouldn't be. What happens if the optics get covered in soot, are moved due to the energy of combustion, or fall out of alignment (lose their concentration of energy)? They'd stop working or destroy your engine! 3.relatively cold metals absorb heat What is colder, your warmed up engine or your fuel or air being sucked in? Clearly an engine that is up to temperatures although it is colder is meant to disapate heat through the cooling system. Heat is a sign of a chemical reaction, but instead of heat they should be worried about force (moving the piston faster). 4.the laser is not strong enough to light the mixture uniformly from a single spot, they need multiple lasers. Multiple spark plugs are used on airplanes-good idea since they run on high energy magnetos which have to fire in a timely manner only once per ignition! but with lasers, they have to time EACH of their multiple 800 picosecond pulses inorder to be able to get enough energy to light a very lean mixture. FYI: Not only do I work in the field of combustion correction technologies, my brother is the leading scientist on ultra fast lasers and laser pulse shaping in the US. He works at fempto seconds which is 10 to the -15 (can't do exponents) they are talking about pico which is 10 to the -12...and 800 pico at that which is about 8,000 times slower than what lasers are capable of doing today. Yes the article sounds cool but it's a bunch of junk. Myth-busted. Last edited by TotalPower; 04-21-2011 at 01:50 PM.. |
04-21-2011, 10:42 AM | #8 |
63
Rep 580
Drives: G20 M340i
Ok Mr. know it all. I think it sounds cool - lasers at full power!
04-21-2011, 11:19 AM | #10 |
Supreme Allied Commander
1969
Rep 61,781
Drives: A BBS WHORE
04-21-2011, 11:28 AM | #11 |
32
Rep 480
Sharks w/ laser beams will be fighting against boats w/ laser beams:
This article on the other hand- I think is pretty freaking cool: http://latimesblogs.latimes.com/tech...pon-fire-.html |
04-22-2011, 01:48 AM | #13 | ||
46
Rep 884
Drives: 2007 BMW 335i
Also, the laminar flame speed is basically a fixed value for a fuel depending on equivalence ratio, turbulence, and combustion conditions, and there is no way to speed up a flame speed by changing the ignition location. Maybe he means the fuel in the cylinder can burn 3x as fast, but its not going to be due to flame speed enhancements. Here is a flame speed plot... As you go leaner (< 1) the flame speed drops significantly, so I wouldn't be surprised if the flame speed in a lean combustion like described is actually slower than in a normal engine running at closer to stoichiometric ratios.
Current: 2007 335i sedan
Alpine White | Sports | Premium | Cold | Comfort Access FORMERLY: 128i coupe Alpine White | Sports Package | Black Leather |
04-22-2011, 09:43 AM | #14 |
113
Rep 1,347
Drives: 2011 335d
Too much science... losing interest....
So back to the original point of this post.... LASERS!!!! |
04-22-2011, 09:49 AM | #15 |
32
Rep 480
I am possitive that lean combustion will raise combustion temperatures since you are introducing more oxygen into the cylinder in order to more completely oxidize the fuel you are spraying-which is why you will see reduced fuel consumption and reduced CO/PM. Unfortunately, because air is mostly nitrogen, you raise NOx by going lean.
*Look after the vertical bar (stoich)...you see NOx go up, CO, PM go down. Since CO and PM go down that means you are getting more energy (heat and pressure) out of your fuel. This is true only up until the point that the reaction is no longer stoich and you begin to be too lean and require more fuel. Having richer combustion is a way to cool your engine down, because when fuel sprays into your combustion chamber it is in the form of a fine mist that is considerably colder than the internals and the spray will slightly vaporize but will dramatically reduce temperatures. This of course is not the best way to cool down an engine, but it works. |
04-28-2011, 01:09 PM | #17 |
44
Rep 1,855
+1
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
