04-22-2022, 06:07 PM | #23 | |
209
Rep 494
Just be sure to follow the instructions because the biggest danger is having the ECU power off unexpectedly while coding it. Also, if you haven't purchased an OBD2 adapter yet, be sure to get one that's fully compatible with your car. The Bimmercode site has that info. |
04-22-2022, 09:23 PM | #24 | ||
Rep 13
I'd like to make all of my ambient lights red - can you point me in the direction of where I could find instructions for that? Or is it a matter of poking around until I find what I'm looking for? |
04-23-2022, 12:05 AM | #25 |
209
Rep 494
If you only care about making all of your lights red, you only need to code one color on the iDrive menu. Bimmercode may allow you to code the first color only (bronze) without using Expert Mode but I'm just working from memory here. The RGB code for full red is FF0000 (Red=FF, Green=00, Blue=00.) Look in the Body Domain Controller (BDC) for Ambient Lighting coding and plug in FF0000 for all of the values in the first menu option - there may be up to four of them. Feel free to share a screenshot if it's not clear how to do this.
04-25-2022, 04:34 PM | #26 |
7427
Rep 6,812
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
I custom coded mine with ProTool. I just replaced Bronze and Bronze and White. ProTool offers a menu where you just pick the colors for the four zones and press "code". I have not messed with four different colors for each zone. That's a little much.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| Last edited by Joe-BMW33; 04-25-2022 at 04:40 PM.. |
maDjzo863.00 |
04-25-2022, 09:07 PM | #27 |
209
Rep 494
I agree, ProTool is definitely the way to go for coding ambient lighting. Strange though, it doesn't let you code the last few colors on the menu; still need expert mode for that.
09-20-2022, 08:23 PM | #29 |
42
Rep 100
I am using ProTool with the bimmergeek bluetooth connector. On my ambient light screen I can only edit "upper" and "lower" layers. How did you configure four layers? expert mode?
09-21-2022, 01:59 AM | #30 | |
7427
Rep 6,812
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
Nai1ZuTe42.00 |
06-06-2023, 08:20 PM | #31 |
20
Rep 59
Drives: 2023 BMW 530e
I have a 2023 530e (G30) Bimmercode guys told me that you can not do dual color (contour color) because it is an LCI model. Bummer. It worked awesome in my 2018 530e. But not the 2023. Does anyone know if ProTool can do it? I just bought ProTool, but don't see anything anyplace to change ambient lighting. I'm most likely looking in the wrong place. Thoughts anyone?
06-07-2023, 04:03 PM | #32 | |
209
Rep 494
Joe-BMW337426.50 |
11-04-2023, 08:46 AM | #33 | |
Rep 1
Custom ambient lighting
Could you please send me a message on how much you will charge to do this? Thank you Abz |
11-04-2023, 02:32 PM | #34 |
Rep 19
11-04-2023, 03:54 PM | #36 |
64
Rep 168
So let me get this old brain straight on this. You download Pro Tool or Bimmer Utility to lets say a laptop then hook it up to the OB port via the special cord and proceed?
11-04-2023, 04:22 PM | #37 |
Rep 19
