09-14-2009, 06:22 AM | #1 |
yodog
197
Rep 5,025
Replacing the 8" subs?
If I were to swap out the stock 8" subs underneath the front seats and drop in the SWS 8" or whatever fits (I think it was the SWS) would it give an improvement using the stock headunit?
I'm pretty satisfied with the overall system but when I turn up the sound, the bass does seem to lack compared to the treble, just seeing if this will fix it.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
09-14-2009, 01:33 PM | #2 | |
2312
Rep 13,025
The biggest improvement is with a 2-channel aftermarket amp of some 150W RMS per channel, regardless of system. |
09-19-2009, 02:10 PM | #3 |
128
Rep 1,144
Technic, what's the smallest/lowest heat output amp out there. I was thinking about trying to install the amp local to each sub. It would be really convenient if all I had to do was run power to that location - or would it just be easier to install the amp in the trunk?
09-19-2009, 05:56 PM | #4 |
190
Rep 1,497
I've installed SWS-8s with Rockford P300-2 amp (it fits under the trunk mat),
installation was straight, and sounds way better than OEM now. Technic was the big man who helped me answer all my questions and tips, mad props to him |
09-21-2009, 04:21 AM | #5 |
yodog
197
Rep 5,025
That's awesome. Does it take away anything from the idrive audio settings? How much did they cost/where do you get these parts?
How's the clarity compared to stock when the volume is turned up?
09-21-2009, 05:48 PM | #6 | |
190
Rep 1,497
I got my SWS-8s from ebay $200 shipped for two 2ohm subs, and Rockford P300-2 amp from amazon for $136.18 shipped (luckly, it was on special sale when I purchased) It's just sub upgrade for more bass, clarity is pretty clear and deeper than stock (premium audio subs), SWS-8s are good enough for me. |
10-21-2009, 07:36 AM | #7 |
4 * General
58
Rep 644
do u have a diy for this or pics as i wanna do this also. i cant stand the stock premium subwoofers.
Nissan GT-R (Sold) E92 M3 + 335 (sold) F10 535 (sold) When Driving Nice Whips It Helps To Have Nice Kix!
10-21-2009, 12:01 PM | #8 |
67
Rep 1,895
Premium sound Bass lacks the sharp punch. I'd also be interested in adding/replacing the subs to get the bass to kick. Just not sure which is the best & cost effective way to do it.
10-21-2009, 03:30 PM | #9 |
e36s54, e70x5d
152
Rep 1,723
For Enhanced Audio:
- Replace the 8" speakers with Earthquake SWS-8 - Install an Audio Control LC6i in the back by your OE Amp - Install an Alpine 4.150 or 2.300 to power the subs Done Doing this next month - maybe I'll take pics and post a DIY |
10-22-2009, 06:43 AM | #12 | |
2312
Rep 13,025
http://www.davidnavone.com/cart.asp?24&cat=7 http://www.m3post.com/forums/showpos...8&postcount=15 |
10-22-2009, 09:55 AM | #13 | |
e36s54, e70x5d
152
Rep 1,723
great point - and saves $$$ Thanks Technik |
10-22-2009, 10:21 AM | #16 |
2312
Rep 13,025
There's no documented per-channel power rating, only that it is a "825W amp".
So I guess that it should be a little less than twice as powerful as the Logic7 amp (420W total) per channel, so in approximation: - 150W x 2 for the woofers at 7 ohms - 75W x 7 for the 4" components at 4 ohms Total = 825W |
10-22-2009, 11:04 AM | #17 |
1153
Rep 8,027
Am I not right in thinking that the watt isn't really the important thing in a 'normally powered' system, is it not the efficiency of the speakers that's important?
Like doesn't ever 3dB of efficiency basically double the volume heard. |
10-22-2009, 11:38 AM | #18 |
4 * General
58
Rep 644
2 or 4 ohm replacements?
10-22-2009, 02:59 PM | #19 |
183
Rep 2,872
I've looked at all the DIY installs and this seems really easy.
I am going to do this as a winter DIY because if I'm not working on little installs here and there I go crazy. Winter time is when I start fabricating and one off modding things on my cars lol So as of recently, can you guys confirm SWS8 paired with the Rockford p300-2 is the best way to go? And why buy SWS8 2 ohm over the 4ohm any difference?? |
10-23-2009, 06:34 PM | #20 |
4 * General
58
Rep 644
10-24-2009, 12:52 AM | #22 |
Scared money don't make money.
68
Rep 1,448
Drives: 2009 E92 M3 DCT
Damn you guys...I keep running into threads like this and deciding to buy more stuff . Bump for an answer on the 2 ohm vs 4 ohm question.
2009 E92 M3/DCT/Alpine White/Fox Red/Carbon Leather OE Tuned 402 whp & 303 wtq/Gintani X-pipe/MXP Axle Back/Rogue Pulley/AFE Stage 2/Cosmetics By IND & EAS HUGE THANKS: Gintani, OE Tuning, and EAS |
