BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Bimmercode - How to use rear lights as signal lights.
      05-26-2019, 08:03 AM   #1
SDriver18i
SDriver18i's Avatar
80
Drives: BMW X1 s18i 2019
UPDATED WARNING:
My right LED rear DRL started to dim about 2 months ago, I got it fixed for free since I still have my warranty but I'm assuming its because of this.
It required changing the entire DRL module.
So, I will no longer recommend coding the DRL's. It might last 1 year, it might last 5 years, but it does have high probability of just giving out.
The fog lights as brake lights however is just a quick change led bulb, if it does ever fail. The fog code is on the second page, provided by Takabo.
So, I found this video.
https://www.youtube.com/watch?v=GN01Pa91PcM
Thought it was cool. Came here for help but I also found the solution.
I tried it but it didn't work properly.
With some help from the video creator, I managed to get it working for the X1 ECU!
Just a note: This will disable daytime running lights in the rear during the day.
Here's how it goes: >
Bimmercode > Body Domain Controller > Expert mode.
The codes below are found in LceLampMapping3 and 4.
What to modify: Keep in mind the names might be somewhat different in the X1. H2 becomes 2H and H becomes 1H. Other than that, this should hopefully work.
MAPPING_TAGFAHRL_H2_L_OUTPUT - sl_2_l
MAPPING_TAGFAHRL_H2_L_FUNCTION - Value 0x06
MAPPING_TAGFAHRL_H2_L_PRIORITY - Priority 1
MAPPING_TAGFAHRL_H2_R_OUTPUT - sl_2_r
MAPPING_TAGFAHRL_H2_R_FUNCTION - Value 0x07
MAPPING_TAGFAHRL_H2_R_PRIORITY - Priority 1
MAPPING_TAGFAHRL_H_L_OUTPUT - sl_l
MAPPING_TAGFAHRL_H_L_FUNCTION - Value 0x06
MAPPING_TAGFAHRL_H_L_PRIORITY - Priority 1
MAPPING_TAGFAHRL_H_R_OUTPUT - sl_r
MAPPING_TAGFAHRL_H_R_FUNCTION - Value 0x07
MAPPING_TAGFAHRL_H_R_PRIORITY - Priority 1
MAPPING_STANDL_H1_L_PRIORITY - Priority 3
MAPPING_STANDL_H1_R_PRIORITY - Priority 3
MAPPING_STANDL_H2_L_PRIORITY - Priority 4
MAPPING_STANDL_H2_R_PRIORITY - Priority 4
If you also want to disable the orange signal light and only use rear lights for signal, complete the following. (You might get a ticket or warning depending on your state, so, do not do this!)
MAPPING_BLINKER_H_L_PWM_LEVEL_1 - 00
MAPPING_BLINKER_H_L_PWM_LEVEL_r - 00
Appreciate 4
MJE60678.00
rameer5.00
Takabo49.00
X1604M55.50
      05-26-2019, 09:12 AM   #2
MJE60
MJE60's Avatar
Originally Posted by Neworgri View Post
So, I found this video. Thought it was cool.
I tried it but it doesn't really work properly on the X1. Can anyone familiar with the functions of the codes tell me how to debug this and make this work on the X1? It triggers both rear lights when I use it.
I also have a few things coded, lights wise I have hyperblink. I don't know if these would interact or not.
This is the code he posted:
MAPPING_TAGFAHRL_H_R_OUTPUT - sl-r
MAPPING_TAGFAHRL_H_R_FUNCTION - Value 0x06
The first thing you need to be aware of is that the layout of rear light clusters on the F48 varies between markets (I.e brake light, indicator light, whether led or not). In brief bulbs/led can be in different position). There are also different regulations, for example flashing brake light when doing high speed emergency braking is not permitted in the US but is std in EU (can be coded). Using coding for a different model in a different market will often not give the results you expect.
X1604M55.50
      05-26-2019, 09:35 AM   #3
SDriver18i
SDriver18i's Avatar
80
Yep, which is why I wanted to ask if there was someone here that has perhaps done this and would know how to sort this out. Because it works, just not properly!
      05-26-2019, 01:56 PM   #4
SDriver18i
SDriver18i's Avatar
80
Update! Got it to work! I'm updated the thread with details on how I got it to work.
      05-26-2019, 07:02 PM   #5
Douggie
142
Drives: BMW X1, X3
Cool!
      05-27-2019, 06:06 AM   #6
civciv
Drives: X1 F48 Med. Blue
Looks like it blinks faster than usual.
      05-27-2019, 08:14 AM   #7
SDriver18i
SDriver18i's Avatar
80
I have hyperblink coded in, that's why.
      09-07-2019, 10:46 PM   #8
ventjock
65
Drives: 2020 M340i
If I were to code this will blinking speed remain the same. I do not want “hyperblink” as you stated above
      09-08-2019, 02:43 AM   #9
SDriver18i
SDriver18i's Avatar
80
Yes, hyperblink is a separate code. I have long coded it out.
      01-04-2020, 11:07 PM   #10
AutobahnX1
Drives: 2019 F48 X1
Neworgri - can you provide update on how coding has performed over time as well as how to not have hyperblink?
      01-08-2020, 01:23 AM   #11
SDriver18i
SDriver18i's Avatar
80
No issues whatsoever, performs great!
Hyperblink is a separate code and has nothing to do with this.
      01-12-2020, 09:32 AM   #12
Takabo
Takabo's Avatar
Japan
49
Drives: G21 320d xDrive Touring MSport
Hi Neworgri,
I also tried "Rear DayLights as Signal Lights". It's fun is not it.
Thank you.
P.S.
Since I did backup, I can always return.
BMW 320d xDrive Touring M Sport(G21)
Production Plant: Munich, Production Date: 2021-02-25
      01-14-2020, 05:45 AM   #13
SDriver18i
SDriver18i's Avatar
80
Originally Posted by Takabo View Post
Hi Neworgri,
Nice! Looking great.
Takabo49.00
      05-27-2020, 09:02 AM   #14
samuelbpereira
Brazil
Drives: BMW X1 25i 2019 F48
Hello, I'm not able to make the arrow flash more than 3x, I didn't find this option in bimmercode, can you tell me where it is in advanced mode? BMW X1 F48
      05-30-2020, 10:59 AM   #15
samuelbpereira
Brazil
Hello, has anyone done or know how to make the fog light turn on at the position of the light at 0? I wanted to connect the fog with the headlight at 0 because the angel eyes get stronger, when I turn on the headlight the angel eye lowers the intensity.
      06-20-2020, 06:02 PM   #16
okankaymak
Drives: 2021 330xi M Sport
How can I make the LED brake lights to be also used for signaling?
2018 X2
      06-21-2020, 07:14 AM   #17
SDriver18i
SDriver18i's Avatar
80
2018 X2
Its written above in the post on how to do it, on a thread on how to do it.
What????
      06-21-2020, 04:49 PM   #18
okankaymak
What????
It's written above in the post how to use DRL lights as signals.
I'm asking how to use BRAKE lights as signals.
Takabo49.00
      06-22-2020, 04:38 AM   #19
SDriver18i
SDriver18i's Avatar
80
AH! Completely missed that!! Just went in the ECU, there doesn't seem to be a way to map the brake lights since it only uses 1 function.
Send a DM to Takabo and see if he can figure it out. Please update if you find something
Takabo49.00
      06-28-2020, 10:21 AM   #20
Takabo
Takabo's Avatar
Japan
49
I sent a PM to Mr. okankaymak.
      06-28-2020, 10:32 AM   #21
SDriver18i
SDriver18i's Avatar
80
Did you actually figure out a way to make it work? If you did, show a vid!
Takabo49.00
      06-28-2020, 10:42 AM   #22
Takabo
Takabo's Avatar
Japan
49
Hi SDriver18i,
It's blinking like this.
