08-15-2021, 02:05 AM | #1 |
Rep 1
Tailgate interior button problem x1(f48)
Hi,
I have a problem with the interior tailgate button. When the tailgate is open I push the button and it doesn't close. It closes normally with the exterior tailgate button, with the driver's door tailgate button and with the key tailgate button. I also want to refer that when the tailgate is opening and I push the interior button it stops. But when I push it again it doesn't close. Does anybody had the same problem? Doew anybody know how to fix it? Thanks. |
08-15-2021, 10:16 AM | #2 |
105
Rep 118
Drives: 2024 330xi
You must press and hold the interior button until the door is completely closed. As soon as you lift off the button the door stops, for safety precautions.
08-15-2021, 11:43 AM | #3 |
Rep 9
We thought ours was broken too for that exact reason, you have to push and hold the switch down until the tailgate is closed. It's a bit unintuitive when considering the vast majority of tailgates dont function this way, but I appreciate it now that I know.
08-16-2021, 02:58 PM | #4 | |
Rep 910
08-17-2021, 11:05 AM | #5 |
159
Rep 458
An issue I have with mine is that when the tailgate is open, if doors (and occasionally windows) are open and I press the close button (on the tailgate) or use the vehicle key, alarmingly from my perspective, it ends to simply 'slam' into the closed position without activating the soft closure mechanism in the last moment of closure. With doors closed and windows partially open the issue doesn't seem to arise. I have mentioned this to the dealer service people, but they have simply brushed it aside. So I wonder if anyone else has come across this and if so how it was overcome.
08-17-2021, 01:37 PM | #6 |
Rep 1,079
Yeah it is a little "loud" on that last close.
I coded out the holding down the button I believe on bimmercode so it is a flick on and it'll go. Also it'll close with the key fob as well. |
11-14-2021, 03:35 PM | #7 | |
Rep 12
Sorry, i have the same need for coding this and enable audio but when using the bimmercode app it doesn't show me options available/cars/f48/ What i was looking for are:
How did you change it? |
11-14-2021, 05:05 PM | #8 | |
4430
Rep 7,475
BTW…you did purchase the app and communication tool to connect to your car, right? Only asking because I’ve read some threads where people thought they could download the “test” app and start coding for free. You can’t code anything until you actually pay for the app.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-14-2021 at 05:20 PM.. |
11-16-2021, 04:55 PM | #9 |
Rep 12
11-25-2021, 07:44 PM | #11 | |
4430
Rep 7,475
If you want to code the 3 options that appear, then just follow through with the instructions on how to code (activate) what you want. Just select the option and see what selections are codeable…then choose what you want it to be (active or not active etc). There’s no need to go into EXPERT MODE for those 3 options.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
11-25-2021, 08:14 PM | #12 |
4430
Rep 7,475
You don’t have #1 (in the diagram below) just above the master window switch on your driver’s door?
When you decode your VIN does it list the option code for the automatic trunk lid mechanism S316A?
11-28-2021, 05:30 PM | #13 | |
Rep 12
OK tks. A bit weird really, i have all the buttons and i allways assume it's just programing that is missing. I have the buttons in the tailgate ( number 4 on your the post ) and in the interior button on drivers door. But, it's just a matter of confort not a biggie |
