BMW M3 and M4 - The Icons
home
Classifieds Sponsors Classifieds Suspension / Brakes / Chassis / Spacers
      02-15-2024, 12:47 PM   #1
IND-Distribution
BimmerPost Supporting Vendor
IND-Distribution's Avatar
9599
Drives: G82 M4 / G87 M2
IND | Race Technologies G8X M3 / M4 Brembo Brake Pad Sets
Performance pad compounds now available for G8X vehicles.
The TS20 is the ideal dual purpose compound for street and light track use. The TS20 combines an aggressive initial bite, good heat resistance all while keeping dust and noise to a minimum. TS20 are offered for a select range of OEM Brembo caliper shapes.
The RE10 is the ultimate endurance race compound offering a balance of excellent stopping power, low thermal conductivity, and extremely low pad and disc wear. Utilizing the latest friction material technology, RE10 offers consistent performance under the most demanding of environments.
NOTE: For BMW Steel Brakes / Iron Rotors only. Does NOT fit BMW Carbon Ceramic Brake Option
Race Pad Disclaimers:
  • Running a "racing use only" pad on the street could produce excessive noise and dust.
  • Disc wear could be accelerated if driven at cold temperatures or used in the incorrect temperature range.
  • Racing pads are designed to work in specific temperature ranges so it is important to choose the desired compound for the correct environment the vehicle will be used in.
Race Technologies pad compounds are run on a brake dynamometer over multiple brake applications (stops) to test the materials in a controlled environment for the most accurate data. Wear rates and temperatures can be influenced by car setup, grip levels, track layout/configuration and many other variables.
The Race Technologies G8X M3 / M4 Brembo Pad Sets may be viewed at the following links to our website:
Street / Light Track: https://ind-distribution.com/product...-brake-pad-set
Endurance Race: https://ind-distribution.com/product...-brake-pad-set
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
[/URL]
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
g80
