BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Carplay
      01-04-2020, 08:26 PM   #1
bimmerbenz65
105
Drives: 2024 330xi
2024 BMW 330xi  [0.00]
2022 BMW 330xi  [0.00]
Carplay
If the car did not come with the car play option, can it be added after? I have a 2018 without navigation
      01-16-2020, 08:43 AM   #2
sdp77
Drives: 2018 BMW X1
I know on the 2018 X1 you can pay $300 and add CarPlay.
      01-16-2020, 10:24 AM   #3
Jorix
73
If the hardware supports it, but considering that the OP does not have navigation - it most likely doesn't.
dianebrat109.50
      01-16-2020, 12:23 PM   #4
dianebrat
110
The number of people who don't understand the hardware component and just say "of course you can just add it" never ceases to amaze me since I initially had an X2 that had no way at the time to do CarPlay even though the dealer said "sure we just add it here...." and then proceeded to not be able to.
I don't know if Shawn's magic connection would have been able to do that in that vehicle since I swapped it for a car with the set of options I wanted.
      01-18-2020, 03:00 PM   #5
MaloDero
Drives: BMW X2
That the same on 2019 X2 model ? It saw it once on the screen and then gone?
Help!
      01-18-2020, 09:29 PM   #6
dianebrat
110
Help!
It would help if you expanded this comment to say what you're referring to because at the moment it makes no sense.
      01-20-2020, 10:34 AM   #7
stvward
stvward's Avatar
133
Drives: G42 M240i on order
I have a CarPlay MMI installed in to my 2017 M240i which gives me full Wireless Apple CarPlay (also an android capability if you use an android phone). If you have a look on YT for the bimmertech video where they install their MMI Prime then you will get an idea of the install process that I did myself. PM me if you need any further info. Happy to help although you will need to check that they have a system for your car. It appears that there is:
https://www.bimmer-tech.net/category...y-mmi-retrofit
      01-20-2020, 10:35 AM   #8
stvward
stvward's Avatar
133
I mentioned the Bimmertech YT video above but thought that I should mention that their's is too expensive. I got mine (identical unit) for around $230 (around a third of the Bimmertech one) from a Chinese supplier who is well regarded.
This thread has a load of information also:
https://f30.bimmerpost.com/forums/sh....php?t=1675929
