ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
SUPPORT ZPOST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
      05-14-2010, 08:15 AM   #1
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
43
Drives: '07 Z4MC
Share Your Alignment Specs
I just got my alignment done last night and wanted to share the info. I've seen that other people posted their alignment info in other threads but thought it might be handy to consolidate it into one. Here are my setup, specs and impressions.
Stock Suspension
Impressions:
Haven't driven the car much since I got it done but turn in feels stronger. I will report back after a run through the twisties.
      05-14-2010, 10:53 AM   #2
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Mine with H&R lowering springs:
Front
Camber: -1.7(-1.6 on right)Pins pulled
Caster: 6.2(6.3 on right)
Toe: -1/16"
Rear
Camber: -1.5
Toe- 1/8"
Note: This is a setup for these springs.
[URL=http://imageshack.us/photo/my-images/153/071jt.jpg/]
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      05-15-2010, 01:54 AM   #3
blender
Custom User Title
blender's Avatar
149
Drives: black
KW V3 Coilvers, 15mm drop, stock wheels, 225s front, 265 rears. 95% street driving.
Front Camber: -2.6 L, -2.6 R
Front Caster: 6.0 L, 6.2 R
Front Toe: 0.05 degrees inwards, both sides
Front camber was achieved without plates by using the Turner camber bolt kit mentioned on another thread here.
Rear Camber: -1.6 L, -1.6 R
Rear Toe: 0.04 L, 0.03 R
Car turns in smartly and holds the road freakin' great. Just a hint of understeer left at the limit.
Corner balancing coming next week ; )
      05-15-2010, 07:03 PM   #4
Master Apex
18
Drives: '17 F80 M3 '07 Z4M '06 E60M5
Stock suspension on 245/40/18 and 275/35/18.
Front:
Camber -1.5
Toe 0.05
Caster 6 degree
Rear:
Camber -1.9
Toe 0.28
      05-19-2010, 11:30 AM   #5
Rick Hunter
Skull Squadron Leader
Rick Hunter's Avatar
307
Drives: '07 M Coupé & '16 435xi GCoupé
Ground Control Coilovers on 245/35/19 F and 275/30/19 R tires.
Alignment set to street driving:
Front L&R:
Camber = -2.1
Caster = 7.7
Toe = 0.00
Rear L&R:
Camber = -1.8
Toe: in 0.15
      05-19-2010, 01:08 PM   #6
Incompatible
55
Drives: 07 AW Z4C 3.0Si
Front L&R:
Camber = -2.1
Caster = 7.7
Toe = 0.00
Rear L&R:
Camber = -1.8
Toe: in 0.15
Rick, how's your inside tire wear with these settings?
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
      05-20-2010, 12:19 AM   #7
Rick Hunter
307
So far so good. I unfortunately don't take her out as much as I once did, so there's not enough miles since the alignment to really give a good answer. I DID want a more aggressive street setup though, and it's definitely noticeable (handling). I still figure the tires will expire before they wear out.
BTW... only have done about 1000miles since alignment (2 months ago), to put it in perspective.
zpost
